Sanyo MODEL DP46848 LCD TV HAS SOUND has vertical lines top to bottom.Question what's the DATA BUFFER on this TV? This TV IS three years old some videos on You Tube say to replace T Con. Would like to
  • 85 Answers
T-con board is situated on top of screen and will have a ribbon cable going from t-con board to av/tuner board common fault is ribbon cable loose or dry joint
Posted on Dec 03, 2012
5 Suggested Answers
Slapnuts1975
  • 51 Answers
SOURCE: Here we go again
The problem is in the LCD panel itself. I am an authorized tech for Sanyo, and in the Chattanooga TN area. Contact Sanyo at 1-800-877-5036. At the prompt hit the 0 key, and then ask for customer service. They will be more then happy to assist.
Posted on Aug 06, 2008
  • 71 Answers
SOURCE: vertical
what have you picked. to the tv
Posted on Mar 05, 2009
  • 3 Answers
SOURCE: Sanyo DP46848 Color lines running from top to
twist the screen. hold opposite corners top and bottom and give a small twist.
Posted on Apr 28, 2011
budmrtn
  • 11361 Answers
SOURCE: SamSung TV Model LN-T4066F Model Code
Look for bad caps in the power supply first.
http://s807.photobucket.com/albums/yy352/budm/SAMSUNG/Samsung%20LN-T4066F/
Posted on Jun 03, 2011
No picture used to have lines at the top
It could be your current problem, but it is not the problem causing the lines.
You can send the main board to us and we can test it and see how it behaves, possibly fix it, but we likely won't be able to take care of those lines.
Feb 24, 2014 | Sanyo DP46848 LCD TV
No picture there used to be lines at the top
It sounds that there is some loose contacts with any cable connectors, or to any solder terminals at the circuit board. It will be best to contact any service technician, or the authorized service center for Sanyo. Gopakumar Gopalan Google
Sanyo flat screen tv about 2 yrs old has thin colored horizontal lines down the right side
Nothing you can do about that...get used to it or change the TV.
It's a defect in the panel that can't be reliably fixed.
Feb 15, 2013 | Sanyo DP46848 LCD TV
Sanyo 46
It sounds that the connections between T'Con board and panel have some loose contact. Re-seat all the flat cables and check. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to the latest updates. It will make search easy. There are more than 1300 posts to different brand TVs now. Pull up older posts there.
Nov 27, 2012 | Sanyo DP46848 LCD TV
Sanyo DP46848 LCD TV has black screen with colored vertical lines
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jun 16, 2017 | Sanyo DP46848 LCD TV
I have a sanyo 46" lcd hdtv model #dp46848. its
i would say buy new as it sounds like your whole datata buffer on the rear left has failed
Mar 19, 2011 | Sanyo DP46848 LCD TV
Sanyo 46 IN. tv DP46848. The left 1/3 of screen is dark
It is a common problem for this model of a Sanyo TV, it uses a Samsung or Chime LCD panel.
The problem is the data buffer IC soldered on the flat flex cable between the LCD panel & the buffer board that gets damaged or loose soldering. If you be able to fix yourself, you may find some videos on YouTube, it will show you how to fix the buffer problem.
Jun 01, 2017 | Sanyo Televison & Video
My Sanyo DP46848 LCD TV display goes black when turned on.
My mother's was doing the same thing (purchased 2008). Put up with it about 6 months and took it to a repair shop. Bottom line - the display panel has a flaw in and will cost more to replace than the tv cost. See about it now it yours is still under warranty.
Oct 21, 2009 | Sanyo Televison & Video
Vertical
Jul 12, 2008 | Sanyo DP32746 32 in. LCD Television
Televison & Video Logo
94 people viewed this question
Top Televison & Video Experts
Electro Med Services...
