Question about Cameras
I have a digital camera DSC-W520 which is currently not working since its lens doesnot come out when turned on and also i have restarted put out the battry and battery is also in fully charged state b
I have a digital camera DSC-W520 which is currently not working since its lens doesnot come out when turned on and also i have restarted put out the battery and battery is also in fully charged state but also its not being a solution. How ever it would be better to say that my lens has been jammed inside and i could not take any picture
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Cameras Master
  • 102,366 Answers
Posted on Dec 02, 2012
iwhitman2055
SOURCE: Olympus digital camera wont turn on
First: thank you, for suggesting battery terminals. It was failing to power on intermittently for some time; the problem became more-and-more frequent until it would not come on at all. Cleaning the terminals saved my camera! Second: for others, let me suggest plain old pencil erasers as a good way to clean electrical contacts (something I learned from HO model railroads as a kid). A vigorous rub with the brand new eraser on the end of a pencil cleaned the battery contacts inside the camera.
Posted on Jul 29, 2006
  • 188 Answers
SOURCE: Power/lens Problems
it seems that the lense movement is jammed. Have you dropped the camera? just have a close look from the front side of the camera, does the lense assembly seems to be pressed or moved aside by some extra preassure? if no physical disalingment is visible may be some sand or dust partical is obstructing the movement of the lense assambly. needs a help from camera repair shop.
Posted on Sep 14, 2006
ginko
  • 19396 Answers
SOURCE: Lens error, restart camera
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Posted on Jul 05, 2009
Rammsteins
  • 300 Answers
SOURCE: sony Cybershot DSC-W150-turn power on, lens zooms
Hi!
It's probably stuck focus. Contact your local Sony service center, but if they ask too much, you can contact me at toms.safranovs@gmail.com and I will give you a good price.
I work in Sony service center.
Tom
Posted on Jul 29, 2009
BillB-SA
  • 2761 Answers
SOURCE: Battery is fully charged but camera does not work
If the camera has recently been dropped you may have lens damage that is preventing it from powering up. If it hasn't been dropped your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera and give them a full charge (assuming that you are using rechargeable batteries). This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced or the camera may have a problem that requires professional repair.
Posted on Dec 09, 2009
Camera is dark
this a problem with the LCD screen.
However you must troubleshooting with replace the batteries, sometimes some batteries has the effect memories. 2) use some adapter for to bypass the batteries, if work is o.k .
But if doesnot resolve the problem you must change the LCD screen, or problem with associates circuit around the SYCON Microcontroller or CPU see the diagram you have 2 options a) do it yourself b) or go to the repair shop.
God bless you
Jul 21, 2012 | Sony Cyber-shot DSC-W50 Digital Camera
Zoom not working in video mode
That is correct. You can zoom in and out before starting the movie, but you cannot zoom while recording.
May 15, 2012 | Sony Cyber-Shot DSC-W530 Digital Camera
Camera doesnot come on. The lens comes out twice or thrice and then disply says "turn the power off and on again". Same thing happens every time I put the camera on.
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success.
Jan 14, 2011 | Sony Cyber-shot DSC-W70 Digital Camera
My dsc w55 says access and and restart the camera, but it doesn't work.
Bang it on the table.
Turn it on again and when the lens comes out, hold on to it gently. The viewfinder should spring into action.
Aug 09, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
My Sony Cybershot DSC-W120 Super steady shot Camera won't turn on
I have the same problem, but when I remove the MS Pro Duo card (1GB) from the camera it works fine again. The memory card works fine in a pc memory card reader. Is there a problem with the Sony camera built-in card reader?
Aug 21, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
Flash doesnot work how does one charge the flash on a Sony cybershot DSC-H3
Some of the popup flashes seem to be defective on this product. Mine is. I am returning mine under warranty.
May 03, 2008 | Sony Cybershot DSC-H3 Digital Camera
Help!!
the only thing that can be done but may not fix it is to push reset switch under battery compartment door (pinhole)..also make sure you do use fresh batteries.Use good batties not cheap batteries because these camera require good current to drive ..if batteries are good and it also acts up with charger ..then sorry but lens would need replacement
Oct 28, 2007 | Sony Cyber-shot DSC-W100 Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
