Question about GE Washing Machines
What causes my GE washer to let the water run out of the bottom of the washer?
GLWP2000MOWW
  • 57 Answers
SOURCE: GE front loading washer leaking
With only a limited amount of information, I would guess your door seal may be worn....but how can you check it? Take a reqular piece of paper (8.5x11) and cut a strip 1x11. Open the door and while holding onto the paper strip, put the strip in the TOP of the door and shut it to see how the seal 'feels' when you try to pull the paper out. It should be very hard, if not impossible to pull the strip of paper out. Now, do the same thing with the bottom of the door. Does it appear to be much easier? Without knowing the age of the machine, I might question the door seal. You might also want to check to see if the door might not be bent just a bit. Do this by placeing a long level vertically along the front facing with the door open, then check the door for level. It may be as simple as bending the top of the door out while you bend the lower part in.
Good Luck
Posted on Feb 23, 2008
memturbo
  • 226 Answers
SOURCE: wwsr3090t2ww ge washer leaks water
there are alot of parts that can fail that would cause a leak .
here is a site with a breakdown of said parts .
http://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=WWSR3090T5AA&mfgModelNum=&fkMfgID=2
Posted on Mar 27, 2009
  • 4 Answers
SOURCE: Kenmore Top Load Model 110 Washer Floods
could be a water inlet valve or the water level swich is defective
Posted on May 28, 2009
dniro592006
  • 121 Answers
SOURCE: Water leaking from bottom of washer
Tub Seal is leaking and needs to be replaced
Posted on Jun 11, 2009
blueextc3221
  • 15935 Answers
SOURCE: GE prodigy washer Water remains in the bottom of the basin after teh cycle has ended
There is a water pump in the machine which pumps the water out of the outer tub and into the drain, after the wash and rinse cycles.
It is possible that this pump isn't working properly. I think if it weren't working at all, you wouldn't be able to get beyond the wash cycle.
It has been my experience that small articles of clothing may get washed or spun out of the inner tub and into the area around the pump pick up, thus partially blocking the flow to the pump.
It's also possible that the drain hose from the pump to the drain may be partially clogged.
It is also possible that the pump doesn't run sufficiently long to get all of the water out because its' motor gets hot and shuts down or because of a problem in the control mechanism which manages the the starting and run time of the pump.
First, I would unplug the washer from the wall outlet and probe under the inner tub, or possibly remove the tub to see that there is no blockage from clothing.
It's also possible that things left in clothing pockets like paper clips, small plastic items, etc. can get into the pump and lock up the impeller.
If you're sure it isn't blocked you can then run a "short cycle", no load and water only, and watch to see how much water comes out of the discharge hose where it's hung on the drain pipe.
It should gush out, and tub should be free of standing water prior to the start of the first rinse cycle.
If it does not, then you'll have to access the pump and clear it of obstructions or replace it, if defective.
As it drains, it should start spinning slowly, then speed up as it drains; the final portion of the spin cycle is very fast.
Essentially, the spinning tub wrings out the clothes using centrifugal force.
With the water remaining in the bottom of the tub, it would appear that it is:
a) not spinning long enough, or
b) there is something preventing all the water from getting out in the time allotted by the timer to perform this task.
A fair handy man can get to pump either from the rear of the machine with back plate off, or by removing the cabinet cover from the frame, depending on the model of the the machine.
As always - before attempting any repair, UNPLUG THE UNIT!
When clothes are wet at the end of a cycle, check these:
Motor coupler
To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
If it's spinning when you lift the lid, the coupler is fine.
If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning
If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve
Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
Water remains in the main tub of my GE washer and causes an odor
I myself would not run a minidisc in a GE washer. Only a Maytag.
Sep 08, 2012 | Audio Players & Recorders
Door won't open on my GE gfwh2400lww
Gather towels, shop vac, mop....Open small door at the bottom of the washer on the outside. Remove the small door and cup that's attached to it. Be prepared for a washer full of water!!!!!! Reach in, turn the nob to the left so tht water and debris can escape. You need to do this every 5 loads to keep debris from building up and causing the door to lock.
Aug 31, 2012 | GE GFWH2400LWW Washer
Water leaks out front center of door during the
Check the door gasket for any damage. A rip or a tear could be the cause of the leak.
Jul 20, 2010 | GE WSXH208A Front Load Washer
Water leaking from bottom of washer. anyone know possible cause?
hi,
Check whether the inlet valves are leaking. To test this shut off the water supply, if the water stops then replace the washers water intlet valves..
Mar 29, 2010 | GE Washing Machines
GE Dishwasher no water upon start, humming, blinking lights
Seems like the anti flood is activated when water (even a small amount) appears on the bottom of the machiene. This is usualy a leaking pipe but can also be caused by a clogged pipe. Most machiens do have a plastic pipe that (from the flat water tank) feeds water to the bottom of the machiene in case of an internal fault. The anti flood is normaly a polystireen float with micro switch on the base of the washer. This automatically puts the outlet pump on to drain the water. The machiene does not work exept the outlet pump in this mode.
Jan 18, 2010 | Dishwashers
The water does not shut off even after it reaches the proper level it continues to run and it overfills and leaks out the bottom of the washer the clear hose is not clogged and we blow into it we can hear...
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
Sep 14, 2009 | GE WVSR1060A Top Load Washer
Will a clogged drain hose cause the washer to shut off ?
That might be a problem if there is water build up on the bottom but if its shutting off I dont think it will do that unless it is a new model. You could have a component going out if its an older model. If the entire washer is going out it might be your dishwashers electrical circuitry. Hope this has helped, good luck
Jul 14, 2009 | GE Nautilus 24" Built-in Dishwasher
Wwsr3090t2ww ge washer leaks water
Mar 27, 2009 | GE WDSR2080D Top Load Washer
Water leaks out from underneth
We have a WDSR2080D GE washer and had the same exact problem. We replaced the water pressure switch ($30) to see if that was the cause. A malfunction in this switch would cause the leaking from the bottom because there would be no way for the washer to "know" that the tub was filled to the appropriate level--causing the tub to overflow. Then we found out that the water pressure switch was not the cause and found that the water pump switch was the problem. A malfunction with this switch would cause water to continue to fill the tub without stopping--which would cause an overflow. Think of it as turning on a faucet without the ability to turn it off. Happily, we are now with a working and non-flooding washer at only a minimal expense. Note that the schematics for your washer are not in the manual. They are inside the control panel, which means you have to take the front of the washer off as well as the control panel in order to see what's really going on. My guess is that GE would rather consumers not try to fix their own appliances so they put instructions and helpful hints INSIDE the appliance.
Jul 23, 2008 | GE WDSR2080D Top Load Washer
Washing Machines Logo
43 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
