Question about JVC AV-27432 27" TV
Jvc has no sound model AV-27765
Had hooked up the tv to rogers cable no sound and also straight to the dvd player just no sound
  • 57 Answers
Check the speaker of the tv set if is good, if no you need to replacei it. or check the parts like resistor or capsistor if has a 12volts supply,last option the audio output need to replace it.
Posted on Jan 11, 2009
I have a JVC DVD Player & VCR Model HR-XVC27U. It is hooked up to a Panasonic TV CT-32SL14J. I have Cable. With the JVC, I have lost any audio. If I record a VHS, I get picture, no audio. If I...
Shifting a heavy item, or anything really, can cause damage to either the cable or the port the cable is plugged into very easily.
I recommend replacing the audio cable, or trying an alternate audio output (you may be able to choose between RCA-style stereo audio output, digital PCM and digital optical.)
Similarly, the dvd player may be setup to output audio in a format that isn't matching what your AV receiver is expecting - again a variation of either stereo, digital rca or digital optical.
I hope that helps.
Jul 18, 2010 | JVC HR-XVC27U DVD Player/VCR
I have an lg lcd mod#lc427d hdtv how do i hook up an rca rt2280 system to it. i have a dvd player hooked up to tv now using hdmi cables, rca av reciever does not have them...
You can check your dvd player for a coaxial or an optical sound output, then you can plug it directly to your receiver. Those two are the best options after HDMI. Another option is A/V RCA type cable, you´ll need 3 stereo A/V wires, in order to connect the 6 channels. Remember to uncheck the HDMI sound output option on the DVD menu.
Nov 14, 2009 | RCA RT2280 System
I HAVE A MAGNAVOX TV MODEL 255102-OODD, A MOTOROLLA (VERIZON) SET TOP BOX MODEL QIP2400/1006 AND A JVC DVD MODEL DR-MV150BJ. I HAVE TRIED ALL THE HOOK-UPS SUGGESTED BY JVC AND STILL CONNOT GET A PICTURE. ...
ok, The issue will be in the sequence you have things connected. The connections sequence is going to be controlled by what connections are available. I assume the Set Top controller is connection to your Antennea connection on the TV. Your TV should be on channel 3 or 4. The next step depends on what type of connectors you are using for the JVC DVD. I have an Antennea output on mine so I connected them in series. If you don't have an Antennea output from teh DVD player you will need to connect the DVD using Audio/Video cables which means you will need to connect to the TV alternate Source connector and to watch DVD's you will need to change to that source. Much like you would switch between regular TV and VCR tape on a VCR player connected to the Antennea connector.
Sep 23, 2009 | Televison & Video
Mintek DVD-1600 Setup to cable box/tv
A dvd player that doesn't record hooks straight to the television, not the cable box. Tv's typically have av jacks. If yours doesn't, you will need to buy an rf modulator. If your tv has the jacks, U will need to use your tv remote and hit tv video or input or source on that tv remote to switch between input and tv modes.
May 03, 2009 | Mintek DVD-1600 DVD Player
How do I hook up my dvd player to my JVC model AV-56wp74?
just run your av leads into your AV inputs on tv,then switch tv to AV1 or AV2
May 01, 2009 | JVC Televison & Video
Technically challenged...need DVD to show on TV screen
hey 1st of all you gotta make sure that your son made tha right connections with the av cable (this is the cable with three different coloured pins) from your DVD to your tv. if this doesnt solve your problem then make sure you are using the correct av channel on your tv set that will allow you 2 play your DVD player because sometimes you cant play your DVD on thhe same av cannel you watch normal tv
Jan 01, 2009 | Pioneer DVR-520H DVD Recorder
Parental lock
i have the same exact problem what i figured out is that i cant watch cable on it but when i hook a vcr to it i can watch movies. but when i hook my dvd player to it the block comes back on. so i hooked my playstation 2 to my vcr and hooked my vcr to the tv and i can watch dvd's that way. thats all i have sorry..
Oct 20, 2008 | JVC AV-27820 27" TV
Help
What video out put you connected between JVC player and TV ?
Look at back of your JVC player for Video out (yellow color) pin, hook RCA cable there and plug it to Input-1 or 2 in TV.
Now select AV 1 or 2 (what ever you hooked) in TV by remote and hopefully picture will in TV.
need further help, let me know model number of your TV.
Oct 11, 2008 | JVC TH-M45 System
JVC AV-27432 27" TV Logo
110 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
