Question about Radio Communications
Cannot pick up any channels on my midland 278 cb
When wired up, if i hit the scan button, it just keeps scanning and wont pick up any channels. It is tuned to the UK and was working in my last lorry. Also if i turn the squeltch knob, i get no sound through the speakers.
    Sergeant:
  • 193 Answers
I would check the coax connection from radio to antenna.Assuming the radio is still working as it did in the last install. Take an ohm meter and see if ground at radio end is ground at antenna end. same with the signal wire (center conductor).
Posted on Dec 06, 2012
Communicomm
  • 90 Answers
SOURCE: wiring a midland 78/999 cb radio microphone
Pin 1 = white
Pin 2 = shield
Pin 3 = black
Pin 4 = red
Posted on Sep 29, 2008
One Wire
  • 126 Answers
SOURCE: converting a different brand of mic for a midland CB
This should be a typical Midland pinout. If you are using a generic 4 pin mic that is wired to cobra/Uniden, all you have to do is switch pin 1 & 2, then 3 & 4.
Not all mics are color coded the same with their wires.
Posted on Oct 06, 2008
  • 181 Answers
SOURCE: THE WIRES IN MY DAD'S OLD MIDLAND 77-106 MIC. HAVE BROKEN LOOSE
first check out the front for a circle with 27/81 this is the 40 channel (FM). if you cant find the circle it is (AM) and not used as much in the uk. if it means alot to you and your dad post it to cb communications shildon DL4 1HE and i will will see want i can do.
Posted on Jul 25, 2009
SOURCE: UNIDEN UH-011 UHF CB RADIO
i have just printed off a hard copy of this manual it was on Http//.www.uniden.com.au/ RESOUCES main/pdf/uh011.pdf If that isnt helpfull i could post it out to you.
Posted on Aug 09, 2009
  • 67 Answers
SOURCE: Midland alan 42 multi CB Radio
The user manual can be found in PDF form here: http://www.alan-uk.com/cb/manuals/42%20multi%20manual.pdf
Posted on Feb 27, 2010
Why wont my midland cb change channels
make sure the channel 9/19 switch is off / set to normal
Jun 09, 2014 | Midland 4001 40-Channels Base CB Radio
How do you program a Regency Programmable Scanner R1070?
Regency R1070 Frequencies for people with no manual
These are the ranges it supports.
30-50 Mhz
144-174 Mhz
440-512 Mhz
To make it scan, first set the range by pressing Manual and then Search. It will ask for the LOwer end and the UPper end of the range. Enter them, press Scan and then Search, and it will start scanning. When it locks and you want to keep going, hit Search again. You can press Delay to stop at a channel temporarily. To save a frequency in memory, hit Manual and pick a number, then type it out and hit Enter. When you have a few channels saved and you want to check up on each of them, Scan scans through memory. The Lock button is to skip a particular channel while scanning.
That's pretty much the whole manual right there.
Jan 30, 2012 | Radio Communications
Just installed midland 1001z. When powered up, it sequentially flashes the channels (1,2,3,...etc.) over and over, but never stops so I can't tune it to a station. The exception is that when I flip the ch....
Well the CB you have should not cycle through channels like that for sure. It is not a progressive scan. Try messing with the channel 9/normal switch again. In rare occasions that switch will **** to the side just a tad. there is a PCB board inside that is responsible for the channels responding to the channel as the channel knob is turned. This board could be going haywire. If fooling with that switch does not take care of the issue then I would contact the person you got the Midland from immediately and have them get you one that works properly.
Regards, Tony
Apr 25, 2011 | Midland 1001Z 40-Channels Base CB Radio
Mobile cb radio keeps changing channels
If you have a scan button on the microphone, it may be stuck in the scan mode. It also ha could also be a wire shorted inside of the microphone plug.
Apr 12, 2010 | Radio Shack Radio Communications
CAN I GET MY CB TO SCAN THE 40 CHANNELS?
If it is not factory with the feature, the answer is no.
Apr 08, 2010 | Midland 77-099 CB Radio
Nautico 1 keeps going to channel "1a"
Found out it was a low battery. We had charged it for several hours, but it was apparently low. It is supposed to show the low battery symbol, but it never did. We put it new AA batteries instead of the power pack and it worked just fine. Thanks
Jan 25, 2009 | Midland 79-290 120-Channels Base CB Radio
I have a radio shack pro 96 digital trucking scanner.the other day we finally put up my outside antenna for it.it worked fine all through xmas and new years.the other day turned it on and it would not pick...
The very part of your scanner that makes it a scanner is inop. YOU can find it but IT won't scan. Back to radio shack for warranty before they change their mind.
Jan 09, 2009 | Computers & Internet
Converting a different brand of mic for a midland CB
Oct 06, 2008 | Midland 1001Z 40-Channels Base CB Radio
Question about setting up a scan
When you get to CB or whatever bank you want to search you must press the E/YES and then it should search. Also check your squelch. Hope this helps you out.
Sep 29, 2007 | Uniden BC246T Handheld Scanner
Radio Communications Logo
48 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
