Question about Acer Aspire M1641-U1521A PC Desktop
Black screen after Vista Update
Updated Vista with SP2 and now computer comes on with fan running but only a black screen. It does not boot. No recovery CD available.
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 55 Answers
Try hitting the f8 key repeatedly when you turn own computer and choose safe mode then do a system restore
Posted on Dec 07, 2012
venexcsd
  • 1185 Answers
SOURCE: Bios update failed *flash*
You are in deep trouble
A problem with refreshing the Bios is that you can corrupt the old one and then the new one does not load leaving you stuck in limbo land
I would contact Acer support and hope that they offer a pre-programmed Bios chip to replace your corrupt one.
Posted on Jul 04, 2009
  • 1019 Answers
SOURCE: Acer Aspire T690 will not post. When powered on no video
You need to remove The Side-Panel. ( Power Lead out )
locate A small round Button Cell Battery.
As big as a 1p or a Cent Piece. ( Usually silver )
carefully prise the Battery Out For Between 10-15 Seconds, And Replace it. replace the power cable. switch on the computer, the bios has now been reset to it,s factory default settings.
if you are prompted to set date/time enter bios ( F2-del Or esc ) dependant On Bios request.
This Should cure your Problems.
Mike @ Compurepair.
Posted on Oct 16, 2009
lock123
  • 6831 Answers
SOURCE: After finally getting my Acer Aspire M5641 PC to
Hello
Well, if the computer does not even boot from the recovery disc, i would suggest that you take out your drive and backup the files you want to keep and format the drive. Install windows on the clean drive and it should work perfectly again. Always remember to keep your virus protector updated. Hope this can help.
Best regards
Andrea
Posted on Nov 04, 2009
SOURCE: Acer Aspire AM1640-U1401A has black screen-@ boot attempt.
Had this issue with two Acers of similar make. Replacing the Motherboard resolved the issue on both.
Posted on Mar 11, 2010
  • 644 Answers
SOURCE: when turning on my acer
Ensure that you havent got a cd in the cd rom then reboot, press F2 or Delete to enter the bios and look for boot options, set the primary boot to your harddrive press F10 and press y to save and exit the bios, Press F11 and set that to boot from harddrive and let the computer boot, if it still dosent boot to windows then the hdd has become faulty, or has been wiped of the operating system and windows will need to be reinstalled.
Posted on Aug 21, 2010
How do i fix the black screen of ***** on my windows vista?
The problem is not the fix, the problem is finding out which problem of many possibilities is causing the the black screen.
This requires some troubleshooting.
I assume you are using a PC.
The first step is to turn on the monitor first.
Make sure the power on indicator LED on the monitor comes on.
Then boot the PC. Make sure the CPU fan comes on inside the PC.
(If you are running a laptop and the screen is always black, it is usually the flexible cable joining the screen to the main body has broken. A hardware problem)
Does anything show up on the screen?
If no, check the CPU cooler inside the PC.
If it is plugged up with dust and lint, you may have a burned out CPU that will have to be replaced. (A lack of cooling air causes the CPU to overheat and fail when the safety does not work. A common problem.)
If yes, get a Linux boot CDROM/DVD, boot on the Linux CDROM/DVD, and follow the instructions to run CLAM antivirus under Linux.
When the screen goes black during boot, and stays black, the problem is usually a "Root Kit" virus.
You can not remove these viruses with a normal Windows antivirus program. They are too deeply embedded in the system.
This is the start of the troubleshooting procedure.
You really need somebody "on-site" to troubleshoot a problem that is this complex.
Jan 24, 2016 | Microsoft Windows Vista Ultimate Edition
My laptop Lenovo g400.when I turn on my laptop its functioning but after 3 hours or less iturn off my laptop but when I I turn on again there is no screen display its all black but the power led is and...
Restart your computer and then press and hold F8 keys until you get Advanced Options menu screen.Use the arrow key to highlight Safe Mode, and then press Enter, your computer will boot automatically to safe mode.
If you able to start in the safe mode then Scan your computer for viruses. Some viruses can cause a black Screen , especially ones that infect the master boot record (MBR) or boot sector.
Update drivers for your hardware. black Screens are hardware or driver related so updated drivers could fix the cause of the STOP error.
Return BIOS settings to their default levels. An overclocked or misconfigured BIOS can cause all sorts of random issues, including black screen.
If it doesn't helps you then simply get the system utility program like PC Fresher that will fix windows errors that cause of black screen screen
Oct 09, 2013 | Lenovo 3000 Computers & Internet
Black screen
If it didn't helps you then simply get the system utility program like PC Fresher that will fix windows errors that cause of black screen screen
Sep 16, 2013 | Dell Latitude E5500 Laptop
Dell latitude e6400 wont boot has black screen
- Update drivers for your hardware. black Screens are hardware or driver related so updated drivers could fix the cause of the STOP error.
- Check for registry issues
Sep 16, 2013 | Dell Optiplex 755 Ultra Small Form Factor...
Dc7800
What is the error message? The CPUs will not overclock on there own, that requires configuration. Some components when not installed properly with cause the computer to boot to a black screen and the fan to speed up dramatically. I've seen memory sticks and display port cables cause this. Check all your hardware and make sure everything is seated properly.
Jul 07, 2013 | Computers & Internet
Vista hangs on restart at end of sp2 upgrade
Take advantage of Microsofts offer to go to Windows 7. You will solve this one problem now only to encounter more later.
Jan 09, 2010 | Lenovo ThinkPad T500
After installing Vista SP2 update computer wont reboot from HDD or CD w/ vista CD
ok boot the computer and as soon as you see the black screen hit f1
or delete to enter bios go to boot menu and configure the cd-rom to be your first boot option. you can also hit f12 when you first see the black screen to enter boot menu. choose to boot from cd .
ok now install the disk and choose repair system .
Nov 13, 2009 | Dell Dimension E521 AMD Athlon 64 X2...
HP 550 will not get to the log in stage
This is a known issue with Vista. Microsoft has not documented a solution but SP2 for Vista addresses this issue.
You can try running chkdisk from the repair console (insert Vista installation DVD and select repair).
If you have backup CDs or DVDs, try to restore your system.
I nothing helps, you will have to manually back-up your data and reinstall Windows.
To back-up your data you might want to remove the hard disk and connectit to another working PC as a secondary hard disk. Then simply boot up,copy your data and plug the hard disk back in.
You can download theVista SP2 from here. Also download and install SP1 before installing SP2.
Thank you.
Nov 04, 2009 | HP Business Notebook 550
Re-installed XP Pro + SP2 + SP3 - but have black screen
reinstall xp and dont install sp2 go to microsoft update and let it install sp3 for you
Sep 23, 2009 | Dell Latitude D600 Notebook
Acer Aspire M1641-U1521A  PC Desktop Logo
76 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
