Question about John Deere Garden
How do I remove the mower deck for a John Deere X475
4 Suggested Answers
SOURCE: replace blades on a john deere L120 mower deck
First make sure you have the tools, metric that is. The deck must be removed and turned over. To do this you must put the deck in the lowest position. Using a 15mm socket pull the belt tension spring pulley forward to detach from clutch. Next remove retaining pins located at the five deck brackets. This will allow the arms to slide off and the deck can be dragged out from under the mower. Turn deck over. Use a 18 inch 2x4 to block blades while removing the two 15mm bolts. The bolt heads will need to be cleaned so the socket can seat on bolt head. I use my torque wrench to get more leverage and i can use it to reset blade bolts to 64 ft lbs. While blades are of it is a god time to thoroughly clean underside of deck.
Posted on May 25, 2009
  • 218 Answers
SOURCE: I NEED TO SEE A DIAGRAM ON A JOHN DEERE 214 LAWN
Hi..my name is Keith..and you can go to an online lawn mower parts site and put in your model of lawn mower and search for the mowing deck..and they will have a diagram of the mowing deck with the belt on it..and there are several sites online but i'll give you the one i use www.outdoordistributers.com ...i hope this has helped
Posted on Jul 12, 2009
  • 5 Answers
SOURCE: need john deere stx38 mower deck belt diagram
Go to http://outdoorpowerinfo.com/repairs/deere_stx38_gear_drive_belt.asp
for pictures and descriptions of drive belt and deck belt on John Deere STX38 and STX46 tractor with black deck
Posted on Oct 22, 2009
Is there a diagrm of how to attach the mower deck to a john deere x324 lawn mower and where can i find it
https://www.google.com/?gws_rd=ssl#q=Is+there+a+diagram+of+how+to+attach+the+mower+deck+to+a+john+deere+x324+lawn+mower
Apr 24, 2017 | John Deere Garden
How t Remove ignition switch x475 john Deere Key broke off in my x475 John Deere. How do I remove the ignition switch?
To remove broken key use an o ring pick and a doctors stitch twizzers . works every time.
Oct 30, 2016 | John Deere Garden
Keep burning up deck belts on 20yr old John Deere rider rx75. What size belt should I be using
1/2 x 60
Check all deck idler pulleys and make sure no bad bearings or flat spots
Apr 24, 2015 | John Deere Garden
I need a belt diagram of John Deere L120 mower deck
Belt path for JD 100 series, 42" cutting deck, 2 blades.
Sep 14, 2014 | John Deere L100 Series
John deere x475 mower will not engage after cutting heavy grass
It is probably full of grass in the mower deck. Clean it out and try again.
Sep 25, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Have a 2000 J.D. x475 62" deck engine will crank and crank but will not attempt to fire
Check for rust on the flywheel magnet and the coil, make sure the air gap on coil is correct, check for broken primary wire.
Aug 18, 2013 | John Deere Garden
John Deere 185 deck height adjustment
having a problem with dive belt being hit by the mower deck 185 john deere suggestions !!
May 08, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John Deer X475 lawn mower
Check fuses.Does the dash light for PTO come on?Right side screen by pedals sometimes comes in contact with wires and cuts them.This happens mainly on the older units.
Sep 19, 2009 | Garden
Garden Logo
992 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
