Question about Chopard Mille Miglia Gran Turismo XL Automatic Stainless Steel Black Dial on Black Rubber Strap 1684573001 Watch for Men
Date setting problems
I have just noticed that the date on my gmt changes ate about 3:45 am ???
  • app_3rp36205
    app_3rp36205 Dec 04, 2012
    Thanks - but I'm more concerned as to why it has happened ....... its a new watch and a month ago it was changing after midnight but now its at 03:45 ish ....... could it have been damaged by me setting the GMT and/or the date when the time was too close to midnight - or is tat an old wives tale ?
  • Conrad Jacoby Dec 04, 2012
    I don't believe that you have damaged your watch; actual damage would likely prevent the date from advancing at all. It is possible that setting the GMT hand may have confused the time at which the watch believes it reaches "midnight." That diagnosis is somewhat movement-specific, though, as the GMT hand should be fully independent of any other complication in many movements.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 172 Answers
A jeweler should be able to pull and reset the hands on your watch so that the date changes much closer to midnight. Note that some movements are designed to change the date at one time and the day of the week slightly later. This is done so that the power of the watch movement isn't overwhelmed by moving two date wheels simultaneously.
For a competent repairman, this is a fast and inexpensive repair. However, because of the risk of breaking the brittle pinions on which the hands are set, I would really discourage you from attempting this repair yourself. You might also accidentally scratch or otherwise mar the watch face, which would require an expensive dial refinish that will probably never look exactly like the factory dial.
Posted on Dec 02, 2012
After setting to uk time, will revert to European time zone (1 hour ahead of uk)
It sounds like it it changing to BST...
Make sure the date is correct, and set to UST
British Summer Time
Universal Standard Time (GMT)
Apr 17, 2016 | Watches
Set reserve indicator on invicta 6106
Here is how to set the Invicta 6106 Invicta 6107 and other similar models with the ISASWISS 8173 movement with the following functions:
TIME - DATE - DAY - ALARM - GMT - POWER RESERVE
DO THINGS IN THIS ORDER AND YOU WILL FIND IT TO BE VERY EASY! After you understand how to set ALL the functions you can skip steps later to set individual functions but for now just do it exactly step by step:
1. Unscrew the center crown (if it is a screw down crown) and pull it all the way out (this is position 2) and turn it until you see the DAY sub-dial at the 6:00 position set to the day BEFORE today. There is no QUICK SET for the day on this movement so you must just keep turning the crown and hour hand past 12 midnight and watch the day pointer until it gets to the day you want - the day BEFORE today.
2. Now set the time to 6:00 (am or pm doesn't matter at this point). This is very important because you do not want the time to be between 9:00pm and 12:00pm when you set the date later on - we are using 6:00 just to be safe.
3. Push the crown all the way in - you don't have to screw it down.
4. Now pull out the crown very gently to the 1st position - just one "click" out. Now turn the crown AWAY from you to set the date to the date BEFORE today - this appears in the small window at the 4:00 position.
5. Now pull the crown all the way out again to position 2 and turn it away from you until it goes past 12 midnight and TODAY's DAY AND DATE are showing and then adjust the hour and minute hands to the current time - be sure to set the hour to AM or PM and push the crown all the way in. If you wish to set the seconds exactly - with the crown pushed in watch until the small seconds hand in the sub-dial at 2:00 is exactly at 60 and then pull the crown out to Position 2. Set the time ahead a minute or so and push the crown in when the actual time is the time you have set - you can set it to atomic clock time on the internet or by another watch that sets itself to atomic time.
6. Now the DAY, DATE and TIME are set to current. Now when the hour hand passes 12 at midnight tonight the DAY and DATE will advance correctly.
YOU CAN STOP HERE IF YOU WISH - but you can continue on to set the ALARM and the GMT indicators as follows:
7. To set the GMT hand (the one with the red-bordered pointer) the crown is pushed all the way in and screwed down. Now simply hold the bottom pusher in for a few seconds until you hear a beep - now you can start pushing it and watch the GMT hand moving - one push at a time for small adjustment or hold it down to make it move faster. When you stop pushing it another beep indicates that it is OUT of the setting mode - so if you want to adjust it again just hold it in until short beep and start pushing the lower pusher same as above.
Understanding GMT (or second time zone): Note that the GMT hand time is indicated on the 24 hour dial (think in military time where 3:00AM is 0300 and 3:00PM is 1500) using the very small numbers around the very outside of the dial. When the local time is 3:00PM if GMT is adjusted for the SAME TIME ZONE as you are in now the GMT HAND will be pointing at the small "15" which is between the 7:00 and 8:00 hour markers. If the local time is 3:00AM and the GMT is adjusted for the SAME TIME ZONE as you are in now the GMT HAND will be pointing at the small "3" between the 1:00 and 2:00 hour markers. So lets say you are in Pacific Time Zone and it is now 3:00pm local time and showing on the minute and hour hands - and for example you want the GMT hand to show Eastern (New York) time which is 6:00pm (in military time that is 1800 indicated by the very small 18 which aligns with 9:00) - hold in the bottom pusher until you hear a beep - now start pushing it in short increments or hold it down to move it faster until it points to small 18 (large 9). Now the GMT will indicate the hour in the EASTERN time zone while the main hour hand indicates your local time.
7. To set the ALARM - unscrew the crown and pull it to Position 1. Turn it TOWARDS you (if you turn it way from you will set the date which you don't want to do) and you will see the hand with the white pointer and the word "Alarm" in tiny writing on it move clockwise. Set the ALARM to the time you want. Push in the crown and screw it down.
8. To activate the ALARM push the TOP PUSHER once - the small hand in the POWER RESERVE sub-dial will move slightly and then it will move again (give it a second or so) and you will hear a BEEP - now the alarm is activated and the small hand points to the "ON" label. When the alarm sounds if you wish to stop it push the top pusher. But it will stop on its own and then repeat a few minutes later - you can just leave it alone if you wish. Note that the Alarm will turn OFF after sounding - so if you want to wake up for work on time tomorrow be sure the ALARM indicator is pointing to "ON".
9. To deactivate the ALARM when the small hand is pointing towards the "ON" label simply push the top pusher again and and the small hand will move clockwise down to the "OFF" label.
10. POWER RESERVE sub-dial. To align the Power Reserve sub-dial hand (after battery change) pull the crown out to Position 1 and push the top pusher until the hand points to 0%. Push the crown back in and screw it down.
11. Reserve Indicator - the instructions for this movement states that holding down the top pusher for 3 seconds will move the POWER RESERVE hand to the power reserve scale - but this is confusing because the hand never actually stays on the power reserve scale - it will only stay on "ON" or on "OFF".
However - I believe that this is the way it works. When you push the top pusher with the small hand in the "OFF" position it will momentarily move to the power reserve scale and stop for a second before it moves again to "ON" - I believe that this reading indicates the POWER RESERVE just before it moves again to the "ON" position..
Jan 03, 2012 | Invicta Reserve Watches
I don't know how to change the date on my breitling colt
Their web site does not give any user manuals but most watches change the date by pulling out the crown to position 2 (1 is the normal home position, 3 is fully out and 2 is inbetween the two) and rotate the crown to change date.
This quality of watch may require you to turn the crown wheel anticlockwise before pulling it out (extra seal).
If this does not work them go to http://www.breitling.com/en/index.php#/models/aeromarine/chrono-colt/ and using the menu on the left, locate their nearest service center and contact them. I fell sure that they will be only too happy to explain the procedure for changing the date.
Dec 13, 2010 | Breitling Colt GMT 293/BL/FGHT Wrist Watch
Brieting Colt chronograph - 12 hour timer will not reset to zero.
The chrono hands can be set by pulling out the crown as if the date or time was to be set.With the crown out press the chrono pushers to advance individual hands as required.
Regards
Aug 05, 2010 | Breitling Colt GMT 292/SLV/FGHT Wrist...
How do i set the the 24 hour hand in a rolex 16758
Yours is the original GMT Master. The GMT Master II allows the GMT hand and the regular hour hand to be set differently but not on your older model. On yours, the regular hour hand the the GMT hand are fixed so that if the triangle on the rotating bezel is at the top, the GMT hand will indicate local time. To indicate time in a 2nd timezone, rotate the bezel to orient the time to the GMT hand. There's a copy of the original instructions posted at: http://www.rolexforums.com/showthread.php?t=45269
Apr 30, 2010 | Bulova Watch
How to set and use the subdial on my invicta model 5749 gmt watch
While I'm not familiar with that particular model, most GMT hands are set by turning the crown "backwards" in the date setting position. IOW, if you set the date by pulling the crown out to the first detent and turning it clockwise, turning it counter-clockwise will set the GMT indicator.
Apr 10, 2010 | Bulova Watch
Set 24 hr hand
first click changes the date if you turn one way, but turning thr other way should change the 24 hour hand.
Nov 30, 2009 | Watches
Rolex GMT Master II date changing after midnight
If it still under warranty take it back to rolex, other wise take it to an indpendent watchmaker they should be able to fix it for a small fee. The watch probably doesnt need a service yet if it is new.
May 06, 2008 | Rolex Explorer II 16570 Wrist Watch
Casio Gulfman G9100 tide setting. where to find Lunar Tidal Interval?
If you look at the GMT differential in the manual, you'll notice that it corresponds to the offset from GMT that your time zone resides in. I live in San Antonio but i don't see that on the list. I do know that when we're not in Daylight savings time, I'm -6.0 from GMT... so that's what i set it for. Also, if you're near enough to the coast to use this feature, it would probably be a good idea to compare the watch reading to the actual tides and adjust accordingly.
Hope this helps.
Mar 19, 2008 | Casio Sea-Pathfinder SPF40-1V Wrist Watch
Omega seamaster gmt
what you have to do is that pull the crown to halfway do not pull completely out, if you pull halfway out and then move the crown to clockwise or anti clockwise it will change the date. if you pull completely out then it will change the time.
Nov 07, 2007 | Omega Seamaster 2561.80 Wrist Watch
Chopard Mille Miglia Gran Turismo XL Automatic Stainless Steel Black Dial on Black Rubber Strap 1684573001 Watch for Men Logo
225 people viewed this question
Top Chopard Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Chopard Watch Expert? Answer questions, earn points and help others
