HP DV6700 Freezes.
Will load windows but freezes when you run a program. Pointer moves across screen ok but no keyboard.
    Problem Solver:
  • 7 Answers
Its a common windows problem. there is a multitude of options to solve this. try start windows in safe mode and start a program. if that works go a restore point back. or reinstall windows. or get a newer version of windows. windows 7 or 8 are likely to perform better than windows xp - assuming it is windows xp you run. avoid vista like the plague
Posted on Dec 02, 2012
  • 38 Answers
SOURCE: acer 7720 will not boot
Do you want to try and see if a 'Linux LiveCD' boots? This is the way I test if the computer works. You burn this CD to a disk, and then boot off of it when you're computer starts. I will not modify anything on your computer as long as you go to 'Try Ubuntu with out installing'
http://www.ubuntu.com/getubuntu/download
Don't worry, I'm not trying to get you to install anything, just see if it boots into the 'live environment' (means you are running it off of the cd) If this works, that means that it is only your windows installation is messed up, and a reinstallation of windows should work fine with a Windows install CD NOT the recovery cd.
Posted on Jan 31, 2009
SOURCE: laptop/notebook runs on AC, but freezes with battery use
Laptop/notebook runs on AC, but freezes with DC
Posted on Feb 26, 2009
zohail
  • 1223 Answers
SOURCE: 7720 will not boot
off course it is repairable dont worry look try to install OS thru the following procedure to factory default state
Acer: When you first turn on the laptop and see the Acer logo screen, hold the ALT key and press the F10 key (you need to do this before the Acer logo disappears).
if it installs the OS ok then fine if not
pls consider changing RAM take out from beneath the laptop open the cover all screws and take out the L shaped panel then u will see the RAM in front with 2 chips one uper and one lower side try to take out both and then re fit only one in the upper slot and then try to install if hangs again , then try the 2nd chip in the first slot and repeat the procedure if it works ok only try both chips one by one if it resolves ur issue and u find the faulty one replace it with new one with sam specs
in the last case if ur system still hangs then my friend ur hard disk is giving u hard time it needs replacement
when a system boots after bios loading all that is trf from Hdisk to RAM and then OS is loaded if one have problem system will hang or freeze try these solutions and then tell me the results
pls go step by step
and pls rate me fixya if i fixed ur problem
kindly let me know abt it and tell me in detail the messages u get and the system behaviour
Posted on Mar 02, 2009
  • 14 Answers
SOURCE: My HP dv6700 freezes up after I have signed on
I would advise to bring up the task manager (right click on the Windows bar across the bottom of your screen and select task manager) then click on the Processes tab. From there you can see the percentage of the CPU being used and Memory being used. System Idle Process should be high for CPU usage, but if you have anything else that seems abnormally high, look up that process online and see if it's safe to kill it. You can also sort the CPU and Memory columns by clickingon the column at the top.
If a process is holding you up and not essential to Windows. You may want to kill the process and uninstall the program that the process belongs to.
Posted on Jun 21, 2009
  • 1121 Answers
SOURCE: Will not load past starting screen (HP logo)
maybe is hard disk problem, try boot from cd.(check for any errors dispayed)
Posted on Jul 15, 2010
Play dota
test this steps and fix it. God bless you
1. The Mouse o There are two examples of a computer freezing up. One is when a single program on the computer is frozen, while the other is when the entire system freezes up. To determine which type of problem a computer is experiencing, attempt to move the mouse on the screen. If the mouse pointer is visible and moves, the issue is with a single program. To determine which program is frozen, bring up the Windows Task Manager. This can be done by right clicking a blank area of the taskbar and selecting "Task Manager," or by pressing the keyboard shortcut "Ctrl+Alt+Delete" and selecting "Task Manager". The program or programs that are frozen will show as "Not Responding" on the Applications tab of the Task Manager. Click the frozen program and click "End Task" to close it. Visit the program's website for specific troubleshooting tips if the program continues to freeze. If the mouse pointer is stationary on the computer screen, the entire system is frozen.
Unfreezing a Frozen Computer o If the entire system freezes up, it will need to be rebooted. To do so, hold down the "Ctrl" and "Alt" keys. While holding both keys down, press the "Delete" key twice. This should shut down the system and automatically restart it. If the computer does not respond, try the keyboard shortcut once more. If it remains frozen and does not reboot, you will need to perform a hard shut down. This simply means pressing and holding down the power button until the computer completely shuts down. Once it has shut down, leave it off for a few minutes and then turn the power on once more.
Continuous Freezing o A frozen computer might be a one-time occurrence, or it could be the sign of a more serious problem. If the computer continues to freeze up, there are several items that should be checked out. The first step to take is looking at any recently installed software. Programs such as freeware or shareware often contain malware that can damage the system. Even reputable software can contain a damaged file. Uninstall recently added programs and determine if that was the cause of the computer freezing up. To uninstall a program, go to the Control Panel from the Start Menu. Select "Add/Remove Programs" in Windows XP or earlier, or "Programs and Features" in Windows Vista. In the list of installed programs, select the one to be removed and click "Uninstall." Follow any prompts and restart the computer when the process is complete. Next, update and run both the antivirus program and spyware removal program installed on the computer, or use the link provided in resources. Check the Windows website and download any updates.
System Tools Finally, you will want to check the available space on the computer's hard drive and use the built-in error checking and cleaning tools. Go to "My Computer," right click "Local Disk (C:)" and click "Properties." On the "General" tab, make sure there is sufficient free space. The "Disk Cleanup" tool will free more space by deleting unnecessary files. Click the "Disk Cleanup" button to run the tool. On the "Tools" tab there are more tools that can solve the problems causing a computer to freeze up. The Error Checking Tool finds and corrects hard disk errors and the Defragmentation tool will reorganize system files, helping the computer run better.
Jul 24, 2013 | HP Computers & Internet
Jul 15, 2010 | HP Compaq nc6220 Notebook
TWO PROBLEMS - #1 - MOUSE POINTER FREEZES, ALONG W...
You may be a victim of spyware/maleware infections. You will need to have your system cleaned. This should help resolve your issue.
I would recommend trying CCleaner first to see if this helps you. Please keep in mind this will not rid your system of everything just keep you a float and offer you a fighting chance.
Please keep me posted and updated on your issue. I am here for you and will see your issues out till resolved.
Have a great and wonderful day :)
Thank You
Please do not hesitate to contact support :)
Frank
Live-Tech
1-888-361-8511
http://www.mylive-tech.com
http://www.itsupport.co.cc
May 20, 2010 | Computers & Internet
Chrome mouse on laptop freezes, get stuck...advice
Ok..now that I have more information about your pointer problem,yes,there could be a trojan virus causing it.Best thing to do first is,using your other mouse,boot your computer up into safemade by tapping the F8 key untill you reach a black diagnostics screen.At the top of the list you will see "safemode",using the arrow keys on your keypad,move up to "safemode" and press Enter,then wait for the boot to finish.This procedure allows you to get inot windows with services and drivers only needed to help fix many problems.Sometimes there are trojans that will use certain windows services or programs you installed to run.Using safemode allows you to "get in" your computer without those programs and services running.After you get into safemode and your all booted up,see if you can use your synaptics pointing device normally,if so,then yes,there is a very good chance you have a trojan or trojans infecting your computer.If so,best thing to do,is open your virus scanner while you are in safemode and do a complete scan,to see if any virus or trojans are present and remove them,then reboot your computer and let it boot back up normally.We will see if any trojans or viruses are in your computer with this methode.Good luck.Please let me know what happens:)
Apr 12, 2010 | HP Pavilion dv1000 Notebook
My HP dv6700 freezes up after I have signed on from the password window. It works find in the Safe Mode but will freeze up after a couple of minutes sitting idol or if I try to work on any program or on...
Jun 21, 2009 | HP Pavilion dv6000z Notebook
Jerky pointer and freezes
Possible solution for that, open the mouse and CLEAN the mouse.
May 06, 2009 | Mouse Systems PC Trackball II
Hp computer freezes for a few seconds at a time after repowering then is fine then freezes. Only solution so far is restoring to an earlier date. Does anyone have a solution for these intermitent freezes?
go into msconfig or the system configuration utility and then click on the startup tab. This will show you all the programs that are running while windows is loaded. Uncheck the programs that you don't want running and then click on Apply and then click on OK and then let the computer restart. Your computer should run a bit quicker and the freeze ups should pretty much go away.
May 05, 2009 | HP Computers & Internet
Mouse freezes when i move it on desktop or a window.
hi, ok go into control panel,printers and other hardware-mouse -slow the pointer speed a notch at a time. this should help. good luck,glen
Jan 04, 2009 | Microsoft Wireless Optical Mouse
WINDOW FREEZES WHEN OPENED MESSAGE SAYS ALPS POINTER PROBLEM
my compaq laptop freezes up when not used for a few minutes and then data is lost and I have to reboot it!
Jan 04, 2009 | HP Pavilion dv5170us Notebook
Computer freezes after logging on
Hey sounds like it might be a program you have loading when the computer starts up this should hopefully fix it. Restart pc, keep press F8 when you press the restart button and select SAFE MODE when the menu appears, it will load windows but look different, click the start button and run, type in MSCONFIG then hit enter, a program will appear, untick the box that says load startup items, click apply and ok, will ask you to restart the pc, if it works ok, then let me know i will give you more instructions to get you all up and going,. All the best John
Mar 04, 2007 | HP (SHP) SRP/NC6000 32 IDS DISCRETE US HP...
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
