Question about Samsung Clothes Washer Power Control Board - DC92-00161C
Samsung washer clicks & gives me a F1 code - Samsung Clothes Washer Power Control Board - DC92-00161C
2 Suggested Answers
kevin_getz
  • 1031 Answers
SOURCE: samsung washer error code f1
What kind of detergent are you using? F1 in most cases means that the wrong type of detergent is being used. If it's a front-loader, you should be using h3 detergent.
Posted on May 22, 2012
What does an F-1 code mean on the display? washer will not start.
power problem
  • Whirlpool Fault Codes - AppliancePartsPros.com www.appliancepartspros.com > Appliance Repair Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • Washer Diagnostic& Repair - F1 Error Code power supply ... www.youtube.com/watch?v=BAVS9mI3JLQ
    • BY APPLIANCEVIDEO.COM
    • 4 MIN
    • 65K VIEWS
    2014-02-07 · Troubleshoot your trusty Whirlpool Top Load Washer that has these following symptoms: F1 Error Code At: http://www.appliancevideo.com To ...
  • Whirlpool Cabrio f1 error and how to fix it https://whirlpoolcabriof1error.wordpress.com Control board W10189966 will work with the Whirlpool model numbers listed at the bottom of this page. These models include the Maytag Bravos and Kenmore Oasis.
  • whirlpool F1 code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • 68 POSTS
    • FIRST POST: 2008-07-28
    2009-09-29 · Discuss whirlpool F1 code in Washer Repair. "whirlpool cabrio washing machine displays f1 code. have already pushed cancel and restart to no avail.
  • Cabrio Washer by Whirlpool F1 Error Code - Facebook www.facebook.com/CabrioWasherByWhirlpoolF1ErrorCode Cabrio Washer by Whirlpool F1 Error Code. 793 likes. Got the F1 Error Code? Tell your story! Share ALL your issues with this washer to warn others...
  • Whirlpool Fault Codes - Appliance Help Online appliancehelponline.com/whirlpool.html Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • May 04, 2016 | Whirlpool WTW8200YW Cabrio Top Load Washer
    I have the maytag series 4000 and got the f2 code. I have cleaned the.hoses and wven replaced the drain pump. Is thete a rest button? It is still not working and.shows the same code
    F2 code is water level to high
    Washer Error Codes
    Below is a list of washer error codes for HE & conventional top load washers and front load washers. As more error codes are found or published, we will add to the list. Right now you will find error codes for Asko, Fisher & Paykel, Frigidaire, GE, Kenmore, LG, Maytag, Samsung, and Whirlpool. This list might not be complete and should be used for reference only.
    Asko Washer Error Codes
    • F1--Water supply/low water fill.
    o 1. Check water supply to machine.
    o 2. Replace water inlet valve.
    • F2--Water level too high.
    o 1. Plugged/Bad water pump.
    o 2. Faulty water valve.
    Sep 19, 2014 | Washing Machines
    Samsung washer error code f1
    May 21, 2012 | Samsung Clothes Washer Power Control Board...
    What is code F1 mean on the Whilrpool Cabrio. The washer stops about 5 seconds when I first put it on.
    Ok the Cabrios have alot of problems. In your owners manual there is a big page where it gives you errors codes and what to do it also givees you a diagnostic feature which helps determine the problem. This site gives you the fault codes and what to replace. F1 means primary control failure. Also sometimes when the control board is bad something else could also be wrong. Good Luck
    F1 (F60-68)
    Primary Control Failure F then 1 flashes when there is a primary control failure. Replace the machine control assembly.
    See Accessing & Removing the Electronic Assemblies. F1 (F60-68)
    See Accessing & Removing the Electronic Assemblies.http://www.advantagesupplyfl.com/WhirlpoolCabrioWasherFaultCodes.html
    Jun 02, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
    Washer starts to fill then stops /now warsher wont wash
    I too was having the same problem and I almost paid to have it repaired, which would have cost a few hundred dollars, thanfully I called the recall line after reading some of the other post on here and my machine was elgible for a upgraded on the control panel so didn' t cost anything for us. Sears told us that the F1 code is a miscommunication in the control panel, basically the machine is confused and don't know what to do so it stops and gives that code. Hope it helps!
    Jun 19, 2010 | Kenmore Oasis HE 27082 Top Load Washer
    F1 code coming up on my Oasis HE washer
    YES! Serious problem...more annoying than anything else. Wait until your machine stops at the spin cycle and displays "F1" again. We just had a repair tech out today and received a quote of $384+ to fix/replace the circuit board. Kenmore & Sears are fully aware of this problem and have issued a recall on a model that is one digit off of the model I have yet they will not do anything about this even though it is the same problem. These machines are huge dogs!
    Jan 15, 2010 | Kenmore Oasis HE 27082 Top Load Washer
    F1 code on oasis washer, machine will not work
    HI. This code is in reference to a failed Machine/Motor Control & Water Pressure Transducer module. This is the main initiator of the unit. The F1 is and indication of a failed component, or circuit board structure.
    This module must be replaced, asap. The part number will be
    W10189966. Click here to view an exploded diagram of the control sector. This module will be located just under the control sector panel housing. The affected part will be labeled number 1
    Jan 04, 2010 | Kenmore Oasis HE 27082 Top Load Washer
    I have the exact same F1 code problem
    F
    This was under recall last year.
    Telephone Whirlpool at 1-800-253-1301. Whirlpool has acknowledged the F1 fault and will send a serviceman, free parts and labor, to correct the problem concerning the "famous" F1 fault. This is even for washers out of warranty! This concerns model WTW6600 series washers.
    Tell them that your Whirlpool Cabrio washer has been receiving the F1 error code repeatedly, with the same symptoms as reported by hundreds of other customers online. You were told that there is a recall for this known defect in the control board, and are requesting that Whirlpool fix the problem including parts & labor.
    Be sure to get the authorization code from them so the service person cannot argue about costs.
    Basically - this is a problem (faulty chip) on the main controller board of the unit... and the entire board must be replaced with the updated version.
    Give the warranty a try (even if it is out of warranty)
    CLICK HERE to see the part that is going to have to be replaced.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
    Aug 23, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
    Samsung Clothes Washer Power Control Board - DC92-00161C Logo
    Top Samsung Washing Machines Experts
    Jaime Hernandez
    shaun taylor
    Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
