My siemens s14-39 has a blank display and will not start any programmes
My washing machine has a blank display and won't start on any programmes
  • 1294 Answers
SOURCE: Zanussi Washing machine
Try some WD40 on the door switch.
Posted on Jan 25, 2008
  • 96 Answers
SOURCE: Zanussi ZWF1437W washing machine - wont start
The error message "Err" usually indicates that the wash program and option are not compatible. 40 degrees and 900 rpm Spin should be o.k.. I would try another wash program with no special options and see if the problem goes away.
Posted on Mar 07, 2008
SOURCE: siemens washing machine
need a service centre in INDIA.
Posted on Jul 11, 2008
SOURCE: Wash programme will not start
Start button is bad, the button it self, not the board
Posted on Feb 28, 2009
beltronic205
  • 1474 Answers
SOURCE: what does f-5 mean when flashing at me and won,t
if water is in drum then door wont open,drop drain hose to floor level into bucket to drain manually, then check filter or pump is it running ok if not is it stuck some thing in it , hot wash is cold water inlet ok or is this due to again faulty pump ...
Posted on Jun 25, 2010
Our Siemens washer stopped spinning We have renewed brushes goes round now. But only turns one way then the other for one revolution We have tried different cycles but all the same is it the programer
First thing I would check if that timer which you are calling the programmer. If the programmer is not displaying an error code you properly have a bad timer given what your saying
Dec 19, 2015 | Siemens Washing Machines
Hi! I have a Siemens 12.52 Wash&Dry machine and the display is blank no matter what I do with it.Any suggestions?
The controller board has shorted out. When an essential diode in the circuit shunts, it is like a fuse and leaves a gap between two vital portions of the main board. When the circuit has been compromised, current is no longer traveling along the pathways and thus all normal functions are lost. Replacement is suggested.
Jan 18, 2015 | Siemens Washing Machines
How do i reset washing machine AEG 64840
You can choose the right programme for any type of laundry following the descriptions on the washing programme tables (see «Washing Programmes»).
Turn the programme selector dial to the required programme. The programme selector determines the type of washing cycle (e.g. water level, drum movement, number of rinses) and the washing temperature according to the type of laundry.
The pilot light of button 8 starts blinking.
The selector dial can be turned either clockwise or anticlockwise. Position "0" to Reset programme/ Switching OFF of the machine.
At the end of the programme the selector dial must be turned to position "0", to switch the machine off.
If you turn the programme selector dial to another programme when the machine is working, the yellow pilot light of button 8 will blink 3 times and the message Err is displayed on the display to indicate a wrong selection. The machine will not perform the new selected programme.
Dado
Jan 15, 2015 | AEG Washing Machines
Washing machine Siemens iq300 has error CL in display (status) & can't be used
This means that the door is not being closed. It might be a bad door switch.
Mar 27, 2013 | Washing Machines
How to release child lock in seimens washing machine that is wash and dry D12-52 1200 rpm
Child lock will deactivate only in the original programme that it was activated in. If you have forgotten the orginal programme, try deactivating separately in each programme.
To deactivate child lock press the clock key for 5 seconds.
Nov 07, 2010 | Siemens WFXD8400UC Front Load Washer
Siemens serie iq 1430 start problems\r\nThe display just flashes and goes dark Machine will not start
siemens serie iq 1430 start problems\r\nThe display just flashes and goes dark Machine will not start
Sep 18, 2010 | Siemens WFXD8400UC Front Load Washer
Jan 03, 2009 | Siemens WFXD8400UC Front Load Washer
Hotpoint ultima wt741
washing machine WT741 ultima all light are flashing and it won't do anything else
Nov 12, 2007 | Washing Machines
Washing Machines Logo
41 people viewed this question
Top Washing Machines Experts
