Question about Samsung WF218ANW 4.0 cu. ft. High Efficiency Front Load Washer
How do you remove the cycle selector knob on wf218anw washer
Selector knob does not change cycles
2 Suggested Answers
SOURCE: My Samsung WF218ANW/XAA front load washer will not
lefever352, I am currently trying to solve this same issue on the identical model. I removed , cleaned, and re-assembled all the water tubes and the entire pump assembly. The pump works but for some reason it is not priming into the drain tube. The pump assembly appears to have a diaphram over the outlet opening and it it looks like this might be the problem. I am still hunting the solution, BUT so far the above actions have to resolve our issue. I hope perhaps Fixya can help.
Posted on Jan 22, 2011
I have a Kenmore washer #11026002010. I am having problems with the water overfilling and not progressing to the next cycle. Would you have info on the fault codes and also the recalibration procedure
Does it sound like it wants to spin? If so more than likely the motor coupler broke causing your washer to not spin. It is one of the most common parts that fail.
Anyhow Sears is the best bet for your answers they even list all the steps needed to trouble shoot.
Model 11026002010 Kenmore Automatic washer Repair
This one is from the link above and credit to:
Natasha12,November 17, 2014
Thank you for choosing Searspartsdirect.com and being a valued member. I can certainly assist you in locating the diagnostics for your washer.
ACTIVATING THE SERVICE
DIAGNOSTIC TEST MODES
1. Be sure the washer is in standby mode
(plugged in with all indicators off).
2. Perform the following sequence of
movement using the cycle selector knob.
NOTE: AFTER RESET, sequence "a" through
"e" must be completed within 6 seconds.
RESET - Rotate cycle selector knob
counterclockwise one or more clicks
to clear sequence.
a. Rotate cycle selector knob clockwise
one click and wait ½ second.
b. Rotate cycle selector knob clockwise
c. Rotate cycle selector knob clockwise
d. Rotate cycle selector knob
counterclockwise one click and
wait ½ second.
e. Rotate cycle selector knob
clockwise one click.
?Successful activation of Diagnostic Test
Modes will be indicated by all status
LEDs (except for Lid Locked) flashing
ON and OFF in half-second intervals.
NOTE: LED names may vary between
makes and models.
FAULT CODE DISPLAY MODE (Pgs 6-7)
To access fault/error codes, perform steps 1
and 2 of Activating the Service Diagnostic Test
Modes. Turn the cycle selector knob until the
status LEDs or display correspond as follows:
?"Done" LED On, "01" Displayed on 7-segment
01
Sensing Soak Wash Rinse Spin Done
Press the START button to enter Fault Code
Display Mode. The status LEDs will flash
ON and OFF and "cl" is displayed on the
7-segment (if display exists).
1. To view last 4 fault codes:
? Turn cycle selector knob clockwise to view
fault codes in the order of most recent to
oldest. (Refer to Fault/Error Code charts
on pages 6 & 7.)
NOTE: A fault/error code will be removed
from memory if it does not reoccur after
10 consecutive wash cycles.
2. To clear fault codes:
? Turn cycle selector knob until the status
LEDs flash ON and OFF or "cl" is displayed
on 7-segment. (See figure 2, page 2).
?Press and hold START button for 3
seconds to clear all fault codes. Press
POWER to exit Service Diagnostic Mode.
You can also visit searpartsdirect.com for parts, diagrams, and repair information.
If you do not feel confident repairing this problem yourself, then you can have it repaired at your home by a Sears technician. Here is a link for the website: Sears Home Services .
Thank you for your question. Have a great day.
Jan 10, 2015 | Kenmore Washing Machines
I have a whirlpool cabrio washer for a while now here and there i was pulling out soaking wet clothes.and ofcourse my warranty ran out yesterday and now it will not start any cycle all its does is sense...
This particular washer has a test that we can run to see any errors. This can be confusing on this model.
I am including a document below that will describe how to view the old error codes. Use the section that starts with Activating the service diagnostic modes. You can start with the cycle selector knob at any position.
  1. Be sure the washer is in standby mode (plugged in with all indicators off).
  2. Perform the following sequence of movement using the cycle selector knob. NOTE: After reset, sequence "a" through "e" must be completed within 6 seconds. When it tells you to rotate the cycle selector knob, it means 1 click, not a full turn. Once you have completed the cycle knob turns reset and "a" through "e", turn the cycle selector 1 click clockwise from the position it is already in. This is the fault code display mode. Then press the start button. Each time you turn the cycle selector knob 1 click clockwise after pressing start will show you an error code. Note: this washer stores 4 codes if any. The error codes on this washer are displayed in this format: F5 E3, F7 E1, etc. There is an error code chart in the image below.
If there are no error codes stored, I recommend that you start from the beginning (step 1 above) and then run the Automatic test mode. If this unit detects a problem, it will display the error at the end of this test.
Here is a list for the errors.
Post back your results.
Sep 14, 2013 | Whirlpool WTW8200YW 4.6 cu. ft. Cabrio...
My cabrio washing machine want start
start with Activating the service diagnostic modes. You can start with the cycle selector knob at any position.
Post the results back to me.
Nov 30, 2012 | Washing Machines
My washer test runs great I hear every thing working correctly but when I do laundry it doesn't spin. How can I fix this issue. I am getting an error code f7 e1
I know how frustrating it can be when appliances do not function properly.
I hope this is helpful. Post back your results.
Click here for image
Nov 12, 2012 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Washer will not start
  2. Perform the following sequence of movement using the cycle selector knob. NOTE: After reset, sequence "a" through "e" must be completed within 6 seconds. When it tells you to rotate the cycle selector knob, it means 1 click, not a full turn. Once you have completed the cycle knob turns reset and "a" through "e", turn the cycle selector 1 click clockwise from the position it is already in. This is the fault code display mode. Then press the start button. Each time you turn the cycle selector knob 1 click clockwise after pressing start will show you an error code. Note: this washer stores 4 codes if any. The error codes on this washer are displayed in this format: F5 E3, F7 E1, etc...
If there are no error codes stored, you will need to replace the control board. Here is a link to the part.
Oct 17, 2012 | Whirlpool Washing Machines
WHDSR209DWW on/off button will not engage to spin the cycle selector dial
The cycle selector is not engaged onto the timer shaft. Need to remove the on/off knob by removing the plastic "U" clip. Remove the cycle selctor knob and check that the steel spring clip on the selector is fully seated. Re-install the cycle selector onto the timer shaft aligning the selector key with the with tthe notch on the timer shaft. Re-install the on/off knob.
The cycle selector and on/off combination is a poor design. Users press the on/off knob in and turn clockwise to set the wash cycle. If you're not gentle this action wears the teeth on the timer shaft and the user has to press harder and harder to set the wash cycle. This pressing causes the cycle selector to be pushed off the timer shaft and you can no longer operate the machine.
VERY IMPORTANT:
Stop using the on/off knob to set the wash cycle. Press on the cycle selector to set the wash cycle. Use the on/off knob only for starting or stopping the machine. Don't press or pull too hard on the on/off knob or you will wind up pushing the cycle selector off the timer shaft.
Jan 12, 2010 | General Electric WHDSR209DWW Top Load...
The laundry is still wet after a normal wash cycle, because the machine doesn't get into the "high speed spin" (this has happened several times . . . have only had it 2 weeks). It has happened on full...
Since it can spin by selector then there is no problem with the spinning mechanism. Need to call warranty service to address the electronic sensor control.
Jan 09, 2010 | Samsung WF218ANW 4.0 cu. ft. High...
Washer stopped spinning mid cycle does drain and fill whats the problem
Check to see if you advance the selector knob to the spin cycle. If it does spin at this time, then you have a problem with the selector knob. If it does not then you have a problem in the motor area.
Nov 28, 2009 | Whirlpool LXR5432KQ Top Load Washer
How to remove the washer cycle selection/start-stop knob on a Whilpool Heavy Duty Thin Twin stacked washer dryer
I believe the selector knob on a Whirpool just has to be turned counter-clockwise with the selector pushed in. It will spin off the shaft and then the outer indicator dial will pull off. The shaft also has a keyed slot that will only allow the dial to be removed and installed one way, so there should be no question as to how it goes back on.
Was there a reason as to why you are removing the washer selector knob? If this is a simple matter of replacing a broken water temperature selector, you shouldn't have to remove any of the control knobs to gain access to the selector. The entire front panel comes off by removing the screws holding it in place. That way you can access the broken selector from behind the front panel much easier. Just remove the panel right above the washer top (under the dryer) and it should expose the front panel mounting screws. Remove these screws and the front panel comes off. Just make sure the unit is unplugged before you begin. I hope this helps you. Let me know if you need further assistance.
Apr 22, 2008 | Whirlpool LTE6234D Top Load Stacked...
Samsung WF218ANW 4.0 cu. ft. High Efficiency Front Load Washer Logo
81 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
