My washing machine starts washing then gets stuck nd can't empty water or move it onto another programme have checked for blockage but ant seem to find anythink please help
Check drainase system. is water pump pull out the water properly?
is valve packing clear? or clogged with coin or anything else.
Posted on Dec 02, 2012
  • 1294 Answers
SOURCE: Hoover Nextra washing machine - water backing up
If this is a front loader see that u use only washing powder for FRONT LOADING MACHINES. Also possible your detergent drawer is clogged with old dry detergent. Pull out the drawer and clean with tooth brush. Things shd be fine.
Posted on Oct 08, 2007
jumptrout51
  • 3361 Answers
SOURCE: programme gets stuck on wash cycle
Most likely a defective door switch.
Posted on Mar 02, 2009
barkencoa
  • 3463 Answers
SOURCE: water not pumping out
Filter is located at bottom rear right of washer, inside large black hose.
Remove lower rear panel to gain access.
Please rate my solution.
Thanks.
Posted on May 31, 2009
  • 215 Answers
SOURCE: Found lots of fluff from a previous wash. Next
To clean pump you will need to unplug machine, at rear using screwdriver remove the panel at bottom of machine. depending on fitting of clip holding pipe onto your pump, use suitable tool to remove the clip. You can now remove the pipe from the pump. check inside the pump also.If you need to remove the tub end of this pipe there is what is like a ping pong ball within the pipe. Make sure you refit this as it acts as a non return for the water.
Posted on Mar 15, 2010
Macmarkus
  • 2605 Answers
SOURCE: my washing machine starts to fill with water then
Hello sue, welcome to Fixya.
Are you able to remove the back panel and check the belt ?
How much are you able to perform on your own I should say, check motor, wiring etc ?
Let me know, I'll watch for your reply and have a better understanding of how we can help you.
macmarkus :)
Posted on Jul 01, 2010
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
My ignis washing machine stops in the middle of the washing cycle and makes a sound, kind of blowing.
there are many more likely causes for this fault. The program will stick if the heater isn't working, if the thermostat fails, if it can't fill up with cold water for the rinses, if it can't empty the water etc. There are too many possible causes of this fault to be able to give anything other than rudimentary advice. However, the common causes of a washing machine sticking that can easily be fixed are filling and emptying problems.
Check that the cold water supply is available to the washing machine, which is a common cause for sticking on rinses.
The most common cause of a washing machine not taking any water in is either a kinked fill hose or the tap becoming faulty whereby you switch it on but the valve inside doesn't turn. Another common cause is the tap getting accidentally switched off and people not realising. Other causes can be wiring faults, water valve faults or programme control faults. This advice was originally written when most washing machines were hot and cold fill and didn't have error codes. It's now been updated to reflect the fact that these days the vast majority of washing machines are cold fill only and should give an error code if they can't take in water.
If your washing machine is stuck full of water the water needs to be drained out and this article gives tips on how to do this. If the entire washing machine has gone dead leaving the machine full of water it may be worth checking that it isn't something as simple as a blown fuse ( Washing machine is dead, wont start ) in which case if you get the washer going again it should pump the water out itself.
If the washing machine appears to be functioning normally but simply won't pump away the water then the possible causes (in the most likely order) are a blockage somewhere, a pump failure, or an electrical fault stopping the pump from running.
Blockages are the more likely explanation, but pumps can fail.
Dec 31, 2010 | Amana NAV2330AW Top Load Washer
The motor on my Miele washing machine is running constantly even when not set on a programme. The water seems to empty out as soon as it comes in. I Have to release the Stop /Start button to stop motor.
what motor do you mean the motor that spins the drum or the pump motor if its the pump motor i would check the programmer as it tells the pump when to run, on a rinse water evacuate cycle it would seem that you are stuck in that mode call a loacl engineer
Jan 16, 2010 | Miele Novotronic Premier 500 Front Load...
Error "nd" trouble
Nd, means no drain... a blockage in the drain line from the tub. Access from the back panel, you can remove the hose from the machine and check for blockages... this would be on the tub side of the hose... take the hose loose from the machine and check for blockage at the tub. squeeze the hose to check for blockage within.
take the hose loose at the pump to check for blockage there as well... watch out for water ...be ready to mop... let me know how you do..
May 26, 2009 | Maytag MAH2400A Compact Front Load Washer
Programme gets stuck on wash cycle
Mar 02, 2009 | Washing Machines
Diswasher
Check the float switch. If it is stuck the machine will start but no water will be allowed in and the pump will turn on to drain the non existant water. This happens often when a small item gets under the float preventing it from allowing the water valve to open. Find the float in the bottom of your machine and make sure it moves freely.
Jan 15, 2008 | Whirlpool 24 in. ADP6940 Dishwasher
Oct 07, 2007 | Washing Machines
Hotpoint WD440
On the power pcb panel, there is an eeprom. This gets corrupted and throws the machine into a frenzy. A replacement should include a new pcb and a new eeprom. Only from dealers unfortunately.
Aug 28, 2007 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
35 people viewed this question
Top Washing Machines Experts
