Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
My ge profile refrigerator door alarm keeps going off and has stopped dispensing
Techsim
  • 59 Answers
SOURCE: GE Profile Door Seal
There is a cam at the top of both doors the grab on to the fridge to hold the door s shut. There has been a problem with them breaking and not holding tight. Check the door and make sure the cam is gripping the cabinet correctly.
Posted on Nov 02, 2008
SOURCE: Water dispenser keeps freezing GE Refrigerator
If this is a newer model GE side by side refrigerator, this is not uncommon. what you can do to check to see what is going wrong, remove the toe plate at the bottom front of the unit. Under the freezer door, you will see a white plastic water line, with an inline connector about 4-5" from where the line comes out the bottom of the door. this is normally a blue push-in type connector. On this connector, you will see two white sleeves on either side, push in on this sleeve while pulling the corresponding water line section out of the connector, if you squeeze the sleeve enough, the water line will slip right out. Place a towel on the floor, make sure both ends are on top of towel. Now, breifly actuate your water dispenser trigger, see if water comes out the exposed water line. If water comes out, your entire water dispenser system is OK, but, the water line in the freezer door is frozen, in which case the only way to melt it, is to turn the unit off, open the freezer door, and blow a fan for a few hours, to melt the ice INSIDE the door. You could also buy a new door, but that is very costly.
If no water comes out the exposed water line, then either your water filter is clogged, or you have a bad water valve solenoid
Posted on Feb 15, 2010
DeBruce
  • 145 Answers
SOURCE: Can I get a replacement door for my GE Profile Refrigerator
Warners Stellian in Minneapolis can help.
For cleaning DeBruce Polish is the answer.
DeBruce Polish is Odorless, Non-Toxic and non abrasive and perfect on stainless steel, glass cook tops, polished granite marble and more. DeBruce Polish is Odorless, Non-Toxic and Non Abrasive. DeBruce is perfect on stainless steel, glass cook tops, polished granite marble and more. We buy DeBruce at debrucepolish.com.
Posted on Mar 05, 2010
  • 19 Answers
SOURCE: Ice maker in our GE profile refrigerator is not working
Ice maker Diagnostic Test:
- Remove the ice bucket
-Turn the ice maker off, wait 15 seconds than turn it back on
-Press the ice paddle three times, this will begin diagnostic test.
-PLEASE DO NOT TOUCH ICE MAKER DURING DIAGNOSTICS
-In 3 minutes you should see the rack inside turn 360 degrees
-AND the ice maker bowl should fill with water
-IF either DID NOT work, call 1-800-GE-CARES for ice maker replacement. A service call is approx $80. The $80 will be deducted from the part/labor if you choose to purchase/install parts from the service technician. If not, you will pay for the service call. Good luck.
Posted on Apr 05, 2010
SOURCE: GE Profile Refrigerator door latch broken
I need a door latch for a 1932 GE refrigerator
Posted on Apr 25, 2011
GE Profile fridge model PFE28RSHHSS. All sound has stopped working, so no open door alarm, or sounds for any other function. Other than that fridge works perfect
The speaker is located on the dispenser board. It is told when to make noise for the door alarm by the main control board. There is no test to determine which board is bad. There is nothing to measure on the comm cable between the two. Are there any other issues going on with it? Sometimes some other functions start to blink out and can point you to which board is bad.
Aug 03, 2016 | GE Refrigerators
OUR REFRIGERATOR HAS A ALARM GOING OFF WITH A ERROR CODE LC ER
this sounds like the door alarm- it occurs after the door is open (or the switch has failed) for more than 2 minutes. Remember that both doors have one and also turn on/ off the lights which may or may not be tied together.
May 04, 2014 | GE Profile Stainless Bottom-Freezer...
Water has stopped dispensing. was working fine yesterday. GE Profile ARCTICA
Could be in the door dispenser panel, Sol valve, main control board, water line freezing in freezer door? Call a qualified service company.
Ge refrigerator repair
Oct 22, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
THE ALARM WONT STOP BEEPING ON THE GE PROFILE PSC23NSWA
go to your electrical panel and kill the power to the fridge for a few minutes, or pull the plug whichever is easier. this will recycle the alarm mechanism and often solves the beeping problem
Jun 26, 2009 | GE Profile PSC25MGT 24.6 Cu. Ft. Stainless...
GE Profile Series - Side by Side Refrig - No Water Dispensing
Tubing/resevoir is coiled behind the crispers and can freeze.
Eric
Jun 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser system
the dispenser in the freezer door has a small low temp heater surrounding the dispenser compartment to keep this from happening, and also to keep condensation from building up around the dispenser. this heater may have stopped working.
May 22, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerators Logo
506 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
