Question about Irons
How to open pressa bella dry steam iron, to put water in
snakehead
  • 1074 Answers
SOURCE: My Tefal Steam Generater Iron will not steam
check the little tube that regulates the water to the holes it needs to be changed.good luck.
Posted on Apr 18, 2007
satscoop
  • 59 Answers
SOURCE: Brown spots coming from steam iron
you can mix 50% water with 50% vinager let it set in the iron overnight then turn it on and let the steam run out.What happens is the inside of the iron where the water is had corroded or rusted or has lime deposits.the vinager will break this loose overnight.also after you let the iron steam out all the mixture,flush the iron 4 to 5 times and start using fresh water from a store bought gallon.your tap water is probably full of iron.
Posted on Nov 15, 2007
jaylex
  • 417 Answers
SOURCE: Rowenta DA75 - Won't Steam
Can you remove the steam button if you can fill with water heat to maximum and holding over sink remove steam button rod this will clean the steam traks but be careful this gets very hot.
Thanks J
Posted on Feb 11, 2008
SOURCE: Rowenta Steam Iron Leak
I have purchased two Rowenta irons. Both have the problem with water leakage. The entire iron looses all of it's water....both in the stand up position and the sitting down position. This happened after a couple of months for both items. I contacted Rowenta and they never responded. I will never purchase another item from them. Obviously, the irons must be defective. I'm going to contact consumer affairs.
Posted on Sep 03, 2008
SOURCE: i have an elitech steam generator iron but water
I have had this iron for 5 months and only been used 4 times. When I turn it on , there is water leaking out of the iron and the handle is too hot to touch after a few minutes
Posted on Aug 10, 2011
Tip
My Steam Iron is Leaking Water
If you are having trouble with your steam iron leaking or dripping water, then this tip is for you.
The first thing to remember is that the wrong water can cause you many problems with your iron. If you are experiencing problems, one of the first things to try is to use different water in your iron. Steam irons need a certain amount of mineral in the water for them to operate properly, but too much mineral, iron, or organic matter can be disaster.
Too much will cause all sorts of problems. Brown water, white scale and other problems will come from the wrong water. The wrong water will also cause the iron to corrode and leak. Of course not taking care to store the iron properly will also cause corrosion and leaks. See my other steam iron tips on the brown water and white scale issues.
So, if you are having problems, you must first figure out if it is bad water causing the steam iron to spit the water out of if in fact you have a leak internally. Internal leaks are not repairable. They are often caused by a combination of poor water quality and not drying the iron properly before storage. Either of these can cause internal corrosion and lead to leakage. Make sure to use good bottled spring water and empty the iron before storage. Lay the iron horizontal for a few seconds while hot to dry the remaining water from the tank before storing on its heel.
Poor water quality can also cause the iron to spit the water back out the wrong places and give you the impression that you are leaking, when in fact you are not. Water that makes steam too rapidly, will spit out all over the place and will not want to stay in the tank and make steam. Before assuming that you have a bad leaking iron, try using different water first. You may also need to follow my tip for cleaning the water tank of your iron, so that the different water can be effective.
In short, the wrong water can cause many problems when it comes to steam irons. Do some experimenting before you buy another one only to soon have the same problems all over again.
on Jul 14, 2010 | Irons
How do I put water in the Sunbeam Steam Iron #GCSBBV-200
If the GCSBBV-200 is similar to other Sunbeam steam irons, fill the iron when it is cool and unplugged. With the ironing surface flat on the sole plate, set the Steam dial to dry and the Fabric Select dial to Min. Then use an easy-pour measuring cup to pour water into the opening at the top front of the iron. Make sure not to fill past the maximum fill level. (Tip the iron up as if you were resting it between passes with the iron to check the level.)
I hope this helps.
(Sunbeam has the manual for the GCSBBC-395 on their support site: http://www.sunbeam.com/service-and-support/product-support/instruction-manuals/garment-care/other/garment-care-other-manual.html . The direct link to the manual is http://demandware.edgesuite.net/aamb_prd/on/demandware.static/Sites-sunbeam-Site/Sites-sunbeam-Library/default/v1425126445413/documents/instruction-manuals/160253.PDF . Check how similar your iron is to the newer models.)
Mar 01, 2015 | Sunbeam Irons
Floor steamer not getting hot
follow this steps and fix it.
GOD BLESS YOU
Clean an iron:
  1. Unplug the iron and make sure it is cool before cleaning.
  2. Use a toothpick or pipe cleaner to remove buildup in the steam vents, making sure the debris doesn't fall into the vents.
  3. Use a fine sewing needle to carefully clean the spray nozzle of mineral deposits.
  4. To flush sediment from a steam iron, pour 1/2 cup water and 1/2 cup vinegar into the water tank. Place the iron on a rack over a broiling pan and set the iron to steam until the tank runs dry. Repeat if necessary. Or follow the instructions for using a commercial iron cleaner.
Service the steam and spray mechanism:
  1. Unplug the iron.
  2. Use a fine sewing needle to unclog the steam valve assembly. Also, check the valve spring and replace it if it is broken or has lost tension.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in water and squirting the pump. Clean or replace as needed.
Clean a metal soleplate:
  1. Unplug the iron.
  2. Use a sponge and commercial soleplate cleaner or baking soda and water to remove dirt buildup on the soleplate. Rinse well with water and dry. Don't use harsh abrasives or immerse an electric iron in water.
  3. Use very fine steel wool (0000) or an emery cloth to remove scratches and burns on the soleplate, then clean the soleplate.
Sep 30, 2013 | Conair Compact Garment Steamer Iron
How to open a steam iron severin
follow this principle.God bless you
Clean an iron:
  1. Unplug the iron.
  1. Unplug the iron.
Jul 20, 2013 | Severin Steam Iron, 2500 Watt, White...
The steam button is stuck on (pushed in) but there's no steam.
follow this steps. God bless you
Clean an iron:
  1. Unplug the iron.
  1. Unplug the iron.
Nov 15, 2012 | Black & Decker Irons
Water leaking out of iron no steam I have a Hamilton Beach Steam Storm Model 14560 Lost manuel
The Use and Care Guide for the Hamilton Beach Iron can be downloaded here:
http://useandcares.hamiltonbeach.com/files/840091300.pdf
If water is leaking out of the iron:
• Do not overfill the water tank.
• If steam ironing, is Adjustable Steam Knob in a steam position that matches Temperature Control Dial steam range? Did the iron have enough time to preheat?
• If dry ironing, make sure the Adjustable Steam Knob is in the DRY IRON position.
Jun 20, 2011 | Hamilton Beach Steam Storm 14560 Iron
It is sticky and looks like glue.It looks gooey
Hello :
Here I'm going to tell you the basics of cleaning your Rowenta iron :
Things You'll Need:1:Rowenta Soleplate Cleaning Kit
2: Ironing board
3:Clean, dry cloth
4:Two cotton terry cloths, such as washcloths
Now to the cleaning :
1:Pour out any water from the iron. Turn the steam iron on to the "Cotton" setting, which is the one with three dots on the settings dial.
2:Cover an area of the ironing board with a clean, dry cloth. Fold one washcloth or other piece of cotton terry cloth in half and place it onto the cloth on the ironing board.
3:Dispense a 2-inch long daub of cleaning solution onto the terry cloth. Run the heated iron over the cloth directly on the cleaning solution. Move the steam iron in a circular motion over the cleaner on the cloth for a minute or two.
4:Remove the steam iron from the cloth. Carefully wipe any remaining cleaning solution from the soleplate using the second terry cloth.
5:Add water to the steam iron. Turn on the "Steam" or "Burst of Steam" feature. Run the iron over the clean, dry cloth on the ironing board to ensure the cleaning product is entirely gone from the soleplate.
PLEASE RATE !
Apr 20, 2010 | Rowenta DX6700 Iron
What happens if I use CLR in my steam iron? I have an expensive European style iron which is no longer producing steam. I have bought an iron descaler/cleaner and have repeated its use. I tried the...
The steam tank may not be heating because of mineral deposits in the tank. But also do this check first. Open up the tank reservoir cold, and drain all water out, (is it clean inside there when you shine flashlight in there? Rinse with clear filtered water only (low minerals).
Do not use CLR or anything agressive in there. You should have the main unit in full steam mode and the iron control also in full steam mode. Leave one tablespoon of water in the tank, put back together and let the pressure build. Put a clean towel on your ironing board and when iron is at full pressure and heat, hit the burst of steam and look at what comes out of the sole plate. If you see lots of white deposits look at the sole plate and see if the white chunks are coming out steam holes.
When using iron, run it till steam/water tanks are dry, the burst of steam is used in this case to clean the iron of all standing water. Pull the reservoir and allow to cool...once tank is cool drain it as well. Doing this several times should help purge unit of the heavy mineral deposits.
If you need parts, here is the Rowenta repair facility....
California Electric Service in Concord CA (it is the only Rowenta repair station in California) go to either of the following addresses:
their website is: http://www.californiaelectricservice.com/
or tech service: service@californiaelectricservice.com
Mar 12, 2010 | Rowenta DG-980 Iron
Won't steam
The steam irons I have see have a separate button to allow water from the reservoir to enter the steam chamber. This button latches down for steam and you unlatch it for dry. Also, there is a temperature range on the temp dial for steam.
The reservoir must have water in it for the iron to make steam. If calcium from the water has built up on the reservoir valve, it may prevent the water from entering the steam chamber. Straight white vinegar instead of water may help.
Nov 02, 2007 | Toastmaster 3302 Iron
Irons Logo
191 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
