Question about Kenmore 63942 Dryer
Reaching the motor for lenmore dryer
How can I reach the Kenmore dryer motor? I haver reached the vent propellor so far, should I remove it? Thanks Sam - Kind of a handyman
  • geraisy Jan 11, 2009
    Extremely helpful. Thanks
    I stil need to know how to disengage the propelor from the motor
  • 115 Answers
The motor is reached from the front you have to take your 2 screws out where your filter is on top then you have to pull the top foward and up then there is 2 screws on the front panel inside then you can take it off then reach under drum and remove belt from motor and remove drum then there is access to your motor
Posted on Jan 11, 2009
  • Steven Carter Jan 12, 2009
    put a wrench on the pulley where the belt is then go to the back and take the 4 screws out of the filter housing at the bottom and then you might be able to turn it if not most of the time you have to bust it off and get a new fan blade
How to clean a whirlpool dryer vent?
First Remove drier vent hoze and confirm it is clear and open. Get a long flexible brush. Brush out link for discharger as far as brush will reach.
Go to lent catch screen and remove it . Brush as far as one can for there.
Alternately, but messy, use compressed air, in reverse.
Jul 27, 2014 | Whirlpool Dryers
Kenmore dryer 70 series
Check the vent for clogs and kinks. Could be something in the blower wheel causing the noise and blocking the vent.
Remove the vent from the back of the dryer, unplug the dryer, and reach inside the dryer vent to check for items lodged in the blower housing.
Feb 04, 2014 | Dryers
I have a ken series 90 has a lot of build up lint and i would like to know easiest way to get to the inside to clean out thanks
In the trap itself there is a flexible brush you can buy and reach in. As for the vent pipe you will have to remove and clean and replace it once cleaned.
Sep 26, 2012 | Kenmore Dryers
My dryer stopped working. I can hear the timer, but it doesn't start
Sounds like a blown thermal fuse problem which is caused by blocked lint duct and vent or a faulty cycling thermostat. The exhaust air temperature rises when there's a blockage in the duct/vent or when the cycling thermostat fails to cycle off properly. The thermal fuse blows when the temperature reaches the fuse rating and terminates power to the motor. The dryer will not start and no dryer function works. Click on the link below for the detailed troubleshooting instructions.
Troubleshooting Whirlpool and Kenmore Dryers Not Starting
Mar 09, 2011 | Kenmore Dryers
Problem for Frigidaire FSE748GF Dryer Brown marks on clothes - What could the problem be and how do you fix it.
If the clothes have a 'burned' smell, likely, the air flow through the machine is restricted and getting too hot. Vacuum out the exhaust hose and the outside vent of lint. Reach inside the machine's air outlet pipe and vacuum all that you can reach. Remove the lint filter and wash it in hot water and detergent to remove fabric softener deposits. Vacuum below the lint filter opening as far as you can reach and inside the door cavity (be careful of sharp edges!). Hope this helps!
May 16, 2010 | Frigidaire FSE748GF Dryer
My kenmore dryer heat element goes on and off. The clothes take hours to dry.
It seems to run forever If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system. Normally, this is what happens during an automatic cycle: The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees. When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.) The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Dec 31, 2009 | Kenmore Dryers
Where is the dryer vent located?
most vents are standard size an in the worst case you can find a flexible duct to reach out to where you need to go!
May 27, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore 11070702990 Gas Dryer - Timer does not work
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
May 09, 2009 | Kenmore 60172 Electric Commercial Dryer
Auto switch does not reach "OFF"
hi thanks for the question do your clothes come out dry but i would check the venting from the dryer to the outside very important thanks the appliance doc
Aug 18, 2008 | Kenmore 63942 Dryer
Kenmore Electric Dryer 68731
If still heating, clean out vent and check for kinks. Also, REMOVE PLUG FIRST!! Remove back and remove four screw holding filter duct assembly at bottom left. Pull duct toward rear and reach into bottom of duct and remove lint. Also, wash out filter screen.
Nov 17, 2007 | Kenmore 659 Electric Dryer
Kenmore 63942 Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
