Question about Roper RGS7648E Dryer
It only partially drys a load of clothes
The dryer ignites the burner right away then stays off for most if not the remainder of the drying cycle
    Top Expert:
  • Roper Master
  • 9,472 Answers
You have a faulty flame sensor. Here is the part to order.
Posted on Dec 02, 2012
maklean
  • 1665 Answers
SOURCE: Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
http://www.repairclinic.com/0088_8_1.asp
Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Type in model No at search tab to find parts availability
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
Posted on Jul 15, 2008
jsrock516
  • 5911 Answers
SOURCE: roper clothes dryer not drying clothes
Please take a look at the following link. In particular, the first major paragraph where it discusses proper ventilation:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
I know the link is for a dryer that no longer heats, but if a dryer is left in a condition where it is starved for air, the heating circuits will actually over-heat and eventually fail. You need to ask yourself when was the last time you inspected or cleaned the dryer exhaust ventilation. If you can't remember, or if you've never cleaned anything before, it may be a good time to do so. Most dryer heat related problems are caused by poor ventilation and lack of cleaning. I recommend that you clean the dryer ducting twice a year. That's once in the spring, and once again in the fall. It is also important to note that the SHORTER and STRAIGHTER the exhaust vent line is, the BETTER. The more bends and kinks that you put in the dryer exhaust, the more resistance you create for the dyrer blower, and the more potential choke points you create where lint can accumulate and clog. Not to mention, this can also cause a fire hazard and/or a habitat for rodents.
Follow the recommended advice and try drying a load of clothes with the vent hose removed, first. If your clothes dry faster like they should, you may have an exhaust clog somewhere. If your clothes still aren't drying correctly, inspect the interior blower fan housing for obstructions. This is all explained in the link provided.
If you attempt these preliminary measures and still have problems, please let me know. I hope you find this information helpful.
Posted on Sep 04, 2008
  • 10 Answers
The vent may be stopped up, or the vent hose crimped so the air cannot escape, you can check the air flow at the vent on the outside of the house while the dryer is running.
try cleaning the vent and the lint screen with a vacuum cleaner, you may need to replace the vent hose, this should solve the problem
Posted on Jun 02, 2009
SOURCE: dryer gets hot but wont dry clothes
should the top of my 10 year old Maytag dryer feel almost hot to the touch
Posted on Oct 11, 2009
  • 121 Answers
SOURCE: Roper dryer stopped working during cycle REX6634RQO
replace your t-fuse again but also chekc to see if the vent going outside is restricted. if hte vent is smashed or clogged the heat has nowhere to go. i would say that is your issue. clean your vent before you change he t-fuse.
Posted on Oct 20, 2009
Takes 4 to 5 dryer cycles to dry one load
usually thats a blocked vent to the outside..Its wet on the inside because its holding the condensation from the clothes .also check blower wheel ..One sure way is take your vent off the back of the dryer and dry a load if it drys in a normal time you know your out going vent is plugged
Feb 18, 2015 | GE Dryers
No lint on filter? Where is it all going? Checked exhaust vent bought a vacuum attachment and there is no lint. Twice and sometimes triple the drying time! Help!
Instructions
  1. Dryer Does Not Run
    • 1 Close the door firmly. The dryer will not operate if the door is not completely closed.
    • 2 Press the "Start" button firmly or push the knob in to start the dryer.
    • 3 Turn the dial past the "Off" position and away from "Wrinkle Prevent." The dryer will not start in the "Off" or "Wrinkle Prevent" position.
    Long Drying Times
    • 4 Remove the lint screen. Clean it and replace it.
    • 5 Check the temperature of the room. The dryer will not operate properly in temperatures below 45 degrees Fahrenheit.
    • 6 Inspect the area around the dryer. It requires at least 1-inch clearance on the front and sides of the dryer. A 5-inch clearance is needed on the back of the dryer. Move the dryer, if needed.
    • 7 Separate large loads and do not use an air dry cycle.
    Lint, Stains and Wrinkles
    • 8 Clean the lint screen before drying each load of clothes to prevent lint buildup on clothing.
    • 9 Add fabric softener sheets before starting a drying cycle. If the sheets are added after the load has partially dried, they can leave stains on the clothing.
    • 10 Dry small loads and remove clothing as soon as the drying cycle completes to prevent wrinkling.
    Dryer is Noisy
    • 11 Check the inside of the dryer for loose change, buttons or other items. Empty the pockets on clothing before drying.
    • 12 Separate items that are knotted together and restart the load. Knotted or balled up clothing will bounce and make the dryer vibrate.
    • 13 Level the dryer. Turn the leveling legs on the front of the dryer clockwise or counter-clockwise until the dryer is level. Turning the legs clockwise will lower the dryer. Turning the legs counter-clockwise will raise the dryer.
Jan 15, 2013 | Admiral Dryers
If clothes are wet then no heat. if clothes kinda dry then heat at first then no heat
Hello Friend, If the burner on your gas dryer is igniting the first few times producing heat in the early part of the drying cycle and then Doesn't ignite the remainder of your drying cycle, It's pretty safe to say that you need to replace the valve coils. Here's general information pertaining to the replacement of your valve coils: Your problem is very simple to fix. You're dryer needs a gas valve coil kit. To replace coils just remove front of dryer body and look below drum you will see the gas valve. The valve coils are located on top of valve (two little round black cylinders). It's simple, just remove the two screws from the little metal bracket that holds them down, unplug the wires from them and just lift them straight up off of the valve. Take notice that one has 3 wires and one has 2 wires. Just replace with new coils and plug wires back in and re-fasten metal bracket. Your dryer will run like new. Happy to help, Tim. And please don't forget to give me your rating for my help. Thanks!
Jun 27, 2009 | Kenmore Dryers
It takes usually 3 complete cycles to dry an average load of clothes.
try taking the vent hose off your dryer and running it through a cycle with it off...if it drys ok then you have a clog somewhere in your venting.
Jun 22, 2009 | Roper REX5635E Dryer
Dryer does not dry clothes. Flame does not stay on
run dryer for 10 minutes then remove vent hose see if start working mean flame on for while, if it is then you need to clean your vent system.
May 01, 2017 | Maytag Atlantis MDG7400AW Gas Dryer
Drying on-and-off
I would replace the coils on the burner valve assy.
Mar 17, 2009 | Whirlpool Dryers
Machine drys fine on timed cycles but shuts off before clothes are dry on automatic cycle.
First try cleaning the moisture sensors with rubbing alcohol, these are two silver colored strips located inside the drier just below the lint cleanout
Oct 31, 2008 | Whirlpool GEW9250 Electric Dryer
Dryer heats slowly
When dryer heats too slow, that means that there is a problem either with the heating element, the thermostat, or the vent.
See the following suggeations from Repairclinic:
Drying is too slow It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Vent
Heating element
Internal ductwork
Cycling thermostat
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
Oct 04, 2008 | Whirlpool Dryers
Most common cause of this is a clogged venting going to the outside to test this remove the vent from the back of the dryer and run a load if it drys ok them you know you have a venting issue and will need to be cleaned out if not plz repost and we can look deeper into it
Jul 15, 2008 | Roper REX4634KQ Electric Dryer
Kenmore dryer isn't working
was the previos dryer taking a long time to dry??? Make sure a high velocity of air comes from the dryer with the vent unhooked there may be a internal restriction causing the long drying times, if there is no restriction then it is in the home vent line. To verify that it is a vent issue unhook the vent and do a load of clothes if it drys in 40-60min it is the vent.
Sep 29, 2007 | Zanussi TC180W Electric Portable Dryer
Dryers Logo
251 people viewed this question
Top Roper Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Roper Dryer Expert? Answer questions, earn points and help others
