Question about Car Audio & Video
The main amplifier blew up but sub amp is good, can I use it on another brand of amp as the sub side of it?, and just one more question is the amp suposed to be really hot when its running? like it he
Does the main amp run really hot?? can I use the sub amp on a different brand of amp as the powered amp and subs??
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 77 Answers
Need the full description of your audio setup including manufacturer and model numbers and how they are installed.
Posted on Dec 02, 2012
SOURCE: sony 1200 watt amp
What kind of deck to you have? Sometimes there's a setting for the subwoofer output that has to be turned on. How is the deck hooked up to the amp? Be sure of the normal things: -Make sure the sub is connected in side it's box -Make sure the RCA cables didn't come off the deck -Check every connection! Let me know and be sure to leave feedback or I don't get paid.
Posted on Oct 03, 2007
blueextc3221
  • 15935 Answers
SOURCE: apline mrv-1000 2 infinity sub
RMS power at 12V 20Hz-20kHz
2 x 100W @ 4 ohms (0.08% THD)
2 x 200W @ 2 ohms (0.3% THD)
1 x 400W @ 4 ohms bridge (0.3% THD)
That amplifier is not 2 ohm mono stable in bridged mode (assuming subs are SVC 4ohm).
It is seeing too much resistance and overheating. Thermal overload protection kicking in.
The phase switch allows you to switch from in phase to 180* out of phase. This feature is not to taken as written in stone. In some rooms, or locations of a room, the output will sound louder/better either in phase or out of phase. So there is no correct setting. It all depends where the sub is located and the acoustics or shape of the room.
Phase is term that describes multiple characteriscs and behavior of a speaker system.
Phase alignment: The vertical alignment of the voice coils of all the speakers in a speaker cabinet, so that all signals reach the sweet spot at the same time.
Crossover phasing: If one or more crossover slopes are of a different slope, then the speakers would not fire at the same time, causing delays in response.
Reverse polarity: You may reverse the polarity of a speaker to make the speaker fire inwards instead of outwards to improve alignment with the other speakers in the system. This is very common in tweeters circuitry. As for woofers, if the polarity is reversed, there is usually a cancellation of bass, to a degree.
Posted on Dec 22, 2008
  • 4 Answers
SOURCE: 3 amps 2 subs sound system for car, need wiring help
it is easy to hook it up!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Posted on Jan 14, 2009
Icehockey35
  • 16 Answers
SOURCE: JL audio 250/1 not powerful enough for pioneer TS-W307D4?
you should move up to more power....underpowering subs is bad! try not to go under the subs rms by 5o watts?
Posted on Jul 03, 2009
Devsta
  • 68 Answers
SOURCE: Alpine PDX1.600 amp cuts off
Make sure there's no missmatched impedance. If your sub running 2 ohms then your amp has to be 2 ohms stable. Does the amp blow fuses or get really hot? If it does it can be a fire hazard and I would recommend taking it out of your car. It could be that you don't have sufficient grounding. The grounding needs to be very close to the amp and the paint needs to be thoroughly scratched off. Otherwise could be a blown transistor within the amplifier, you can check this by opening up the amp, running a multimeter and testing the transistors for resistance.
Posted on Aug 05, 2009
Light blinking and sub just sounds like a heart beat
Swap the wires of your Sub with another channel and if the same sounds comes out, you blew your sub. If a different sound, you blew a channel on your Amp
Apr 11, 2013 | Audio Players & Recorders
Just bought 2 12 in d3 dual 2 ohm subs with d5 600.4 amp. Need to know how to wire subs. They were in a box already I assumed they were wire at 2 o When i hooked One up to my amp it hit really for Jus...
what wattage are the subs and amp? if your subs are more wattage than your amp, your amp will blow fuses as cant handle the output to your subs. for example. you have 2 500 watt subs and a 300 watt amp, that is no good as amp isnt powerful enough. if you have 2 500 watt subs you need at least a 1200 watt amp to power them both. 200 watt more than the combined wattage of subs as amps should never be turned up to max as they tend to blow and overheat more quickly. 80% volume on amps is reccomended by installers and manufactures.
Feb 27, 2011 | Diamond Audio D5-600.4 Car Audio Amplifier
Which amplifier i should use with JBL CS-1205T
this sub woofer tube has a rms rating of 275 watts... try using a kicker or orion 600 watt mono amp to run this. the brand name is what tell you about how good an amp is for instance the names i just mentioned rate their amp by standard play frenquencies where as other lower brand names rate their amps by the max out put on certain subs at certain frequencies which may lower their impedance and create more power although you will never play your sub at those frequencies. as for the max power of your sub of 1100 watts that is more than like only at a certain frequency so always only double your rms rating of your sub to find max power handling.
Jan 29, 2011 | Sony Xplod Amplifier XM-SD51X - Class D...
Have SONY Xplod 1000watt dual ch. amplifier pushing two 12" MTX Terminators. About a week ago my my Sub on the right side quit working, while the left side sub is still banging hard as ever. I...
Check your subwoofer for resistance. It is more likely you blew a sub than a channel on the amplifier. If your subwoofer has no resistance, which can be checked using a multi-meter, then it is blown.
Jan 17, 2011 | Sony Xplod XM-1652Z Car Audio Amplifier
800.2
Well when you blow a sub it can definantely short your output fets in the amp.
Nov 09, 2008 | Rockford Fosgate 800.2 Car Audio Amplifier
ELA 500.I
While I don't have any first-hand experience with either Bazooka amps or Memphis subs, this review pretty much says what I initial thoughts were. The amp will do the job without much fuss, so it mainly depends on whether you can get it for a good price.
BUT........
There could be a issue with your sub. According to Memphis, your sub (assuming it's the single voice coil version) is only good for about 250W RMS (let's ignore peak power for now). The ELA500.1, on the other hand, puts out 375W RMS at 4 ohms. You could very easily overpower your sub with that amp.
Mar 13, 2008 | Bazooka (EL10190PP) Car Audio Amplifier
Amp light is on but no power to my subs!
Hi There.
When you say the 40 Amp fuse blew. Was it your mains battery fuse or was it the fuse on the amplifier? If it was the fuse on the amplifier then you may have hurt the amplifier. The Kenwood KAC-8101D is a 1000 Watt monoblock amplifier. Therefore if you say that 1 of your woofers is not playing, then it is almost certainly blown if you are sure it is connected correctly. Try disconnecting it and only running the woofer that tries to play. If this woofer is still working correctly, you will notice a drastic drop if the sound of your bass. The reason for this is because you have changed the impedance load on your amplifier due to the fact that the other woofer is not working. Have your working woofer checked and replace the faulty woofer then you should be banging again.
Hope this helps!!
Jan 30, 2008 | Kenwood KAC-8101D Car Audio Amplifier
Powers on but no sound
Check the main amp fuse under the hood, even if it looks good just change it. Often times that light on the amp can come on just from the power amp tunon wire. Try a friends subwoofer box just to make sure the connectors on your box are good, and if that doesn't work then give me some more details....year/make/model of car, what kind of sub, what types of things do you see on the side of the amp....is there a green light as well as a red light?
Aug 18, 2007 | Xtant A3001 Car Audio Amplifier
My 7801 doesnt turn on
check pwm circuit amps turn on with 3-4 volts on mosfet gates ic 494, 5252or 555 controll these.hit me up for more
Apr 03, 2007 | MTX THUNDER7801 SUPER AMPLIFIER CLASS D...
Car Audio & Video Logo
29 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
