Who made the CDC ch4000R 5 disc changer. The tray does not move
    Top Expert:
  • Audio Player... Master
  • 44,921 Answers
What is the brand of the changer?
Posted on Dec 04, 2012
  • 85 Answers
SOURCE: Tray won't open.
Drive belt for draw is duff needs replacing
Posted on Jan 08, 2009
techman
  • 3130 Answers
SOURCE: my CD changer's disk tray keeps opening up, refuses to play discs
You have a problem with the try control circuit. It could be the switch is leaking across itself. Could be a problem with the tray motor control IC, or the Microprocessor is not reseting the open tray line correctly, or theres a cam assembly inside the unit that tells the microprocessor where everything is by means of small micro/leaf type switches thats out of alighnment or broken. If its seven years old, you got more then it was designed for and I would'nt invest a dime or the time into the repair of this unit. Time to take a trip to the electronics store. Good luck
Posted on Jul 21, 2006
SOURCE: Panasonic stereo with 5-cd changer
Hi, I have a Panasonic SA-ak25 system. I played one cd then inserted a second. When the second cd had finished it ejected but the first cd is still in the player, When i try to eject it the lights start to flash and it always stops on no (4) can anybody help. Bob.
Posted on Aug 08, 2008
SOURCE: Panasonic SCAK16 5-Disc CD Changer Problem
You need to clean up the cd sistem and put it on time again
Posted on Nov 04, 2008
petraman7
  • 1175 Answers
SOURCE: Disc door keeps opening.
The drawer belt may also lift the laser up to meet the CD . If the belt is bad , the CD player will kick out the CD.
Change the belt.
Try studiosoundelectronics.com
or
mcmelectronics.com
Posted on Jan 12, 2009
Why does my yahama cdc-505 cd changer not play cd, or change tracks
This is a result of the deck kicking out you disc as an unacceptable media. This usually means that it can not read the data on the disc or the necessary TOC (Table of Contents).
The other possibility is that your draw in detection switch has gone bad and when the processor- control type, tries to load a tray or close the drawer it is not getting the door closed signal. Depending on how the unit is programmed it might just sit there and do nothing or in your case throw the disc back out.
It is kind of telling you it wants to go see a Technician.
It could also be a bad belt that loads the Pickup assembly- it might be good enough to move the drawer in and out but the Pickup assembly needs more torque and it might not be there.
Dec 13, 2012 | Yamaha CDC-505 5-Disc CD Changer
I have a cdc 675 CD changer, When I close the draw it stays close about 10 seconds, the display reads "open" and it opens back up whether there are discs in it or not
It's reporting that it (correctly or incorrectly) detected that the drawer has not fully "closed", i.e., it thinks that there was a "jam" while the drawer was sliding towards the "closed" position.
This sounds (pun intended) like you need to take the unit to a qualified audio/video technician, to trouble-shoot, and maybe check the "alignment" of the drive-tray.
Sep 30, 2010 | Yamaha CDC-675 5-Disc CD Changer
The disc tray of my Yamaha cdc-745 CD player does open properly.
It's the belt inside the machine - open tray and look in front left side and you will see it. Easy to change out with new one.
Dec 13, 2009 | Yamaha CDC-745 5-Disc CD Changer
The changer does not detect CDs in it. After
Optical pick up replacement required to rectify this problem
Nov 26, 2009 | Yamaha CDC-697 - CD changer 5-Disc CD...
5-Disc CD player
your tray is out of track, have to place it back. not that easy but you can try. dont force it of you can damage the tray or gears
Nov 21, 2007 | Yamaha CDC-765 5-Disc CD Changer
The CD changer is locked and won't move
Open the player. (Undo the screws) take off the cover and nudge the tray gently take a look around and see if the white plastic gears are locked up. A little gentle prodding should loosen it up. Barring that call Yamaha!
Feb 25, 2007 | Yamaha CDC-675 5-Disc CD Changer
My CD changer's disk tray keeps opening up, refuses to play discs
Jul 21, 2006 | Yamaha CDC-755 5-Disc CD Changer
105 people viewed this question
 Grubhead
Grubhead
