Question about Hayward Pool Products Hayward Xstream Filter 150 Sq Ft, 1.5 HP Pump/Timer
I had a pond installed with a Hayward Xstream pump and filter. I cannot get the manuel from the contractor. It has been about 6 months. I need to know how to service it. The model numbers are CC 100925 and SP 15921FP. Thanks.
  • 565 Answers
Manual for the filter:
Manual for the pump:
Your model numbers don't match _any_ Hayward products.
The above manuals aren't an exact match to your model numbers, but should be in the ball park as far as maintenance and service along the Xstream product line.
Posted on Feb 14, 2009
How to take off locking ring from top lid to replace on Hayward xstream filter sysyem,I need to take the locking ring complently off so I can replace locking ring
Hi Mark, The link below is a user manual for a hayward xstream filtration series, This is from that manual...
Depress safety latches (located on the underside of the locking ring handles) and unscrew locking ring in a counter-clockwise direction. Remove lid from filter body.
Hope this helps....CHEERS..
Mar 27, 2016 | Pool & Spa
How do I unlock my Hayward Xstream filter. I can not get the filter top off
Same problem, brand new filter... I'm 190 lb guy who works out 6 days a week, I can't open this filter for the life of me. If I knew it would be so hard to open I'd have opted for a less expensive sand filter. Cartridge are supposed to keep the water clearer but if you can't open the filter to clean it without spraining a wrist or having a heart attack (or both) what good is it? Beyond mad, I'm thinking of just biting the bullet next spring and buying a filter that actually opens. Even the brand new Hayward chlorinator didn't work properly this past summer, i,thought they were supposed to be good products, dealing with their customer service is pointless.
Sep 13, 2014 | Hayward Pool Products Hayward Xstream...
Hayward xstream pump vibrates and makes noise and we have done everything in the manual to correct the problem i'm tired of taking it apart to put it back together to get the same results NOISE I...
i had the same problem tryed every thing then i called hayward they told me the housing in the top of the filter was worped they sent me out a new filter to and locking ring and cartridge for free awsom call customer service 1-908-355-7995
Jun 22, 2011 | Hayward Pool Products Hayward Xstream...
We have a hayward xstream pool pump for our 18' above ground pool that my daughter got through make a wish last august. we cleaned the cartridge yesterday and when we replaced the cartridge it started...
Try taking the pool filters cartridge out and following these steps to make sure that it is installed properly.
1. Clean debris from bottom of filter tank.
2. Replace element evenly on the collector hub in bottom of the filter body.
3. Place lid evenly on filter body and turn Easy-Lok™ ring clockwise until the safety latches engage securely.
4. Close and secure drain plug (located at the base of filter body).
5. Open air relief valve (Turn lever to left).
6. Open valves (Optional suction & return valves).
7. Prime and start the pump.
8. Once air has escaped the filter and a steady stream of water is flowing from the air relief valve, close the air relief valve and note the pressure gauge reading.
Jul 15, 2010 | Hayward Pool Products Hayward Xstream...
Running at 20psi
If you pressure is low on these pool filters, there are several things that you will want to check. First, make sure that your system strainer baskets are not dirty or clogged. Also, check the suction side of your pump to make sure that there are no leaks. Make sure taht you filter cartridge does not need to be replaced or cleaned. Make sure your pump is properly primed and that the pump impeller vanes are not blocked. Make sure that your strainer basket is not broken to allow debris in.
Jul 04, 2010 | Hayward Xstream 150 Sq. Ft. Cartridge...
I can't get the lock ring off to get the cartridge out to clean! It spins about half a turn then stops, HELP!
There should be two buttons (for lack of a better word) on the underside of the ring you push up on to unlock as you turn. Once it is off turn the pump on for a second or two to pop the lid off. When putting back together close air bleed and fill bottom of filter with water then put the top on and as the water tries to drain back to the pool the suction will help pull the top down into place.
Jun 25, 2010 | Hayward Pool Products Hayward Xstream...
After cleaning the filter the pressure went down to 19 PSI. normally it goes down to 10 PSI. I checked the gauge and that is good
It may not be clean enough or maybe, if you have had it for awhile, you should replace it. Just MHO...Lee
Nov 22, 2009 | Hayward Xstream 150 Sq. Ft. Cartridge...
Haywards pool filter,model 244t
hi mike, unfoutunatley repairs of this nature are not very good, a replacement is the best course of action
Jan 22, 2009 | Hayward Pool Products Hayward Xstream...
Open Questions:
See all Hayward Pool Products Hayward Xstream Filter 150 Questions
Hayward Pool Products Hayward Xstream Filter 150 Sq Ft, 1.5 HP Pump/Timer Logo
238 people viewed this question
Top Hayward Pool Products Garden Experts
Dennis Key
Dennis Key
john h
Are you a Hayward Pool Products Garden Expert? Answer questions, earn points and help others
