Question about SanDisk Sansa m240 MP3 Player
Its not plug and playing Sandisk 240m 1g
I have windows xp with SP2, windows media player 10, and no dusty USB ports. When i plug in my Sandisk 240, my computer doesnt detect it, then i plug in something else to the same USB port and it works fine.
Hi blackmajik, I just got a Sandisk m250. Windows wouldn't recognize it either until I updated my Windows Media Player to version 11. Now XP sees it just fine and the MP3 player syncs with WMP and accepts and plays music!
Posted on Jun 12, 2007
The pc is unable to detect the sansa disk
If you are using Windows XP: verify the following operating system requirements are met. - Windows XP SP2 or higher - Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
If you are using Windows Vista: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player. - Download the hotfix from http://support.microsoft.com/kb/939211. - Run the hotfix.
Refresh the driverd
1 - Connect the Sansa player to the PC The screen on your player should turn on, show 'Connected' and indicate the battery charging or full. - If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub. - If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
Apr 03, 2010 | SanDisk Sansa Clip MP3 Player
Download from audible
hi,
Have you tried connecting to the net and then continue to subscribe??
Feb 09, 2008 | SanDisk Sansa Clip MP3 Player
Sansa Fuze player will not connect to the computer
The Sansa Fuze information support is on next site:
http://kb.sandisk.com/app/answers/detail/a_id/3249/
Sansa Fuze can connect in either MTP or MSC mode.
MTP is Media Transfer Protocol when a software program like Windows
Media Player 10 or higher is installed.
MSC is Mass Storage Class when the player is detected as an external flash drive in "My Computer".
The connection mode can be set to one of the following USB modes:
auto detect:
the player will connect in MTP or MSC mode. It depends on the drivers that are installed for the USB ports for the operating system and extra media software, if the data on the player can be detected. In auto detect
mode, MTP mode detection is only possible when having Windows Media Player 10 or higher installed.
mtp:
detection on operating system Windows XP SP2 or higher, in Windows Media Player 10 or higher.
msc:
detection on operating system Windows in the explorer in "My Computer" and on MAC operating system.
Look in the manual on page 35 = page 38 in the pdf file, how to switch the USB mode under System Settings in the player:
http://mp3support.sandisk.com/sansa/UserManual/FUZE/fuze_userguide_en.pdf
Mar 20, 2010 | SanDisk Sansa Fuze MP3 Player
Sansa m240 files won't show up on computer
Uninstall/remove the mp3 player from the device manager of windows while its plugged into you computer and unplug afterwards from your usb port and plug it back in, windows now sees a new device and starts installing it.
Go to the configuration panel\system and click at the tab hardware and klik at the button device manager.
This should solve the problem.
Succes.
Aug 31, 2009 | SanDisk Sansa m240 MP3 Player
Sansa clip wont power up unless hooked up to usb
http://www.sandisk.com/media/175960/clip_um_0608_eng.pdf
Windows XP SP2
• Windows Media Player v10
• Intel Pentium class PC or higher
• CD-ROM drive
• USB 2.0 port for hi-speed transfers and charging
Make sure HOLD button is not on.
Battery
The Sansa
Clip player comes with an internal rechargeable battery. To use the player for
the very first time, remember to fully charge the battery. You can charge your Sansa
player through the USB port of your computer, a car adapter (not included) USB port, or AC
adapter (not included) USB port.
Charging
To charge the battery, please follow these steps:
1. Connect the larger end of the USB cable into an available USB port on the
computer.
2. Connect the smaller end of the USB cable into the Sansa
Clip player.
3. The computer must be on for most USB ports to charge your battery. Your
Sansa
will show connected and the yellow charging indicator will appear.
The battery level indicator will blink while charging. You will not be able to
play while connected to the computer USB.
4. To stop recharging, simply disconnect the cable.
The battery can also be charged using an AC adapter (not included) or a car adapter
(not included) and you will be able to play your device while charging with one of the
adapters.
NOTE: Some low-power USB ports may not be able to provide enough charge
power. Also note that the rechargeable batteries are not replaceable.
Feb 26, 2009 | SanDisk Sansa m200 SDMX3-512 MP3 Player
Cant get past cd installation
Grab the software from Sandisk's website and try again. If that fails, upgrade your XP to SP2 or 3.
Sep 07, 2008 | SanDisk Sansa Clip MP3 Player
I WONT ADRIVER
Drivers are not necessary. You need Windows XP / SP2 and Windows Media Player 10 or higher. They supply all the necessary drivers. Best of Luck.
Oct 07, 2007 | SanDisk Sansa m240 MP3 Player
My sandisk sansa m240 not working with my windows xp pc
I have XP Media Edition w/SP2 and I see the M240 as a Media Device and NOT a hard disk, AND it has MEDIA and DATA subdirectories only. Media has to go into the MEDIA subdirectory to be seen/read played. Now, on my plain XP system, the M240 it shows up as a disk drive with different layout. There is no MEDIA directory, so putting files into the mass storage device letter will lockup the unit. I haven't tried Media Player 10 solution, but if you have one of these, do NOT put files in it unless you see the MEDIA subdirectory.
Sep 19, 2007 | SanDisk Sansa m240 MP3 Player
SanDisk sansa c140
You need to Have Windows XP / SP2, Wndows Media Player 10 or higher in order for the device to be recognized. If you have these components, try changing the mode on the device to MSC Mode. Settings>Mode>MSC. Best of Luck.
Sep 11, 2007 | SanDisk Sansa c140 MP3 Player
Question
No drivers are necessary. You need to have Windows XP / SP2 and Windows Media Player 10, or higher in order for the device to be recognized. Best of Luck.
Sep 03, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa m240 MP3 Player Logo
89 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
