We have taken front cover off and drained cleanout tube as well as checked the hose connected to cleanout tube.....just don;t know where to go from here
SOURCE: Bosch Nexxt WFMC3200UC
is the machine washing
or just filling up with water
or leaking on wash cycle
SOURCE: Whirlpool Duet Sport Washer will not drain - F-21 error
Perfect! Yes, they aer 1/4" 6pt screws. I didn't have to lift my washer, but the previous tech had put in 1 screw crooked, so that was FUN! I had cut out an opening on an old cracked tote and was able to hold all the water as long as I transferred some to a bunch of tupperware. Make sure you line up the upper mark on the white drain plug before putting back in. The tote was getting overloaded and I didn't notice the alignment marks until after having some water overflow. Just a heads-up if anyone has an emergency and HAS to get the plug back in in a hurry.
I found:
Wife's Victoria's Secret panties
2 dimes
4 pennies
some legos
a metal nut
pencil eraser
wall anchor
some legos
SOURCE: Machine quits during the spin cycle
I just did a repair on my FAV6800AAW by lubricating the needle bearings in the clutch pulley hub, the tub displacement sensor checked OK per the service manual check. I was getting dc/uc errors, washer was purchased in 7/05. I have basic mechanical skills and used a socket wrench to remove clutch pulley hub, just follow the service manual removal steps to remove clutch pulley hub. Pull the plastic cover off the clutch pulley hub and inspect the spring, clean/lube needle bearings and the Clutch hub coupler that drives spinner shaft. I used WD40 I may need to re-lube down the road with a good light grease. It took a few tries to get it to clutch pulley hub to stay on after re-install, getting the clutch pulley seated properly is the trick. I did not remove the washer tub for this fix, I believe I saw a posting where someone did. I just leaned washer back to get a better reach angle, it is a tight work area. I did not want to junk 3.5 yr old $1k machine with out a trying a fix If you want to work on this model get the service manual, I found it online and I believe you can order it in PDF format from Maytag. Good luck!
SOURCE: machine will not drain and spin
http://www.partstore.com/Part/LG+Electronics+Incorporated/LG+Electronics%2fZenith/4681EA2001D/New.aspx?ModelMfgName=LG+Electronics+Incorporated&ModelBrandName=LG+Electronics%2fZenith&ModelNumber=WM3431HW
you need a new one of these. i took mine COMPLETELY apart and found the impeller jammed. the impeller is a magnet in a sealed plastic carrier with an electro magnet around it. the electro magnet energizes , the two opposing fields spin the inner magnet ( just like a fish tank filter good idea actually!) the inner magnet on mine had a slight crack from factory causing vibration and allowing debris past the seal then jamming the impeller. to check yours drain it with the small drain tube, then get a towel or two and place around the unit at the floor.pull the large black drain cover off and after the gushing tidal wave look inside. you will see the white impeller. try turning it with w screw driver , pen or whatever. you may be able to remove and then clean / reassemble and be good as new. i only needed two tools to tear the machine apart. a Phillips screwdriver and pliers to get the clamps on the pump (2) and the clamp back on the door to drum gasket.
SOURCE: Whirlpool front loader washing machine (AWO3361) WONT DRAIN
Door locked light flashes.
After turning off at power point, then restarting unit will commence but light starts flashing again and machine stops
we ended up taking the front of machine apart... the big gasket between door and drum...once all
once all thaqt was off ...we could get the driver licence and cards out from between the drum&tu
