Question about Kenmore Washing Machines
My kenmore washer stop running in the rince/spin cycle and and i dont know how to rest or if a rest will work model #22432100 ser#c11706094 type#111 please help
My washer stops running in the middel of the rince/spin cycle i have tried to unpluging it i have tried to mess with the lid switch the model #22432100the ser#c11706094 #and the type #111
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
What is the complete model number of your unit?
Posted on Dec 02, 2012
  • Jim Bueling
    Jim Bueling Mar 21, 2014
    Electrolux EWF1234
3 Suggested Answers
  • 50 Answers
SOURCE: have kenmore 70 series washer
The lid switch must close for the washer to spin. I've seen a lot of these break where it's mounted to the top. You may still be able to reach under the top to grab the switch to close it and get it to drain. You'll almost certainly need to replace the lid switch.
Posted on Jul 21, 2008
Daniel S
  • 4323 Answers
SOURCE: Kenmore Elite Model 26922502 Type
Hi
The issue is with clogged drain hose and drain pump assembly. You will have to clean this to clear the clogs, please check this video on how to clean the drain pump assembly:
If after cleaning the issue returns then the drain pump should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Jan 19, 2011
I have a top loading Kenmore washer model # 22432100. It won't drain the water and spin. I completes every cycle up until then and it just stops. When I restart it, it works until draining,...
this is a direct drive washer the reason your unit is depending on if your hearing the motor running or not would either be the motor which i do not think it is or the drive coupler which connects the motor to the transmission and lets the unit spin here is also a video on how to do the repair for the drive coupler if when you disassemble you find the drive coupler intact and not broken message me back then for further diagnosis Thanks again heres you video http://www.youtube.com/user/RepairClinic?v=9K1KHEogf3c&feature=pyv&ad=5457341501&kw=washing%20machine%20coupler
Rick
Jun 15, 2011 | Kenmore Washing Machines
Some times the washer machine will spin and then
sounds like your clutch is slipping,,,,you can put a #10 washer in one of the clutch spring caps and that stops the slipping! thats a low on cash fix or just replace the clutch ,cost about 40 bucks!
Mar 30, 2010 | Kenmore 22422 Top Load Washer
Whirlpool type 111 model LSQ9200LQ3 washer not
I have a whirpool model:lsq9200lq3, and recently it has stopped working. when ever you turn it on, its fine and the water fills up normally and right before it gets to the spinning cycle the machine makes a grinding noise like if something is stopping the motor from spinning, and it dosent spin inside the washer. if anybody has any suggestion It would be great thank you.
Jan 30, 2010 | Whirlpool Washing Machines
I have a Kenmore washer. the water temp switches by itself.
IM NOT SURE HOW YOUR WASHER IS SET UP ON TEMP SETTINGS BUT-- THE RINCE CYCLE IS ALWAYS COLD RINCE
Nov 03, 2009 | Kenmore 24032\24036 Top Load Washer
22432 won't spin or drain
CHECK THE LID SWITCH THE PART THAT PUSHES THE SWITCH DOWN MAY BE WORN ENOUGH TO CAUSE THIS PROBLEM. WITH THE LID OPEN START THE WASHER IN THE SPIN CYCLE AND PUSH THE SWITCH WITH A POPSICKEL STICK AND SEE IF THIS PROBLEM STILL HAPPENS
Aug 30, 2009 | Kenmore 22422 Top Load Washer
Kenmore 80's series top loader only works on wash and rinse cycle
This is a problem with the pump being stuck so the motor cant turn the whole thing. Turn the washer on its side, underneath you can acces the pump, which is connected to the motor by two long clips. remove the pump and take out the colg that caused it to get stuck.
Jul 01, 2009 | Washing Machines
Type 111 filled with water and stopped
with the machine off, turn the cycle dial around 3x very harshly, then try it again. If it works normally now, you'll need a new cycle switch soon!
Mar 27, 2009 | Kenmore 24032\24036 Top Load Washer
Washer stops at rinse cycle-hums and has a smell.
Problem is with your lid switch which has to be replaced. This is if your filter is all clean.
Feb 28, 2009 | Kenmore 15864/15862 Top Load Washer
Have kenmore 70 series washer model #20702991 ser #1069231 type 111 will not drain. It starts the cycle by agitating then stops and will not go to drain cycle. switch on top lid does not ckick, tried...
Jul 21, 2008 | Washing Machines
Washing Machines Logo
746 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
