Slow and wont connect to internet - Computers & Internet
    Novelist:
  • 250 Answers
Main reason behind computer slowing down and internet problems is windows internal errors. to fix this issue you need to troubleshoot PC. Here are some troubleshooting tips that will help you to fix this problem:
--Scan your computer with an antivirus
--Apply De-fragmentation on your system
--Delete all temporary files
--Run disc clean up
--Fix registry errors.
-- Update Network Adapter drivers
If problem still occurs then use a system utility tool like PCFresher to fix this problem. WebRepOverall ratingThis site has no rating(not enough votes)
Posted on Dec 05, 2012
    Scholar:
  • 156 Answers
Need complete details about your system and net connection to answer this question
Posted on Dec 02, 2012
Why does my "hp envy 15-k073ca" drop internet connections?
There can be several reasons why your Internet connection is slow or keeps dropping. To resolve the issue, you can refer to the guidelines mentioned on the link below:
http://windows.microsoft.com/en-us/windows/why-internet-connection-slow#why-internet-connection-slow=windows-7
http://www.wikihow.com/Speed-up-a-Slow-Internet-Connection
GuruAid.com
Mar 18, 2015 | Internet Computers & Internet
Tip
Solution on a slow Internet connections Problem  The major  causes for a slow...
The major  causes for a slow Internet connections. A poor-performing connection can be caused by broadband router configuration issues, wireless interference, or any of several other technical issues with your home network. Follow these steps to diagnose slow Internet connections.
 1. Broadband Router Settings
As the centerpiece of a network, a broadband router can be responsible for slow Internet connections if configured improperly. For example, the MTU setting of your router will lead to performance issues if set too high or too low. Ensure your router's settings are all consistent with the manufacturer's and your Internet Service Provider (ISP) recommendations. Carefully record any changes you make to your router's configuration so that you can undo them later if necessary.
 2. Wireless Signal Interference
Wi-Fi and other types of wireless connections may perform poorly due to signal interference, which requires computers to continually resend messages to overcome signal issues. Household appliances and even your neighbors' wireless networks can interfere with your computers. To avoid slow Internet connections due to signal interference, reposition your router for better performance and change your Wi-Fi channel number.
 3. Internet Worms
An Internet worm is a malicious software program that spreads through computer networks. If any of your computers are infected by an Internet worm, they may begin spontaneously generating network traffic without your knowledge, causing your Internet connection to appear slow. Run antivirus software regularly to diagnose and remove these worms from your computers.
 4. Running Background Applications
Some software applications you install on a computer run in the background, quietly consuming network resources. Unlike worms, these are programs designed to do useful work. Peer to peer (P2P) programs in particular can heavily utilize your network and cause connections to appear slow. It's easy to forget these applications are running. Always check computers for any programs running in the background when troubleshooting a slow network.
 5. Faulty Network Equipment
When routers, modems or cables fail, they typically won't support connections. Certain technical glitches in network equipment, however, adversely affect performance even though connections are maintained. To troubleshoot potentially faulty equipment, temporarily re-arrange and re-configure your gear while experimenting with different configurations. Try bypassing the router, swapping cables and changing network adapters to isolate the slow performance to a specific component of the system.
 6. Service Provider Issues
Internet speed ultimately depends on the service provider. Your ISP may change their network's configuration, or suffer technical difficulties, that inadvertently cause your Internet connection to run slow. ISPs may also intentionally install filters or controls on the network that can lower your performance. Don't hesitate to contact your service provider if you suspect they are responsible for a slow Internet connection.
 www.temabcomputerssolution.blogspot.com
on May 20, 2010 | Computers & Internet
Advent 9315 wifi
How are you connecting to the internet?
1. Wireless
2. Wired
This can have an effect on the speed. A wired connection is not subsceptable to any interference and wont slow down from it.
A wireless connection can be slow because of the router, other things that broadcast radio signals, other things that broadcast non radio signals (like flourescent lights.)
How are you testing the speed? Unless you go to a website that has a speed test program or you are running a speed test application, there is no way to know for certain that your speed is what you believe it is. Your speed can also change due to the amount of people on the internet and other things like equipment failure outside your house.
Mar 31, 2014 | Zyxel Computers & Internet
Lenovo thinkpad slow download speed?
clear out anything you are not using....meditate :)
Feb 16, 2013 | Lenovo ThinkPad Computers & Internet
Slow internet connection on a 256kbs connection.
Not sure from the description whether this is a router problem or broadband Internet connection problem. If the Internet is slow, this is a good article for finding the source of slow Internet: Simple Troubleshooting for your Broadband Internet Connection.
Feb 21, 2011 | Computers & Internet
Slow web searching , sometimes wont display page
Need more information...
What type of internet connection you have? what is your operating system? is the problem with wired connection or wireless? what are the firewall rules?
You should start by resetting the router, if you have no change, check with your ISP (Internet Service Provider) the connectivity of your modem.
Have fun!
Dec 29, 2010 | Linksys Wireless-G WRT54G Router
Hi,, i hav problem regarding accessing youtube this site was not responding.. when i try to open this site there is a error opening in page,, it wont open so watz the reason behind these, can u assist me...
may be ur internet connection is a slow html connection. youtube requires good internet speed for bufferin videos. otherwise go in network connections and repair ur connection.
Sep 01, 2010 | YouTube Videos
I download movies but so slow download more upload
that is to do with your internet connection you have only purchased a low speed package ring your inet company and tell them your problem they will tell you exactly what speed you have and offer minor solutions to improve the speed but it wont make much difference and they may offer to upgrade you to a faster one but it will cost you
Oct 07, 2009 | Acer Aspire One PC Notebook
Belkin Wireless G router
If you're computer is slow in the internet connection because of this router, that will be cause by the router since this device has a built in firewall inside it and the speed of internet that you have before when directly connected to your modem wont be same ecause of that, and there's no way you can add up a memory on this router, if you want try to update the frmware of the router and that will help in speeding up the connection....
Hope that helps........
Oct 06, 2008 | Belkin (F5D7230-4) Router (587009)
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
