Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Sounds like running, then sounds like it turns off
Awaken friday night by loud fan noise, seemed okay. Saturday night, ice was melting and foods getting warm. Cleaned coils and made sure air was circulating. Sounds as if running then clicks as if shutting off,then clicks like running again over and over.
  • 3 more comments
  • debby5555 Jan 11, 2009
    Around compressor
    How do you get "start relay" off compressor
  • debby5555 Jan 15, 2009
    Refridgerator working great. Thanks for suggestions.
  • Ken Bledsoe May 11, 2010
    Compressor is on the bottom might have to pull fridge away from wall to access this area. And also there is a cardboard cover you will have to remove.
    When you hear the clicking sound is it coming from under the fridge? Down around the compressor?
  • 306 Answers
The black box on the compressor is held on by a wire clip just release the clip and make sure you have the frig unplugged. Remove the relay by prying off they are a little tight so will have to grab it and pull it straight off. Get you model number on your refrigerator and take the relay with you and get a new one from a appliance repair parts house. Be sure to take note of what color wire goes where. there are three connections on the frig. ken
Posted on Jan 12, 2009
  • 700 Answers
Sound like the start relay is out on the compressor. Take the model number and serial number to the parts house and ask for the start relay for the unit. they are on the compressor and covered byu a black box cover. remove the old and put on the new one and turn the unit back on. good luck
Posted on Jan 11, 2009
  • Todd Born
    Todd Born Jan 11, 2009
    that is the star relay.
  • Todd Born
    Todd Born Jan 15, 2009
    im glad that it worked for you.
BUZZING NOISE FROM MY HEAT PUMP
Take a look at this YouTube page that explains with good videos what are some of the common problems with heat pump noise. The one that seems dominant is the defrost cycle a heat pump goes thru when it melts ice off the evaporative coils. In defrost cycle, The compressor runs but the cooling fan does not, so you will hear a loud buzzing sound and the unit sounds like it is stalled...because only the compressor is running to generate heat to melt coil ice.
https://www.youtube.com/results?search_query=American+Standard+5000+Heat+Pump+makes+a+buzzing+noise
Defrost cycle noise video:
https://www.youtube.com/watch?v=wudLk0WoIVo
Mar 06, 2015 | American Standard 5000 Heat Pump Unit
GE Side by Side Refrig - loud noise behind the ice maker section Model PSS25SGMB BS
it sounds like the evaporator fan blade is hitting some ice that has built up around the blades i have seen this happen a lot on g.e. SxS lately,if you can remove the ice maker and dispenser you can see the fan blade,if you dont want to do this then shut down the refrigerator and leave freezer door open and heat it carefully with a hairdrier to speed the process up to melt this ice then restart it and the noise should be gone
Aug 30, 2012 | GE PSS25SGNBS Side by Side Refrigerator
We were using the microwave the other night and it started making a loud noise like the fan was running (although the fan was not). We let it sit for awhile and try to use it again but the noise came...
The loud noise and no heat means that the magnetron has failed. It the part that generates the microwaves that heat the food. When it fails it shorts out, causing the transformer to heat up. That is what was causing the burning smell. The cost of a replacement magnetron is around $130-150 range so it may not make sense to have it fixed.
Mar 24, 2011 | Maytag MMV4205 Microwave Oven
Hi - My refrigerator has begun making a very loud noise - like an airplane engine - when it kicks on. After a few minutes the sound recedes but is still louder than normal. The bottom freezer is way too...
it sounds like ice built up arounnd the fan blade probably from leaving the bottom freezer door open and warm air got in and froze up the air ducts or you have a defrost problem but if you hear a cracking sound it sounds like the heater is coming on but can't melt out all the ice.try this,take out all the food out of the freezer,unplug it,get a hair dryer and blow the hot air at the back wall where the vent holes are and melt out all the ice,when you look into the vent holes and don't see anymore water dripping down you can plug it back in and with your hand feel to see if you can feel the air blowing into the fridge section,if you feel the air then you melted out the ice and if the noise is gone then the evap fan motor is still good,if there's alot of ice and snow on the back wall you should remove the panel and then melt out all the ice with the hair dryer.also if you have another fridge you can unplug the fridge and let it melt out on it's own for like a day
Feb 10, 2011 | Refrigerators
Freezer door was left open, now after one day freezer is not cold
you can unplug it and let it defrost on it's own or you can melt out the air ducts,you'll have to shut down the freezer,remove the shelves and remove the inside back wall of the freezer section and melt out all the ice in the right hand corner and any ice on the coil.when melting out the air ducts be careful not to damage any of the plastic or styrofoam on or inside the wall,heat up the area with a hair dryer for a couple of minutes and then move to the coil,after a minute or two go back the the air duct,when you think it's melted out enough turn the freezer back on and with your hand check to make sure the air is blowing into the fridge side,if you can feel air blowing then your all set,if there's any ice left in there the defrost will take care of it.if you have another fridge to put your food in or if the food can't be refrozen i'd just unplug it and let it melt out on it's own over night and you can clean it out while everything is out of it.let me know how you make out and good luck,hope you didn't loose that much food
Jun 06, 2010 | GE GSS25SGMBS Side by Side Refrigerator
GSH25JFRFWW evaporator fan makes loud deep noise at times
GE refrigerators have a faulty design, and so don't defrost completely, so ice builds up in the evaporator coils and on and in the evap. fan motor. Melting the ice will make the fridge more efficient, and the fan quiet again.
The slow, easy way to fix is take out all the food, unplug the fridge, leave doors open all day. Ice will melt, and all will be fine ... for a few months, until the ice builds up again. The fast way is here.
Nov 15, 2009 | GE Refrigerators
Our LG bottom freezer refridgerator is 2 years old. It is making a whirring noise that stops when the door is opened. It can get pretty loud at times.
The whirring sound is the fan that blows cold air into the refrigerator. It is supposed to stop when the door is opened. If it is making a loud noise there may be ice built up in the fan housing. Turning the power to the refrigerator off for a 2-4 hours may allow any ice in the fan to melt. If you do not open the freezer during that time the frozen food will not defrost.If the noise continues, you may have to take the fan apart to make sure it is not frozen. It is probably located behind the back inside panel of the freezer.
Nov 02, 2009 | Refrigerators
Temperature not low enough
check fan at the back of refrigerator or you have defrost problem
Apr 05, 2009 | Kenmore Refrigerators
GE Profile Refrigerator (Model #20) w/freezer on the bottom
If the problem disappears (for a while) when the freezer reaches 32F, then I know what the problem is.
The GE Profile refrigerators (and likely other models as well) often don't defrost properly, especially in humid climates. So they can develop ice buildup internally, especially if the air vents at the back of the freezer are blocked by frozen food. Once that happens, that ice can interfere with the cold air circulation booster fan that runs when the freezer temperature is too warm. Then you get a LOUD buzzing noise from the fan blades, as they bang into the ice.
The immediate "solution" is to be sure nothing blocks the air vents, and then to melt the ice that interferes with the fan. You can turn the fridge off for a while (with the food removed so it doesn't spoil), and/or get a hair dryer and heat the inside back of the freezer, until the ice melts and falls away from the fan. (Just be careful not to block the nozzle of the hair dryer, or it may burn out from overheating!)
But the ultimate solution is to buy another refrigerator, one that is NOT a GE! And that makes me sad, because GE used to make GREAT refrigerators. My last GE refrigerator is nearly 20 years old, and still works well, and it does so QUIETLY.
May 26, 2008 | GE Profile PSW26P Stainless Steel Side by...
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
96 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
