posted by DaBridge on Jun 07, 2007
Having problems with the Front Panel Connectors, and cannot get the motherboard to power up. I have not been able to locate the MSI user's guide via the web. Your help will certainly be appreciated.
Thanks,
Miles
2 Other Users Have The Same Problem
Comment by Guest, posted on Mar 29, 2008
power on password
Comment by Madmardigan, posted on Mar 14, 2008
I need a pin out diagram of the front panel wiring harness connector for a MS-6389 system board. I'm replacing the AT case and the connectors are different.
Best Solution
posted on Jun 08, 2007
Try to jump start it with a screwdriver, just touch the screwdriver to the place where the power connection (from the front) cable plugs in. If this works, you need to plug the power into there, if not, you may not be hitting the right spot, or the psu/mobo is bad.
Rating Locked! (?) DaBridge has rated this solution as Thanks for Trying
Suggest a new solution for this problem
Post a New problem for Gateway MS-6389 Ver.1 S462
Email this problem
Email this problem
Can you Help with these Motherboards problems?
Repair Service
Find Motherboard Repairman Near You:
