Question about Kenmore HE2 Plus Front Load Washer
How to change MCU on Kenmore HE2 - Kenmore HE2 Plus Front Load Washer
2 Suggested Answers
oldTech2332
  • 2341 Answers
SOURCE: Trying to run diagnostics on
What to check next is if the switches on the lower panel below the one where the door mounts,check that when the panel is off that those switch are closed and have ZERO omhs resistiance and the are open when panel is installed. To do the DISCONNECT POWER TO WASHER, remove that panel and check for continuty with the panel off them,then push the switch in as if the panel was on and see if the switches are open with infinate ohms.
If they check to be good ,since of you have already checked for tight good connections on CCU/MCU the MCU would need to be replaced.
Good luck,
Gene
Posted on Aug 13, 2011
Where is the MCU located on my kemore washer?
normally its located down below the drum on either side,but without a model number i cant tell you for sure because kenmore does not make any of their appliances,it could be a whirlpool,maytag,g.e.,frigidaire,etc.,the first 3 digits in their model number before the decimal point tell you who produced the appliance and the 8 numbers after the decimal point are model specific
May 06, 2012 | Kenmore HE2 Plus Front Load Washer
I have a Kenmore HE2t front loader washing machine and getting a F 31 error and the door is locked with a load in machine
Hello & Welcome to FixYa
Error F31 in your washer is displayed due to MCU (Motor Control Unit) failure. It is displayed if the heat sink gets too hot and then the MCU stops motor, then MCU sends the signal to CCU (Central control unit). Please check the wire connections between the CCU and MCU, if thats fine then check the motor operation. Hope you understand...replacing the part# that has gone bad is recommended repair. Please get back to me if you have any other questions.
Kevin
Nov 02, 2011 | Kenmore HE2 Plus Front Load Washer
Getting a f 31 error on Kenmore front loader washing machine
Error F31 in your Kenmore washer is displayed due to MCU (Motor Control Unit) failure. It is displayed if the heat sink gets too hot and then the MCU stops motor, then MCU sends the signal to CCU (Central control unit). Please check the wire connections between the CCU and MCU, if thats fine then check the motor operation. Hope you understand...replacing the part# that has gone bad is recommended repair. Please get back to me if you have any other questions.
Kevin
Trying to run diagnostics on Kenmore HE2. Door locks and then nothing. Few minutes later "Normal/Casual" light is blinking. Fewminutes after that I get the dreaded F28. Tried using...
Good luck,
Gene
Aug 13, 2011 | Kenmore HE2 Plus Front Load Washer
Kenmore H2 PLUS reads F--28 code what does this mean?
The error code F28 means one or both of these parts are bad.
Motor Control Unit (8540135)
Microcomputer Machine Control Unit (8540788)
It would be a good idea to order both, as both components have been problematic for error code F28
If you find either the MCU or the CCU(Microcomputer Machine Control Unit) fixed it.
Here's the online repair manual for your
Whirlpool Duet Sport, but its identical to your HE2.
Give it time to download.
On page# 4-20 it shows how to access your MCU.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/6545d78b3f479480852571650061b1ba/$FILE/8178558.pdf
Feb 13, 2011 | Kenmore HE2 Plus Front Load Washer
F28 code washer stops working. Reset will only
Error code F28 indicates that one of the below part is bad
  • Motor Control Unit (8540135)
  • Microcomputer Machine Control Unit (8540788)
If you find either the MCU or the CCU(Microcomputer Machine Control Unit) you can fix it,
Here's the online repair manual for Whirlpool Duet Sport, but its identical to your HE2.
Refer page# 4-20 it describes how to get to MCU.
May 04, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore washer says there is a communication problem between MCU and CCU
Access the timer and unplug/replug the main harness and re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 07, 2010 | Kenmore HE2 Plus Front Load Washer
Error code F-28
It may be that the drain pump is not the problem at all. Error Code F-28 on the Kenmore HE2 means that there is a signal error between the Central Control Unit (CCU) and the Motor Control Unit (MCU)
Mar 13, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
222 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
