Question about Denon Audio Players & Recorders
Why do i have to power on and off many times before my denon receiver connects?
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 49 Answers
If it does that, It is called the protect mode, There is a internal problem with the amp, Will have to be taken in for repair,
Posted on Dec 02, 2012
How do I hook speakers up to my denon TU-550 receiver?
A Denon TU-550 is a tuner, not a receiver. It outputs at line level rather than speaker level. You will need to connect it to a receiver or a pre-amp/power amp to get audio out of it.
Jan 31, 2015 | Denon Audio Players & Recorders
Why do i have to power on and off my times with my denon receiver before it connects/
That is called the protection mode, Because of a internal problem with the amp, That is causeing it to over heat, End shut down,
Dec 02, 2012 | Denon AVR-1907 Receiver
I have lost video on my tv - connected via hdmi to denon avr-689 receiver.
Had a similar issue, replaced the receiver three times in first month. The fourth time it had to go back to Denon. They returned it saying no fault. Also replaced HDMI cables etc...real head scratcher. Turns out it was the tv. The system can get discombobulated if the receiver, tv and source are not sequenced correctly. This is due to the HDMI protocol, Power up sequence should be receiver, source tv. Once video is lost it has to be rest. With system powered up and tv displaying no signal, remove HDMI cable at tv. Turn off tv at outlet and leave of for 2 minutes (this rests HDMI port, important to leave off long enough!.). Turn tv on and reconnect HDMi...all should be good. Poor Denon, I blamed them when it was my Sony Braiva all along....bad Sony
Apr 16, 2011 | Denon AVR-689 Receiver
Connecting computer speaker to a receiver
Which output section of the Denon are you using? Tape monitor out? And are you getting sound through the speakers (not the PC speakers) that are attached to the Denon speaker terminals?
Oct 26, 2009 | Denon AVR-1601 Receiver
I have a denon avr amp it powers up then goes in
disconnect all connections cycle power if the power stays on reconnect equipment one at a time cycling power after each peice reconnected. If the power goes back to stand by with nothing connected the reciever needs repair
Jul 18, 2009 | Denon AVR 2808Ci Receiver
Connecting 2 sub woofers to denon 1506 receiver
Most receivers only handle one sub at a time. If you are deadset on connecting two, you might want to consider how much power your receiver will give to each if you split the signal then determine the power of each sub. If the subs aren't the same you can be sure they will sound strange.
If they are identical and your receiver has enough power to handle them both, examine the connection the subs use to connect to the receiver and split the connection by buying a splitter at a local radioshack.
You will probably be better off using the better of the two subs instead of having both connected. Your sound quality will be more balanced and clear when it comes to bass.
Mar 03, 2009 | Denon AVR-1506 Receiver
Powering On Problem
out of the box if this unit is doind this it needs repair, the other things youcan try is check all spkr connections, if good make sure the 2nd zone audio level is down to about -60
Feb 01, 2009 | Denon AVR-2807 Receiver
Denon AVR-487 power issue
hello my friend denon receivers are famous for the power problem, check all the connections first and if there is not solution your power supply has a problem
good luck
caypianan@yahoo.com
Oct 28, 2008 | Denon AVR-4800 Receiver
Operating my ipod docking station
Absolutely!
Keyword(Read the instruction and follow it step-by-step.) Well,if you do,you wouldn't be asking for help,cause you want a 50+ pages Denon manual instruction to be concise to few paragraphs so you could move on with your life-:o)
Okay.only this time!
Denon ipod docking station comes with a power plug and a set of cable which you need to connect behind the Denon AVR-2807 receiver which is under an INPUT LABEL for IPOD only(not going to give it away,you will find it!)
Now,of course you could use HDMI......but,the quickest way to view your video(on screen menu) will be using a composite(RCA) video cable to connect from the Video output(yellow color) from the receiver to the TV composite video input.Turn on your IPOD,and you are ready to see the on screen manual.
Hey,this is just a lazy way to start you off if tomorrow night you have a date;otherwise,set it up properly by using the instruction!
Cheers,
solutiondoct
Oct 18, 2008 | Denon AVR-2807 Receiver
46 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
