Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
Hoover spinscrub won't dispense water or soap
It was working the last time I used it. I have taken the handle apart, seems to be depressing down just fine.. Took off brushes, etc and cleaned out filter and sprayed the heck out of everything with water. Brushes and motor seems to be working fine. Water and soap come out of top tank just fine when I press them with my fingers. The only things I can think of is that the motor needs to be cleaned (I have 3 dogs) or the tubes coming from the tank are clogged. (although this seems unlikely that both would clog at the same time). Any ideas? I don't know how to get to the motor to see.
reddevil6
  • 1673 Answers
SOURCE: hoover steam vac v2
Either you need a new tank, or there is a problem with the platform that the tank sits on. The tank has to sit correctly or it won't work.
Posted on Jan 06, 2008
micromaster
  • 3614 Answers
SOURCE: Hoover SteamVac LS F5899-910
Did you try to clean first the unit..
Posted on Jun 01, 2008
SOURCE: Hoover Steam Vac Spin Scrub Carpet Cleaner won't suck
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=728884
Hoover Steam Vac Spin Scrub Carpet Cleaner won't...
Posted by hoofbeats1 on Jul 01, 2008
My machine is a little more than a year old. I have used it about 5 times. It started leaking the third time I used it. The fourth time I took it out, the brushes would not spin (I did clean them and rinse them after use each time).
Now the engine screams and won't **** anything up. Do you have any suggestions? My last Hoover Steam Vac was great and lasted for 3 years! Hi,
I have a Hoover Dual V SteamVac F7425-900 that the brushes won't spin. The lint screen is clean & the brushes switch is in the on position.
It dispenses & sucks up the cleaning solution & water; just no brush action. Help
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The only thing that I can recommend is that you may have a bad switch, some vacs may have a broken belt or the drive mechanism inside the Hoover Dual V SteamVac F7425-900 in or by the brush assm section and is need of repair. Please check the trouble shooting section of the owner’s manual if you’re needing help and to save money. If you don’t have one then contact the Hoover factory cust serv. So, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jul 02, 2008
keemo68
  • 1263 Answers
SOURCE: Brushes won't turn on a Hoover F7426-900
there should be a rubber belt that drives the brushes on either side. hope this helps. please rate this.........thanks
Posted on Aug 30, 2008
  • 294 Answers
SOURCE: No Suction
The water channel hose could be torn. you can check by removing the lower tank and tilting it backwards, it is located in the lower section. could also be the filter cover. it is needed for full suction control.
Posted on Oct 28, 2009
Will not dry or suck up water at all...BRAND NEW
If it's brand new your best bet might be taking it to a Hoover service center. That'll have a year warranty on it so the fix would be free.
Apr 06, 2013 | Hoover H3044 FloorMate SpinScrub Wide-Path...
Hoover steam vac dual v carpet cleaner has stopped dispensing soap. Water is still flowing fine
You probably have a solenoid valve which has failed and will not open. This will require replacement of the valve. For temporary use you can mix a soap solution and put it in the rinse tank. The correct mix is 5 ounces of Hoover shampoo to a gallon of hot water.
May 17, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
Part broken to dispense cleaning solution.
Most of the time you can only get the tank. part number 42242134
Jun 11, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Water and cleaning solution will not dispense unless I hold it for a while
check the belt on the pump it should be a cover on the side pull the belt to the pump if its glazed replace if not then clean the shaft old soap may be on there.
Oct 03, 2008 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover steam carpet cleaner
does the trigger feel like it is doing anything? if not you may find that your handle lever guard is broke and needs to be replaced. this is the plastic piece at the top of your handle and can be removed by taking out the screw. if this isnt it let me know.
Sep 23, 2008 | Hoover SteamVac F5914-900 SpinScrub...
NOTHING WORKS
Check the foam filter on the underside of the recovery tank lid, make sure that it has at least a 1/4 in. gap from the top. There also is a filter, from the bottom, it has a red frame, pull out far enough to clean it.
On the bottom of the tank, depress the vale to make sure water is coming out. With the tank off, squeeze the trigger, is the rod inside the handle pushing up against the diaphram, if it is, there maybe a problem with the reservior asm and will have to be replaced.
Jul 04, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Hoover carpet steam clear
Is this a V2? The F5914-900 just has a solution tank. The V2 has a small soap tan attached to he water tank. If you have a V2, the seal or plunger at the bottom may be bad and can be replaced. The reservior asm. that the tank sits on may be bad. You may have a problem with the tank in which case it will have to be replaced.
May 08, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Model F7441980 Hoover Dual Action Spin Scrub Wide Path
You will have to replace the tank, and it will come with the soap dispenser attached.
Mar 30, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Will not dispense water or solution
On the bottom of the tank is a valve, push it in and see if water comes out Where the tank sits, there is a black round seal, is it in the proper place? The rod in the handle hits just under that seal, with the tank off, you can see if the rod is movin up and down when you depress the trigger. The resevior asm. may be bad, that is what the tank sits on.
Mar 10, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Hoover Floormate SpinScrub won't dispense cleaning liquid
I had the same problem and was preparing to take it back, the last thing I tried was to 'reseat' the handle -- I removed it then snapped it very firmly back into place. That did it, it's working beautifully now!
Nov 25, 2006 | Hoover H3030 FloorMate SpinScrub 500...
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
266 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
