Question about DeLonghi Heating & Cooling
How do I set the timer on my blyss 2.5 kw oil filled radiator
Manual for bylss 2500 oil filled rad
Posted on Oct 10, 2013
5 Suggested Answers
  • 259 Answers
SOURCE: Delonghi HMW2400T oil filled radiator with no operating manual
if the timer is working when it gets to the off/on position you will hear a click so to test it just turn the timer around slowly until you hear the click much like an alarm clock that has the alarm turned off hope this helps regards Jim
Posted on Apr 14, 2009
SOURCE: set time on delonghi oil filled portable heaters and set start and finish times
It was very tough to find the actual manual online for your modle in English. However, you can call Delonghi customer support:
DeLonghi Customer Support: (800) 322-3848
Delonghi does have manuals for some models on their site. Take a look at this link, the model might be similar enough to yours to be able to get the information you need.
http://www.delonghiusa.com/search_results.cfm?sp_q=oil+filled+heater&sp_p=all&sp_f=ISO-8859-1&sp_w_control=1&sp_w=alike&sp_a=sp1003e79d&sp_c=5
Hope this was helpful.
have a great day!
Posted on Oct 29, 2008
  • 4 Answers
SOURCE: honeywell oil radiator
Press the *power button* once to start the heater on high power, continuous run. If left at this setting, the unit will run continuously on high power (1500 watts, 12.5 amps) and will not shut off until the unit is manually turned off.
Press the *power button* again, to change to low power, continuous run, (900 watts, 7.5 amps) and will not shut off until the unit is manually turned off.
Set temperature:
Press the temp/timer button until the temperature icon blinks. Use the up and down arrows to set the desired temperature.
The temperature icon will stop blinking and the current room temperature will reappear after the desired temperature is set.
The heater will turn off and on to achieve the desired temperature.
Set timer: (auto off)
Press the timer/timer button until the timer icon blinks. The hour display will appear. The auto off icon will also appear.
Use the up and down arrow buttons to set the heater operation time between 1 and 10 hours. This function will activate once the timer icon stops blinking. The heater will automatically turn off whn the times runs out.
Set timer: (auto on)
Press the temp/timer button until the timer icon blinks. The hour display will appear. The auto on icon will also appear.
Use the up and down arrow buttons to set the heater start time between 1 and 10 hours. This function will activate once the timer icon stops blinking.
The heater will automatically turn on when time expires.
Hope this helps!
Posted on Nov 16, 2007
  • 3 Answers
SOURCE: Delonghi MG15T Magnum Oil-Filled Radiator timer -timer keeps running?
I found the manual at this website:
http://safemanuals.com/user-guide-instructions-owner-manual/DELONGHI/MG15T-_M
I hope this helps.
Posted on Dec 19, 2008
Delonghi dragon oil filled heater with timer. How does the timer work, is there a way to set it so that it stays on all the time? Do not have the manual
Within the timer is a 3 point switch. Push the switch to the end closest to the arrow and away from the clock icon. It will stay on
Oct 04, 2010 | DeLonghi Dragon 3 1025 / 1025T Oil Filled...
Tip
Oil Filled Radiator Heater Leaking
<p>A very common and increasing popular source of <b>supplemental heat</b> in the last few years has been the <b>oil filled electric radiator. </b> <br /> <p>These <b>radiator heaters</b> are filled with an oil that circulates through the fins of the heater and is heated by <b>electric heating elements</b>. The result is a steady even type of heat that has a lower surface temperature then many <b>space heaters</b>, making them a great way to get <b>supplement heating</b> into a room when you have pets, small children or combustibles near by.<br /> <p><br /> <br /> <p>One of the big questions that comes up with these <b>oil filled heaters</b> is what to do if they start to leak. The answer is that if the<b> oil heater</b> starts to leak then it is no good anymore and needs to be disposed of. These<b> heaters are filled with oil</b> at the factory and then are sealed tightly. Because of this there is no need to ever <b>refill the heater with oil</b> again. The heaters are sealed with the proper oil inside for the <b>best heating efficiency. </b> <br /> <p><br /> <br /> <p>So what this means is that if you have one of these <b>oil filled radiator heaters, </b>you will never have any <b>maintenance</b> or worries about <b>adding oil to the heater</b>. But if there ever is a leak then the heater is also no good and will need to be throw out and replaced. Very few of these <b>oil filled heat units</b> ever leak, but as is always the case there are always some that do.<br /> <p><br /> <br /> <p>A word of caution about heating efficiency. Always remember that when <b>heating with electricity</b>, the <b>laws of physics</b> always apply. <b>For every 1 KW of electric you will only ever get 3415 BTU's of heat.</b><br /> <p>There is no way to get any more or any less than that, so if anyone tries to tell you that their electric heater is more efficient then the next one they are not telling the truth.<br /> <p><br /> <br /> <p><br /> <br />
on Jan 12, 2011 | Heating & Cooling
Using the timer
You should be able to get instruction here at this link with a model#
Jan 03, 2010 | DeLonghi TRD0715T Oil Filled Radiator...
How do I program my Honeywell HZ-709 radiator heater
Is there a seperate control for the timer and temp? If so, turn the temp off first and then the timer.I think they need each other for safety.
Oct 30, 2009 | Honeywell HZ-709 Oil Filled Radiator...
Apr 14, 2009 | Heating & Cooling
Actual output on settings
MODEL DELONGHI TRD0820ER 2KW OIL FILLED RADIATOR
YOU HAVE THREE SETTINGS
1. 900 WATTS
2. 1.1 KW 1,000 WATTS WHICH IS ABOUT 1.096 WATT
3. 2.0 KW 2,000 WATTS
Nov 25, 2008 | DeLonghi Dragon 3 1025 / 1025T Oil Filled...
Set time on delonghi oil filled portable heaters and set start and finish times
have a great day!
Oct 29, 2008 | DeLonghi 6707E Oil Filled Radiator Heater
I hope this helps.
Oct 13, 2008 | DeLonghi MG15T SafeHeat Oil Filled...
Delonghi TRD0715T Safe Heat Oil-Filled Radiator will not work, won't turn on its new just taken out of the box
Ditto same problem. Took it out of the box, plugged it in the electric outlet and did not turn on.
I tried atleast 5 different electric outlets to make sure nothing is wrong with the outlet. Tried changing the timer settings. No use.
Returned it to Lowe's.
Nov 17, 2007 | DeLonghi TRD0715T Oil Filled Radiator...
Timer
Timers? I thought those were like temp settings to turn off when it got to a certain temp. What numbers are on yours?
Nov 09, 2007 | DeLonghi 6707E Oil Filled Radiator Heater
Heating & Cooling Logo
1,847 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
