Question about Peavey CH1 Speaker
  • Verne Koti May 11, 2010
    same size as what came out of the fuse holder.
    take it to a reputable sound co or electrical wholesaler ,
    auto accesories car parts place.
    If no markings on this fuse check the other fuse
    contact manufactuer
    look at amp to check output WATTAGE
    (2400 Watt is approx 10AMP)and make the fuse slightly smaller amperage than the amp.
    No mention of how many speakers connected to the amp either ,
    That is very important too............
    Hope this helps ,Let me know if you require more help,Thanks
  • 226 Answers
SOURCE: Peavey valveking 212 - no pilot light on power on
Hi, are you saying , the sound is very low?
Are the valves ok and do you have the correct voltage going to the heaters?
Looking at the diagram, are the valve mounted directly to the PCB's, if so go over the solder joints and make good any dry joints.Very common in all valve amps.
Check for any leaking or bulging capacitors, a capacitor checker will come in handy here, just measuring them with a meter is not really good enough..
I am still looking at the schematic, so bare with me as i'n not really a valve person, but i'm gonna help.
Regards - Anthony
Regards - Anthony
Posted on Mar 03, 2010
  • 59 Answers
SOURCE: Peavey Pr-15 fuse blown, speaker
Actually its pretty funny thing with those speakers is the "fuse" is Actually called a Lamp in this case. These are what they call a " Red Dot Fuse ". in all the years i've been doing this i've never thought to look up the value haha. Just have to know there are Red Dot lamps and Blue dots and No Dot. If you examine the LAMP you should see somewhere close to the ends ON THE GLASS a color dot of some kind. almost like someone painted it on there. Red Dot Lamp. any parts distributer for people like Harbinger, Peavey, and B52 will KNOW what your talking about
Posted on Sep 06, 2011
SOURCE: i have 2 peavey sp 5 and a pwavey 2600 amp . i
Ok this is not the correct way to wire this scenario up, you simple turn on the crossover on the back of the 2600 and send channel a to the sub which is crossed over inside the amp, and channel b will power both sp5s no problem. You can basically converting to a 3 way mono rig but the amp has all the crossover and routing necessary to add the 118 sub and power it appropriately, i do this all the time djing with the exact same gear list :) hope it helps
Posted on Jun 26, 2012
  • 505 Answers
SOURCE: how do i remove the front grill of my peavey sp 5 speaker.i noticed that they have screws that needs a torx screwdriver. does anyone know what size torx screwdriver it is and if i loosen these screws
This issue is already on this site. Check the following link:
Questions Answers for Peavey get front grill off
Posted on Feb 09, 2015
  • 67 Answers
SOURCE: I need to know what size fuse for a peavey XM-6 300 H series I need to replace
It should be a 5 amp fuse, and usually states that around the fuse holder on the rear.
Posted on Oct 14, 2015
Oct 14, 2015 | Peavey Music
What size fuse peavey XM-6
Fuse is 5 A for 120 VAC and 2.5 A for 220-230 VAC, usually 5 x 20 mm.
Oct 14, 2015 | Peavey Audio Players & Recorders
Peavey xr3800 mixer
I don't know anything about your model of mixer but I suspect a blown internal fuse. With the power disconnected, open it up and replace the fuse with the original size. Put it back together with a couple of screws and power it up. If it works-great! If not take it to a repair shop,
Dec 10, 2013 | Audio Players & Recorders
I have a blown tweeter on my SP3 and I want to replace it but I don't know how to get it out of the enclosure?
There are a number of versions of SP-3, but normally you would remove the screws holding the horn into the cabinet, take out the horn and then unscrew the driver from the horn. At that point, either replace the diaphragm on the driver or the whole driver.
Aug 17, 2013 | Peavey New Peavey Sp3 15" 3 Way PA Speaker
Contact Peavey toll free at 877-732-8391 or by email at,
Jan 26, 2013 | Peavey Valveking Vk100 Guitar Head
How to take the grill off a peavey sp-5
Most versions are obvious, but the newer version where there are no screws on the grill edge require you to remove the bottom plate on the cabinet by taking off the feet and stand adaptor. Once the bottom is off, you'll see the grill is mounted in a slot. With the cabinet on it's back lift and pull the grill and it will slide up and out of the slot.
Jan 25, 2013 | Peavey SP 5 2-Way 15 Speaker
Whats the wattage of the bulb used in peavey sp2 crossover, my sp2 peavey speaker bulb is blown
The lamp is an "1156" lamp... replace with that part number. Here :
Or you can find it at auto parts store.
LIKELY the polyfuse device is ALSO gone... Probably similar to this one (1.1 amp, trip 2.2 amp):
or this one (1.85 amp, trip 3.7 amp):
Jan 11, 2011 | Peavey SP2 PA Passive Speaker
Peavey CH1 Speaker Logo
618 people viewed this question
Top Peavey Audio Players & Recorders Experts
Vito Vacirca Jr.
Michial Gueffroy
Are you a Peavey Audio Player and Recorder Expert? Answer questions, earn points and help others
