Question about Sony CDX-S2000 CD Player
Car Radio/CD player not working
Radio doesnt work at all, CD player works but will only play tracks in order, cant skip to next track. None of buttons are responding.
5 Suggested Answers
insanegtp
  • 112 Answers
SOURCE: radio audio working but no audio from CD. Shows cd playing but no
:) swap your blue with your blue/wht or vice versa.. (behind the radio) this WILL fix your problem..
Posted on Jan 27, 2009
  • 27 Answers
SOURCE: Sony CDX-S2210 CD Player stuck on demo mode
make sure the unit is switched off and the clock is displayed then
1 Press and hold (SEL).
The setup display appears.
2 Press (SEL) repeatedly until the
desired item appears.
3 Press the volume +/– button to select
the setting (example “ON” or “OFF”).
4 Press and hold
(SEL).
The setup is complete and the display returns
to normal play/reception mode.
Note
Displayed items will differ, depending on the source
and setting.
With the card remote commander
In step 3, to select the setting, press
< or ,.
The following items can be set (follow the page
reference for details):
“z” indicates the default settings.
*1 When the unit is turned off.
*2 When the audio output is set to “SUB.”
CLOCK-ADJ
(Clock Adjust)
(page 4)
BEEP To set “BEEP-ON” (z) or
“BEEP-OFF.”
SUB/REAR*1 To switch the audio output.
– “SUB” (z): to output to a
subwoofer.
– “REAR”: to output to a
power amplifier.
DIM (Dimmer) To change the brightness of the
display.
– “DIM-ON”: to dim the
display.
– “DIM-OFF” (z): to
deactivate the dimmer.
DEMO*1
(Demonstration)
To set “DEMO-ON” (z) or
“DEMO-OFF” (page 4).
A.SCRL
(Auto Scroll)
To scroll long displayed items
automatically when the group/
track is changed.
– “A.SCRL-ON”: to scroll.
– “A.SCRL-OFF” (z): to not
scroll.
LPF*2 (Low
Pass Filter)
To select the cut-off frequency
“78HZ,” “125HZ” or “OFF
Posted on Jan 29, 2010
  • 66 Answers
SOURCE: i cant eject my cd
There is a indent in the front of the face of the radio. Try to push it with a sharp pencil or pen. It might reset the cd part and eject button might work again. If not you may have a cd stuck in it then you can try get tweezers and pull it out or a credit card and try to straighten it out. Those were some of the techniques I used when I was an installer for 12 yrs.
Posted on Apr 07, 2010
kenw392
  • 2226 Answers
SOURCE: my sony cdx s1000, the source button does not
you may have a bad switch. if you can you can use a multimeter to check the resistance of the switches. anything less than a few megaohms, denotes a bad switch usually.
Posted on Nov 12, 2010
Every Button Switches Between Radio and CD
Reset the radio by pressing a sharp object (pin, pen, etc.) into the small reset hole on or behind the face. If it doesn't have one, disconnect the negative cable from the battery for two minutes and reconnect. If you still have this problem, the radio is bad.
Apr 18, 2014 | Panasonic CQ-DF203U CD Player
Panel lights up, plays CD, plays iPod, but none of the controls work.
switch off, remove battery and replace it after two minutes. switch on. Goodluck Mark
Dec 03, 2013 | JVC KD-HDR50 Car CD/ MP3 Player
Cd player showing error 43
Still under warranty?... check that.
Mar 24, 2009 | 2008 Hyundai Elantra
My tracks don't play in the recorded order, list I made them.....
If song tracks jump or skip then it is problem of cd player like optical laser is dirty / clogged,
and if track doesn't jump or restarts in middle of playing back then cd player is just fine,
Please check cd creator software settings.
Dec 18, 2008 | Sony CDX-MP40 CD Player
Player stuck in scan mode
Hi...
Unplug it from the wall...give it a couple minutes. Try playing a CD again (using manual controls) If that works , your remote might be the issue.
If you bought the thing new you paid good $$ for it.
It's worth having it looked at by a Pro.
Oct 22, 2007 | NAD C521 CD Player
Pin hole suggestion used but still asking for a code? (CQ-VD6503U)
i just fixed mine had the same problem just hold the the right track button firmly until it resets it self and it worked for me hope it does for u
Oct 15, 2007 | Panasonic CQ-VD6503U Car DVD Player
Kenwood MP4029 4 code reset
KENWOOD SECURITY CODE CLEAR procedure
Your radio will require one of the following procedures.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
The security is canceled and the set enters the TUNER mode!
Oct 13, 2007 | Kenwood KDC-MP228 CD Player
Jumping Tracks when using "Next" control
find the "reset" button (this button usual is very small) find it in front of the control panel, if the control panel is removable find "reset" button after removed
Feb 02, 2007 | Sony CDX-T69 6-Disc CD Changer
CD Player Acting Up
some cd players have a feature that is called intro. it plays typically the first 4 to 10 seconds of a song & goes to the next track. it does this to every song on the cd. see if intro is on your display or if it's turned on in the menu. i hope it works. good luck.
Jan 04, 2007 | Aiwa XP-R230 Personal CD Player
Sony CDX-S2000 CD Player Logo
41 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Philip Rowney
Philip Rowney
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
