Question about Whirlpool GS563LXSS - stainless Steel Gas Kitchen Range
Whirlpool gas range f5 code
No door latch, not self cleaning, did everything, cleaned oven, checked door, unplugged to reset, held down a button to clear, nothing, while i was here it beeped once, but no code when i went back in kitchen, please help,
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
F5 is a fulty display control board. Unfortunately there is nothing you can do to fix this problem but to order and replace the display control board.
Here is the board to order.
Posted on Dec 02, 2012
SOURCE: locked oven door
The Coat hanger is a great idea and it works. My oven was doing the same thing and I a female fixed it with the coat hanger. Thank you Thank you
Posted on Nov 04, 2006
  • 8 Answers
SOURCE: Door will not unlock after self clean.
It's probably the timer motor which is stuck. unplug the range!! I recently had the same problem with my whirlpool (hereinafter known as **** inc.) range. Self cleaned the oven and then the door wouldn't open. Googled up similar problems and generally found out that ****inc. had this problem on both gas and electric ranges and it costs an arm and a leg for a new board plus labor. Found out how to manually open door with coat hanger but of course still had problem with same error messages; also the oven, clock, etc wouldn't function. Took the cover off the back of the stove. UNPLUG THE STOVE On the left rear facing the back of the range he found the timer motor had stopped.He unplugged input(230 volt power) leading to the stove, then unplugged and insulated the wiring to the timer motor and the microswitch on top of it ( 4 wires). Then he took the long steel wire off of it and unlatched the oven door. Told me that this probably had something to do with the timer motor on the self cleaning cycle and that it was stuck Said this whole thing could probably be fixed with a bit of WD40. Said probably nothing wrong with board but it sure must be a moneymaker for **** inc. The service techs probably clean the timer motor, say they changed the $300 board, and go on their way. Plugged stove back up and voila! Everything worked except self cleaning function. Hope this helps someone. caution!!!! Do NOT use the self cleaning function unless you fix the timer motor. Replace it or clean it.
Posted on Nov 28, 2008
brnspncr
  • 67 Answers
SOURCE: Oven door will not release after cleaning
Try waiting until the oven is COOL, then switch the power off to it , wait 20 seconds and switch the power back on?
Posted on Jul 29, 2009
heatman101
  • 43501 Answers
SOURCE: Whirlpool Self Cleaning oven error code
Cycling the power off and then on again will sometimes reset it...often you will have to call the customer service number to get the steps to take to unlock that...
Also check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Posted on Jul 18, 2010
blueextc3221
  • 15935 Answers
SOURCE: Start button does not work on whirlppol range
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$%^&UG
Posted on Oct 01, 2010
What can I do for F5-E1 situation
Check this article as the cause could be the control board, the door lock mechanism or the Membrane Keypad!
Whirlpool Oven Common Problems and Causes
Jan 08, 2015 | Ovens
The F5 error code?
WHIRLPOOL
Range/Stove Oven Fault Codes, Common Failure
Code
Condition Check/Repair Digit Failure Code2 F1 Analog to Digital Failure Disconnect for 30 seconds - if display reappears - replace control board F1 Safety flip flop Replace board F1 Shorted keypad Replace keypad F3 Oven temperature sensor opened Replace oven temperature sensor F2 Oven temperature sensor shorted Replace oven temperature sensor F3 Oven too hot Replace oven temperature sensor F3 Clean temp too hot Replace oven temperature sensor F5 Check door/latch switch Replace switch if defective
Nov 03, 2007 | Whirlpool GBS307PR Electric Single Oven
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
on Apr 24, 2015 | Kitchen Ranges
The Oven and Range are working; however I have a F5 code on the display. Can you tell me what this means?
The F5 code means that the range door isn't latching properly (for some Whirlpool ranges). Check the latch when the oven is cool. If it is loose, tighten the screws that hold the latch. Try opening and closing the door to see if the latch is clicking shut properly. Then unplug the range for 30 seconds to a minute to reset the unit. If the error clears, you're done.
If the error persists, clean the latch area. With the oven not in use, rub the latch area with a cloth that you dunked in hot water and wrung out the excess water. Then dry with a paper towel.
If cleaning doesn't help, the latch probably needs to be replaced.
I hope this helps. Please give me the model number of your range for additional ideas. Whirlpool has the user's manuals for most of their appliances at their site. See http://www.whirlpool.com/custserv/index.jsp and the Manuals and Literature search box.
Jun 06, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
Error code E-1F5- came up on self cleaning oven before cycle was done what does this mean door wont open
1. If door latched:
  1. Disconnect power from unit.
  2. Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Replace door switch.
  4. Re-apply power.
  5. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
2. If door not latched:
  2. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals). Replace switch if defective.
4. Measure latch switch (unlatch = switch open, CAUTION - oven light contacts are closed). Replace switch if defective.
5. If corrections are made in any step, reconnect power to control. Press and hold any key for 1 minute to clear R failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
6. If failure remains, disconnect power and replace control.
Note: Applies to all F5-E... codes.
Apr 20, 2011 | Whirlpool 30" Self-Cleaning Slide-In Gas...
Whirlpool oven not working
F5 code is the door latch switch. You need to replace the switch.
Mar 15, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Clean cycle will not work.
F5 - E0 F5 - E1 and E2 -------- this all codes relates to ----- Check door/latch switch ------------ clean it and check if stiil the same problem ---- Replace switch if defective
Apr 01, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
F5 error code
f-5 is a defective door latch code.
Feb 02, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Error code E1 -F5- Broil element comes on and wont shut off
if it is a whirlpool, kitchen aid or kenmore by whirlpool you need to check the self clean latch asembly found on the rear of the unit. check the micro switches with an ohm meter. always remember to unplug the oven before you test any thing or replace parts. not sure why the broil wouldnt shut off. but the f5 error is definatly related to the door latch.
Sep 06, 2007 | Kenmore 95822 / 95824 / 95829 Electric...
Whirlpool GS563LXSS - stainless Steel Gas Kitchen Range Logo
346 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
