Power cable won't stay on to charge my laptop
My power cord won't recharge my laptop
    Novelist:
    Champion:
  • 233 Answers
You need to get the DC Power Jack Either Repaired or replaced...this is the "female" port where your AC Power cord plugs into.. To Repair the current DC Jack...First you'll need to look closely at the Positive posts to see that they are not broken.. If visibally ok.. then you can look at the Solder Connections.. they will need to first be Desoldered.. Cleaned, then Resoldered back in place.
Posted on Dec 04, 2012
Acer aspire 5920 power failure
POWER SUPPLY & BATTERY PROBLEM
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods. When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Nov 04, 2012 | Computers & Internet
No charging battery
Nov 01, 2012 | Computers & Internet
Toshiba satellite l305d-s5934 Won't charge battery dont power On
Oct 25, 2012 | Toshiba Satellite L305D-S5934 Notebook
My hp presario cq60-615dx wont power on
Oct 02, 2012 | Computers & Internet
What are the solutions for hp netbook 1000 that stopped charging?
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Sep 15, 2012 | HP Mini 1000 Netbook
Rdrhow to find recharge componets on a215-s4807 motherboard?
Aug 14, 2012 | Toshiba Computers & Internet
Battery won't stay charged
Bring the power cord/charger to a pc shop and have them test it. It might need to be replaced. Otherwise you need to replace the battery.
Jul 21, 2012 | Acer Aspire 55155879 Laptop Charger...
Laptop battery light won't stay on
The battery might be dead. Batteries only have a useful life and after that they have to be replaced.
Does your laptop work ok off the AC Adapter Power Cord? If so, your battery is dead and your power cord is good. If the laptop does not work off the Power Cord then either your Power Cord is bad or the DC Power Jack where the power cord plugs into the laptop is bad. In either case a good battery will not charge if the power cord or the DC Jack is bad.
Check your DC Power Jack which is where the power cord plugs into the compute. Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
Jun 03, 2012 | Toshiba Satellite Computers & Internet
How to tell if a105-s4074 satellite battery is bad
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Apr 28, 2012 | Toshiba Satellite A105-S4074 Notebook
Agptek replacement battery not working
Nov 20, 2011 | Toshiba Satellite M115-S1061 Notebook
Computers & Internet Logo
67 people viewed this question
David Payne
David Payne
