Question about Samsung NV4 Digital Camera
Memory: 2 GB. The PROBLEM? Suddenly, all the photos are GONE! I connected my camera to my laptop, it shows there that my memory is almost FULL but there are NO PHOTOS at all! WHAT SHOULD I DO?
    Genius:
  • Samsung Master
  • 1,019 Answers
It sounds like the card is corrupted, the photos are lost. try a new card and take a couple of pics and see what happens. If you still have the same problem then it is the camera.
Posted on Jan 26, 2013
  • 6 Answers
SOURCE: cannot connect to pc
hi
Does your PC recognize it?
Maybe you need a driver for it?
Look for the CD in box
Posted on Sep 22, 2009
Obertelli
  • 3006 Answers
SOURCE: memory card saying "full" when its not
Your problem is that you are using an incompatible type of memory card.
Your camera was designed to use SD cards with a maximum capacity of 2GB. It cannot use larger capacity models, and is also incompatible with the later SDHC cards.
SDHC cards are the same shape and will fit your camera, but have differences beneath the skin and so won't work properly in your camera. Without any memory card in place your camera uses internal memory; it's then only by lucky chance that your camera has sufficient SDHC compatibility to allow you to transfer the internal memory image to the SDHC card when you subsequently insert it into your camera.
Your only solutions are to either use an SD card with a maximum capacity of 2GB or to replace the camera with a later model which is fully SDHC compliant.
Posted on Oct 06, 2010
SOURCE: just bought samsung es25.took2 photos and the
The internal memory of the ES25 can only store one or two pictures, but you can buy SD cards from amazon.com quite cheap. 2GB will give you space for about 1000 photos (with super fine setting). bare that in mind
Posted on Dec 01, 2010
  • 11967 Answers
SOURCE: i own a samsung ST60
Sounds like your camera has some pictures on its internal memory and is preventing the memory card from working. With no card in the camera, go into the menu and find "format" and follow the on-screen instructions to erase the internal memory. Then, your memory card should work.
Posted on Dec 14, 2010
SOURCE: Hi, I have a Samsung
My NV3 wont access the 1GB SD card and carries on accessing internal memory but the card works ok in my other NV3? I have also noticed it reacts very slowly when inserted but ok when using the internal memory with the card out.Have tried reformatting card to no avail.. Any help appreciated.
Posted on Mar 23, 2011
Memory card is empty. Camera says Memory card full?
may be your memory card is a high capacity type you must know the supportable stick, there is classification in memory sticks, SD/ SDHC/ SDXC like, high GB will not support your cam.
Nov 15, 2015 | Samsung HZ10W / WB500 Digital Camera
My camera suddenly the screen can not show the picture ...
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Nov 12, 2012 | Fuji FinePix F410 Digital Camera
Can't see images on laptop
Aug 14, 2012 | Cameras
What to do when it says internal memory full
Delete some pictures off you camera. It means that there is no more room on your memory.
Make sure to transfer them to a computer, before you delete them, as you wouldn't want to lose precious memories.
If you found this answer helpful, please rate it.
Mar 14, 2011 | Kodak EASYSHARE Z1485 IS Digital Camera
I have a Finepix z10 and am having a problem. Last night I was using it to take pictures and it was fine until it said memory full, which was a possibility but I was surprised. When I looked at it this...
http://www.fujifilmusa.com/support/ServiceSupportContact.do?prodcat=644675
This is a special problem and I would direct you to contact fujifilmusa.com directly about this problem with the memory card.
I'm not sure how to retrieve all of the photos that are missing that you took beyond the 60 photos that showed up.
Sep 02, 2010 | Fuji FinePix Z10fd Digital Camera
Hi suddenly my Samsung S1020 shows 'memory full'. Tried another new memory card Kingston 2GB- worked a while now same problem 'memory full'!
If you've already copied your photo's to a computer, or had them printed, or otherwise have backed up your photo's, look in the manual for your camera for a "format media card" option, try that. This will erase everything on the external card and give you plenty of room.
Jul 18, 2010 | Samsung Cameras
Camera won't take photo frequently
It might be telling you the internal memory is full. With no card in the camera, go into the menu and find "format"...follow the on-screen instructions to format (erase) the internal memory. Then insert your card and see if things improve.
Jul 14, 2010 | Konica Revio KD-400Z Digital Camera
2 gb sandisc card while transferring photos to laptop it says fil
Download software unlocker install it to access the photos inside the card .
Mar 12, 2009 | SanDisk 2GB Secure Digital Memory Card
Lost pictures
check out cardrecovery.com
Aug 04, 2008 | Canon PowerShot A530 Digital Camera
A-data MMC 1GB
Try using this:
www.recuva.com
It might find the lost pictures.
May 05, 2008 | Cameras
Samsung NV4 Digital Camera Logo
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
