Large bang noise, then TV went off, came back on with audio only.
The Tv was on and had been on for about an hour when suddenly there was a loud pop sond. Next the tV went off. About one minute later it came back on with audio only. It will not show anything on the screen. Not even the menue.
  • tsunami167 Jan 11, 2009
    This is a 50" plasma TV
    Genius:
  • 1,239 Answers
Hi
in all the plasma tvs the manufactures default is there due to over heat the CRT will be gone or it is the lamp  ......you have to check these 2 and fix it
Posted on Jan 11, 2009
  • 1,031 Answers
If its LG50 plasma tv screen that went went off after a popping noise but still has sound, its a common issue with the brand .check the back unplug the tv and test the fuses out of the three visible ones test for any blown fuse atleast one must have blown thou there is sound , .take the code/seriel number down and took the fuse to the electrical wholesalers for replacement for the fuse in the tv and everything will be fine.hope this helps
    Sergeant:
    Scholar:
  • 199 Answers
The tv capacitor or IC on the main board is blowned up and that loud pop which you heard was of slight busting of this component on the main board.you will just have to check out the main board and replace that blown component.also also check out the whole board to locate exactly where the circuit got break and caused this loud pop due to over voltage passed in the circuit board.and after that also check at the socket where you have connected the power wire of the tv if any thing got short there this can happen again so get it checked first before reconnecting in the same power outlet.this will solve your problem
thanks.
  • 45 Answers
May be due to some faliure in the voltage regulation  some kind of damage had occured to your picture display i think may be there is some damage to your picture tube so in that case you contact the dealer he can fix up your problem Thank u
    President:
  • 948 Answers
It will take a visit from a technician to fix your television. There are multiple reasons this could have happened, and only an inspection by a qualified service person can determine what happened and why.
If you have the troubleshooting skills let us know and someone can find the schematics for your tv and tell you what results you should be getting from your tests with a multi meter.
    President:
  • 1,990 Answers
Welcome to Fixya! I have noticed Recently a LOT of Plasma Tv's with the Same Problem. You can check the Boards and Power Supply But, Ultimately the Vast majority of People are Returning the TV to the Manufacturer or Locating an Authorized Repair Center Or Purchasing a New one due to the High Cost of Repair.
  • 10,515 Answers
U need to change the ic on the board :).............................
As the audio is working fine, so its absolutely fyne with power supply...........
It might happen due to voltage flucuation...
Thanks.
  • 19,396 Answers
If the TV is a rear projection the lamp may have gone.
If the TV is a CRT, you may have had a short on the alignment boards near to the deflection yoke.
    Sergeant:
  • 431 Answers
I hope the display in tv had gone due power fluctiations
  • nematics
    nematics Jan 11, 2009
    may i know which model and company
  • nematics
    the display ic had been busted out
Loud bang, then audio only from my tv
YES YOUR YSUS PANNEL HAS JUST POPPED CHECK OUT EBAY FOR REPLACEMENT,,
6871QYH053B
IS THE MODEL BOARD U REQUIRE,,
THERE WAS A GUY ON EBAY 64.99 AND 12£ POSTAGE AS LONG AS YOU STILL HAVE SOUND AND NO PICTURE,, YOUR PSU SHOULD BE FINE,,
Feb 11, 2010 | LG 42PX5D 42 in. Plasma HDTV
RCA HDTV DLP 50'' TV Goes Blank!!!
The bulb went out, The clicking is the ballast trying to start the bulb
Jul 12, 2009 | Televison & Video
On one minute then POP loud noise, burning smell
Loud popping and loss of power is common on plasma TVs and is usually either the Y sustain or Z sustain boards or buffers; in these instances the damaged part will be quite evident.
If this is an LCD you might have degraded insulation on one of the pink/blue backlight power leads causing high voltage to 'arc' to the chassis.
The loud bang and smell is actually to your advantage as in these circumstances the damaged part is usually evident. It'll just be a matter of popping the back off and sleuthing around. :)
May 18, 2009 | Sylvania Televison & Video
When I was watching the tv it suddenly started to flash off and on and then finally will not even turn on
Watching tv all of a sudden loud buzz noise,I shut off unit turned back on loud buzz came back about 30 seconds later loud pop pop then smoke came out of top of unit, i'm not please as this unit i bought about 17 months ago @ Canadian Tire Belleville & warranty is now not covered, pobably will never buy another Proscan product but am more concerned there could be a fire caused buy this than getting unit replaced
Apr 23, 2009 | Proscan 19LA20Q LCD TV
Tv went out after loud pop and has clicking noise does not turn on
If you have a Sony DLP, then the loud pop you heard is your lamp.  The lamps last approx. 4K-6K viewing hours.  Read your manual for replacement part number to reorder and very simple to replace yourself.
Apr 22, 2009 | Televison & Video
Loud popping noise
The 23" CRT set may have a high voltage breakdown in the flyback transformer or focus divider. Take the back off and operate the set in a dark room. Look for anything that has a blue glow around it or sparks flying when the pop occurs. I won't guarantee this will find your problem, but it is definitive if you see these!
I once had a set with these symptoms. I stopped the blue glow and arcing by covering the focus divider with epoxy. It worked for a couple of months before the divider literally broke apart.
Mar 02, 2009 | Polaroid TLA-04011C 40 in. LCD TV
No Picutre
someone shot your tv.
no really, I am just a smart a$$ --- but the loud pop sounds like it may have been one of the capacitors in the power supply board. check for a POPPED cap (rare) and if there is one, test the components in the related circuit - as SOMETHING had to happen to make a cap fail like that - maybe a voltage regulator? give it a look..
Jul 25, 2008 | Sony KP-48S35 48" Rear Projection...
Whistle noise? POP? Black out
sounds like the lamp has shattered. check the lamp
May 18, 2008 | Samsung HLN5065W 50" Rear Projection...
Panasonic TV Turned it self off, humming speakers, loud bang & Burning Smell
hi there, you do have a big problem at your tv, the loud bang means a part is broken, maybe you will cost 50 % of the original price of your tv. ty
Dec 26, 2007 | Televison & Video
Loud bang, unit stopped working
I have seen the caps in the power supply vent, which means they get hot and the top pops up and splits open, resulting in the "bang" sound. If you have experience in electronics then remove the back of the set and examine the power supply, looking for any caps whose tops are bowed upward, and replace.
Jun 24, 2007 | Sony FWD-50PX2 50 in. Plasma Television
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
