Question about Proscan PS36810 TV
Proscan ps35182 I have one and 2 problems whit my proscan, shot down after 1 minute. the problem before raster no signal display on the screen. after that, I can't turn ON I have no thing. Can you tel me please what can I do to fix the problem. thank you. by jeanaudiotron.
    President:
  • 3,130 Answers
Call a tech if you have no experience with TV repair! this is not a place to be experimenting .
Posted on Jun 09, 2007
KP-61HS30 has sound but no video
1) the problem you have is lack of raster , the problem in tv has 4 phase 1) raster 2) picture 3) synch 4) sound.
2) test the power supply , check the horizontal output +125vdc ,vertical output from +80vdc, +al other circuit +12vdc, if there are missing fix it, see the diagram attached.
3) TEST the signal from tuner,i-f, detector, AGC
GOD BLESS YOU
Jul 12, 2012 | Televison & Video
I HAVE A SONY CYBER SHOT DCS W210 WHIT ERROR E:91:01 IN DISPLAY TANK YOU hOLA TENGO UNA CAMARA SONY CYBER SHOT DCS W210 CON EL ERROR E:91:01 HAY ALGUNA FORMA DE SOLUCIONARLO? GRACIAS
Follow the procedures given below to have a perfect fix for your problem.
  • Press Menu button.
  • Toggle across from REC Mode to setup
  • Toggle down thrice from camera to setup 1
  • Toggle across into sub menu
  • Toggle down from four times to Initialize
  • Toggle across again to the sub-menu
  • Toggle up from cancel to OK
  • Press center button to accept the OK choice
  • Screen changes and so press okay again
  • It should restart the camera
  • Opening on the 'Clock Set' screen
Toggle down to cancel and use the camera and make sure that you have the camera to flash, if it works try again in the Auto function. If it is still not working dont worry follow the steps again two or three more times, As this is related to a software error message and not a hardware malfunction. If it is working then don't forget to set your Clock.
Thank you !!
Aug 18, 2010 | Sony Cyber-shot DSC-W70 Digital Camera
Thin diagonal lines on screen. How to adjust whit balance ,screen end focus?
Is that diagonal thin line about 10 to 20 degree slant? And then you have a very bright raster?
Then you set the flyback(for tube tv), I think its "screen" voltage is set too high adjust it slowly to lessen the brightness. It is commonly a small pot on the side of the flyback together with the focus pot.
If you have raster turn the tv on, use insulated screw diver, then slowly turn the knob to the direction(CC or CCW) where your raster go dim.
Be careful your dealing with live and high voltage. If your not inclined on electronics better not to.
Oh BTW, set your settings to normal.
Sep 30, 2009 | Televison & Video
Tv screen is white; sound is ok
Need more information about you problem. Does the white screen appear on all functions.Does any input signal like a dvd or vcr show picture. If so, then you have a problem with signal connection coming from the television signal source, like a cable or satellite box. You need to check the connecting cables to see if they are outputting signal. Try using different cables to connect the signal source to the television. If this does not work. Try hooking up the signal source to another television to make sure you are receiving signal from them.If all this seems to be working fine and you are sure that you are using the remote control inputs correctly, you may have a problem the video input signal board on the television. You can contact PROSCAN at this web address. www.oncorpus.com. Go to customer support and ask for their technical assistance with your problem. The telephone number for PROSCAN service is 1-888-977-6722. I hope this has been of help with your problem.
Apr 08, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
''no signal'' message on blue screen after watching for 10-30 min
First try another signal input like a DVD player or other source, is the signal displayed ok? Then you have lost the signal on one input from whatever the device is.
Mar 16, 2017 | Spectroniq PLTV3250 32 in. LCD TV
PC or monitor, signal problems
your monitor is telling you it's on it's last legs..either that or your compaq has a bad video section. either is more vital than a video cable being loose.
Mar 10, 2008 | Computers & Internet
W300i phone displays white screen
The flex cable is damaged, it needs to be replaced. It is what connects the motherboard to the lcd screen in your phone. I had to replace one not to long ago and it had the same problem and now it works. Hope this helps. Good Luck!!!!!
Nov 05, 2007 | Sony Ericsson W300 Cellular Phone
Display screen problems.
Either the LCD or the connector/connections are at fault.Check them physically for a loose connection due to humidity or dust. Replace LCD and we can help for original LCD and instructions. mail us further. Siva
Jul 27, 2007 | Sony Cyber-Shot DSC-P41 Digital Camera
Pink horizontal line when the tv is powered on.
1. White raster with no signal, washed out looking video with signal. Access the service menu, "menu 0357" use the audio button to select "video chroma" adjustments, use the video button to select item "40 - AGIW", use the adjust button to change the setting to 0, then press the enter button to store the change.
Jun 13, 2007 | Mitsubishi WS-55315 55" Rear Projection...
Proscan PS36810 TV Logo
187 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
