Sf-60cp went off during washing
After starting went off in between
I have sf p120lj washing machine its showing F1 message what should i do advice
I have sf p120lj hitachi washing machine its showing C1 message what should i do advice
Jan 26, 2015 | Washing Machines
WHAT IS SF CODE ON WASHING MACHINE
A bit difficult to provide guidance without knowing make and model of washing machine. But in some washers like Simpson SF code means motor overload and could occur due to too much suds in the wash. Maybe using incorrect detergent.
Aug 29, 2014 | Washing Machines
Why is there an 'SF' code showing and continuous beeping from our Simpson encore 756
there are different sf codes for different faults. try googling the sf number fault to find problem.
May 25, 2014 | Washing Machines
Washing machnie hitachi sf 100 fjx displaying F9 during rinse
hitachi washing meching not worjing display f9
May 02, 2012 | GE Washing Machine
Hitachi SF-P95FJ WASHING MACHINE ERROR CODE F9
if you have Hitachi nw-d8ax f1 error check water sensor f3 error check rinse filter f9 error do not know where the error but I did repaired, remove back panel and right hand side inside polithine cover find blue connector its with 2 wires remove it and switch machine it will give f3 error with sound reconnect the socket its started working
mail me if yours working I will give you more tips nava@netintec.com cheers
Oct 29, 2010 | Washing Machines
Hitachi washing machine. Model:SF-P90DJ Fault code F9
my hitachi model SF-120 HJ is washing machine cleck c2 n c4 warning stop f9..........
Jul 29, 2010 | Washing Machines
Lanzer vibe 416 1000watt Amp stay in protection mode completey
I'm no pro but I've fixed a few amps in my time.When you had the 12's hooked up it was working fine you say,but when you upgraded to 15's is when the problems started. You probably bridged it too low of ohms and it maxed the amp out,it got too hot and started to burn up the channels. all that matters when you buy speakers and amps. The 12's was probaly 4 ohm coil speakes and the kickers are 2 ohm. The kickers bridged together positive to positive, negative to negative would bring it down to 1 ohm load witch I dought the lanzar can handle. If your a fix it yourself kind of person like me. I can point you in the right direction on where to looke for parts to fix your amp....
Jan 30, 2008 | Car Audio & Video
Hitachi SF-H900TPX Washing Machine not working properly
Open machine's service panel and check whether the motor spins. Let us know with your results and we will see how could we assiste you further.
Aug 31, 2007 | Washing Machines
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
