Question about Hitachi 51S700 51" Rear Projection Television
Hitachi 51S700 won't turn off
When turned off, unit goes to 'Magic Focus' (focus is now way off), then shuts down. It will immediatly turn back on the picture, but no audio (unit thinks it is off). Magic Focus is set to manual only, yet it comes on every time you turn off the TV.
    Top Expert:
  • Hitachi Master
  • 14,553 Answers
Some kind of a problem likely in the magic focus area--is the set showing a error on screen if you engage the magic focus?
One thing not to do is disconnect the sensors inside the screen as that could make things worse......
Posted on Dec 02, 2012
  • 3 more comments
  • Al Floyd Dec 02, 2012
    SD Tech - There are no errors showing. The TV will auto-run the magic focus on shutdown even though it is set to only do that manually. Also, once the magic focus action has completed, the TV will go black, then the picutre will return but without audio. I'm assuming the TV *thinks* it is powered down. When you hit power again, the TV will go black then return the picture with audio (no magic focus actions). The magic focus button on the TV doesn't work (all the others do).
  • SD Tech
    SD Tech Dec 02, 2012
    Some thing stupid to do here---follow power cord inside the set and look for up to 3 mechanical relays---They are well known to stick shut when should not be engaged---a moderate tap with a screwdriver handle on each will free one if stuck shut---
    I found one relay just past the power cord and gave it a tap - to the left of it looks like a box capacitor (I tapped it as well), but no change in condition.
    that box capacitor (?) is to the right, not the left...
  • jeff smith
    jeff smith May 07, 2014
    Tapped the relay BOOM. problem solved. My relay was stuck. The TV turned off normally after tripping the stuck relay. I have having the same weird magic focus problem where it wouldn't shut off.
3 Suggested Answers
ginko
  • 19396 Answers
SOURCE: TV will not turn off with remote or manually
That means that you either need to buy a replacement remote (or use an universal remote) , or you need to replace the TV IR sensor, that is a small board located inside tv.
Posted on Apr 17, 2009
barbu51
  • 566 Answers
SOURCE: Hitachi 51F500 magic focus wont work, blue has
Sounds like your blue convergence module is faulty along with a few resistors. There is two convergence modules in your set(stk-392-020) and when one fails, the both of them are usually replaced with a matched pair .If you have a good knowledge of electronic you may replace them yourself.otherwise you`ll need the help of a tv repairman. Hope this help. Good luck
Posted on Nov 17, 2009
Magic focus on my 60" Hitachi isn't working.
If your magic focus is not working your convgence has failed. Read this Tips page here on fixya for more details.
Jan 22, 2013 | Hitachi Televison & Video
Screen will not turn off
Model does not sound like Hitachi but if it is have you unplugged the set? The magic focus is a auto convergence circuit in the Hitachi sets.
Nov 01, 2012 | Hitachi Televison & Video
Magic focus error Hitachi 52
The model number you have selected here does not have magic focus--if you really want a answer post the correct model number.
SD TECH
Dec 12, 2009 | Hitachi 52LDX99B 52" Rear Projection...
Dec 15, 2008 | Hitachi 46GX01B 46" Rear Projection...
TV will not turn off with remote or manual have to unplugged
I suspect the unit might need service. If it were only the remote, new batteries would, of course, be in order. But that part about the manual power button being ineffective suggests something else is affecting the set. Sorry.
Sep 27, 2017 | Hitachi 46GX01B 46" Rear Projection...
One half of picture is distorted
to create the total geometry in the tv is needed a system called Convergence.Convergence amplifiers are damaged in this unit, magic focus cannot work because magic focus works to level computer and controls the amplifiers damaged. this repair is for a technician because an adjustment is needed after the amplifier's replacement.
Oct 09, 2008 | Hitachi 61SBX59B 61" Rear Projection...
Magic focus
If your model has magic focus it should be behind the flip down cover on the front panel next to the auxillary video inputs
Jul 04, 2008 | Hitachi 43F300 43" Rear Projection...
Magic focus
That's a DP23 chassis, why replace the deflection board? Does magic focus come on the screen? Does it just no converge the picture? If so, it's likely that the convergence amps have failed.
That unit takes two STK392-110 Sanyo built Ics at board position Ic04 & Ic05. If you replace them I'd upgrade to the STK392-150's for greater reliability.
Bill
Dec 13, 2007 | Hitachi 51F500 51" Rear Projection...
65S500 will not turn off
Check to see if you have it set to do the Magic Focus on turn-off. It is in the menu under setup.
Nov 06, 2007 | Hitachi 65S500 65" HDTV-Ready Rear...
Wont turn off, goes to magic focus
enter your menu set up and turn off auto focus and see what happens then,also check your other settings while your there.
Sep 09, 2007 | Hitachi 51F500 51" Rear Projection...
Hitachi 51S700 51" Rear Projection Television Logo
133 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
