Code: 10,242,7 when I try to scan, I get a popup that says "cannot write file: code 10,242,7
  • hero May 14, 2013
    me to scan code:10,242,7
  • hero May 14, 2013
    why donnot answer my printer conon pixma mp237 ccd
Meaning of error flag code 4,252,0
Cannot write or read file. - Code : 2,252,0
and because of it stops the scanning.
The following fixed the problem on all computers:
Activate the utility "MP navigator EX"
On the left-top click on Scan/Import
Click on "specify" (i.e. the settting for scan import) and change them to 75dpi and uncheck everything (I only needed to uncheck the "unsharp mask").
Test it now and it will work.
After that wills start working even restoring the settings.
Good luck.
Jan 15, 2012 | Canon Office Equipment & Supplies
I've just finished scanning a corrupted USB and wanted to recover the data from the scanned results. Then, I was led to a page where I entered my license key (that I just paid for 5 minutes ago) and...
If you have popup blocker or antivirus or antiadware running they may be blocking the communication. Try turning them off. After that if it doesn't work, call their customer support.
Jun 29, 2011 | ParetoLogic Data Recovery
Lexmark x6180 Printer. Unable able to Scan. I turned on my printed and selected "Scan" button, located with two other buttons ("Copy" and "Fax" under the section titled...
On the printer operator panel, press Black to begin a black and white scan or Color to begin a color scan. You can rename the file only on your computer once the scanned file is displayed.
Jun 19, 2011 | Lexmark X6180 Printer
When I receive messages from Stthomasepis@aol.com with a file attached, the file will not open and I get the message in the box that opens saying, "Browser is blocking Pop-ups." This is my...
Normally when this message appears a yellow bar at the top of the browser is also present. In IE you just need to click on it and chose the option that says "allow pop-ups". In Firefox there should be an "Allow" button at the right hand side of the yellow bar.
Best of luck to you mate!
May 05, 2011 | Computers & Internet
Pop up window constantly popping up when i try to open my mail....yellow ! triangle...saying "hi"...takes 5-6 cl to get rid of it...how can i get it to stop?
Enable popup blocker. Or sounds like you have a virus...might want to install AVG Free and run a scan or do a reformat of your hard drive.
Mar 12, 2011 | Yahoo Mail
I download Youtube files with realplayers but when I want to delete them after viewing, I got a popup windows that says "Recycling files from Realplayer Downloads.... Recovering items...." and it...
try to remove files through CCLEANER
go to custom file deletion and navigate it to the files to be deleted and then hit run cleaner.
it can be found on filehippo.com
Feb 28, 2011 | Microsoft Windows 7 Ultimate for PC
Scanner won't work
The all in one solution software you used in XP doesn't work fully with Vista.
But you can still scan and copy by using Windows Photo Gallery.
1. Click on files tab at the top in Window Photo Gallery.
2. Click on import from camera or scanner.
3. Highlight your scanner icon (ie HP J5780) then click import.
4. New scan window will popup, now you can preview or scan using this basic looking Vista utility.
Hope that helps.
Chris (ziraffa)
Jan 09, 2009 | HP Officejet J5780 All-In-One InkJet...
2,149 people viewed this question
k24674
jasbo
jasbo
