Question about Refrigerators
I was trying to clean the filter for my GE refridgerator and I accidentally broke the compressor tubing ( I think). What's the best way to have that fix? Thank you
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 74 Answers
Soder in a new pice
Posted on Dec 02, 2012
2 Suggested Answers
  • 195 Answers
SOURCE: i changed water filter on ge profile refridgerator now water doesn't dispense
HI.HAVE U TURNED WATER ON? :) GOOD LUCK
Posted on Jun 29, 2012
Ge monogram refridgerator water on floor
Is the water filter located behind the grille under the doors?. I had the same problem and found the O ring on the filter cartridge was leaking.
Dec 17, 2015 | GE Refrigerators
GE Monogram ZIS480D broke again
GE refridgerators have what they call a main dome control board. This is located on the back of the machine, usually closer to one side or the other and about halfway up the machine. This board really controls everything, even as far as the dispenser in the door. I personally think this is a poor design, even though they look awesome cosmetically. Locate your model number, usually in the refridgerator side somewhere, and go to www.repairclinic.com to order the part. This is becuase they have a return policy that no one can beat. If you install the part and it doesn't work they will take it back and refund you, where as any other part distributor have a no return policy on electronic parts. Good Luck, but you won't need it. This is an easy repair
May 28, 2012 | GE Monogram ZISx480DR 48-inch Side by Side...
I have a frost free upright ge freezer that quit working. No cold at all. It is less that 2 years old. Where did the quality go in GE? I have a GE microwave and it broke within the first year. Is it me or...
when the compressor is working and dont produce cold maybe the tube is leaking, causing the freon gas to scape. you need to reprocess your freezer to clean up and to find leaking tube to fix it. you nee a white line technician to fix your problem.
Jun 16, 2010 | GE 203 cu. ft. General Electric Upright...
My 5 year old daughter broke off the 1/4 inch pipe on the compressor motor on the back of our brand new GE compact fridge where it was crimped and soldered. All of the refrigerant came out. Can it be...
Nope it should not exceed the cost of a new one. Get a quote first to be sure. You can tell them what has happen. Mostly the quote includes refrigerant charging (that include resoldering of the tube), labor, others, and transportation.
I think your daughter broke the charging tube.
Sep 17, 2009 | GE Refrigerators
My refridgerator runs but does not stay cold.
First you can try cleaning out all the dirt, dust and debris from around the compressor. Second try to recharge the freon in the unit. Third you can probably have the compressor tested it may be weak and neeb of replacement. In most cases it's cheaper to replace the refridgerator............
May 06, 2009 | GE Refrigerators
Whineing noise\and leak on freezer side in the bottom of it
yes the water in the bottom is because your drain tubing is cloge thid is the small hole in the frezer area defrost your fridge use a wire to clear out the debri that clogs your tubing the water should drain in the pan where the compressor is thanks from gilles
Feb 10, 2009 | GE GSS20IEP Side by Side Refrigerator
GE Profile PSS26NG Not cold
hi thanks for the question the problem you are having is with the defrost cycle . check the defrost timer and the defrost termination switch. and also clean all coils at the back, and clean drain tube ,from freezer to drain tray at the back. thanks the appliance doc. rate me please
Sep 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refridgerator Issue
Sounds like a compressor trying to start and is not. Check at the compressor for a hum then a click. This is a sign that the compressor has failed. If you had a power outage try unplugging it for a period of time and then plug it back in.
May 19, 2008 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
