Paper size of printer driver and ink ribbon type do not match
No print.
  • 40 Answers
SOURCE: hp laserjet p3005dn tray1 manual feed problem
you can choose mp first in "paper handing" printer menu or print tray1 is A4 default in properties of printer software.
Posted on Jul 27, 2009
SOURCE: Error E02530 on Canon W8400 PG
Hello
when i load a material in printer, it shows me this error E0200B (size undetected) i loaded another photo papers and photo rolls but it steel show me the same error.
what should i do to solve this problem ?
thank you
Posted on Dec 06, 2010
SOURCE: Printer Problem in HP-1280 Printer
go to printer folder , select properties and go to paper /quality , browse to A3, select, apply, OK
check print preview before sending your document
Posted on May 20, 2008
  • 162 Answers
SOURCE: won't print on the photo paper
You didn't mention what paper you're using so for simplicity I'll assume it's an HP paper. When you installed your printer, it installed profiles for the HP papers and associated them with the printer. If you go to the Printers and Faxes folder, right-click on your printer and choose Properties, you'll get a dialog box for your printer. At the top it'll say something like HP Photosmart D7200 series Properties. Click on the Color Management tab, it'll show you a list of profiles associated with your printer. Your paper profiles will be named something like HP PS D6100_7100_7300-Advanced Photo. Don't worry about the names or selecting them, as long as they're listed you're OK. If they're not listed you'll need to re-install your printer software. Close the Properties box and the Printer and Faxes window.
Now go to LR, select your photo and go to the Print module. Scroll down the right panel until you get to the Print Job Header at the bottom. If you don't see any choices, click the triangle and open it up. Uncheck Draft Mode Printing and Print Resolution. Under Color management, click the triangles to the right of Profile:. This will open up a list of all paper profiles visible under LR. If you don't see your HP paper profile, click Other and it will list all the paper profiles on your system. Find your HP paper profiles and click the box next to each, this will make them visible in the LR drop-down. Hit Close and select the profile for the paper you're using.
Now click the Page Setup button, that will bring you to a dialog box where you can select your printer, page size and layout. Make these choices and then click on the Properties tab for your printer.
Now things get a little sticky... The HP driver has an infuriating habit of changing settings you've already made when you change something else. You'll come up in the Printing Shortcuts tab, ignore this and click on the Features tab. It's been quite a while since I used this printer so I may be wrong about the right order to do things, but here's what I remember: First, select your paper size. Click the Borderless box if that's how you want to print or uncheck it if not. Your Paper Source should be Main Tray for 5x7 or larger, Automatically Select for 4x6's that go in the top holder. Select Best or Maximum dpi for Print quality, then choose Paper Type, set it for Other Photo Papers since you'll be selecting the paper profile from LR. Hit the radio button for Print At Actual Size, go to the bottom and turn Photofix off.
Now go back to the top and click on the Color tab, select Print In Color and under Color Management, select Application Managed Colors.
Now go back to the Features tab and make sure nothing has changed. If it has, reset it, check the Color settings again, check the Features settings one last time. Then hit OK and you're back in LR.
Before you print, go over to the left panel and hit the Add button at the bottom. This will save all your settings and lots of time and aggravation by not having to go through the whole process again next time you want to print something. Name your profile with at least the size, layout and paper type you've set up and it will show up under User Templates. Then the next time you want to print on the same paper at this size, you just have to select this template.
Now hold down the Alt key, hit Print,
Posted on Nov 24, 2008
SOURCE: printer reads paper size or type is incorrect
Hi cfiore,
Plz click on follwing link and follow the document, that help you to resolve the issue,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01413548&jumpid=ot_recdoc/c01518785/en_us/c01413548/loc:2&custom_solutionid=rd_c01518785&lc=en&dlc=en&cc=us
Regards,  raj_p5983
Posted on Jan 20, 2009
Hp j6480 printer wont print keeps sending a paper mismatch message
Paper mismatch errors occur because the product scans the width of the envelope before printing. If the paper size setting in the printer driver does not match the paper actually loaded in the product, the product reports a 'Paper Mismatch' error. The message saves paper and ink by preventing print jobs from accidentally printing on the wrong paper. For example, the print job might be for a 101.6 x 152.4 mm (4 x 6 inch) photo, but there is letter-size paper loaded in the product. The error message displays to make sure that ink is not wasted on the wrong paper type. try this out , disable the automatic paper type sensor.
  1. Open the Print dialog box.
    1. In Word 2003, click File , and then click Print
    2. In Word 2007, click the Office button (c01850900.gif ), and then click Print .
  2. Make sure that your product is in the Name drop-down list box, and then clickProperties .
  3. Click the Features or Paper/Quality tab.
  4. In the Paper type drop-down list, click Plain paper .
  5. Click OK to close the Properties dialog box.
  6. Click OK again to print the current print job.
Feb 24, 2011 | Digital Products Hewlett Packard OfficeJet...
Out of paper error
The paper settings in the print driver must match what is loaded in the product. NOTE: These changes do not change the default print settings. The print settings return to default the next time the program opens.
  1. Open the document that you were trying to print when the issue occurred.
  2. Click File , and then click Print . The Print dialog box opens.
  3. Click the button that opens the Properties dialog box. Depending on the software program, the button might be Properties , Options , Printer Setup , Printer , or Preferences .
  4. Click the tab that provides paper type and size settings. The tab might be Features or Paper/Quality .
  5. From the Size is drop-down menu, select the paper size that matches the paper in the tray.
  6. From the Type is drop-down menu, select the paper type that matches the paper in the tray.
  7. Click OK , and then click OK again to print the document.
Nov 23, 2010 | HP Photosmart 8250 InkJet Printer
What's a 016-799 error code mean?
016-799 Wrong combination of print parameters, like selecting to print on custom size paper and setting [Auto] for [Paper Source] on the printer driver and [Auto] for [Paper Size] in trays 1 to 4 on the control panel.
Check the print parameters.What we did is match the documents page size and paper type to the printers (A4) then we could print.
Oct 04, 2010 | Xerox WorkCentre 7328 Multifunction laser...
Why do my pictures look faded with up and down stripes?
Check the paper to make sure you are using the correct paper type for the project. If the paper is too fibrous, the ink applied by the printer might not fully cover the print surface.
  1. In the program being used for printing, click File , and then click Pring . The Print window opens.
  2. Make sure the appropriate product is selected, and then click Preferences or Properties . The Preferences/Properties window opens.
  3. Click the Printing Shortcuts tab. Consider modifying some or all of the options in the Printing Shortcuts menu to increase print quality.
    • Print quality : If the quality of the printouts is not acceptable, try increasing the print quality. To print more quickly, try decreasing the print quality.
    • Paper type : If one of the options matches the paper type exactly, select it instead of Automatic .
    • Paper size : Make sure that this option matches the paper loaded in the product.
    To see additional options, click the The Advanced Features window opens. Consider changing the following option: Ink volume : Adjust the amount of ink that prints on a page. For lighter images (less ink), drag the slider to the left. For darker images (more ink), drag the slider to the right. The lighter the ink volume, the more quickly the printout dries.
Press and hold the asterisk (* ) and pound (# ) buttons on the product control panel.
  1. When the control panel reads *******#######, release the asterisk (* ) and pound (# ) buttons.
  2. Press the 3 , 2 , and 9 buttons, in that order.
  3. Press the right arrow button (c00420524.gif ) to select Special Reports , and then press OK .
  4. Press the right arrow button (c00420524.gif ) to select Print Cartridges , and then press OK
Aug 12, 2010 | HP Officejet J5780 All-In-One InkJet...
I REPLACED MY INK CARTRIDGES. I WAS PROMPTED TO
Ignore the error and continue printing. The print job might still be acceptable even if the paper size and paper type settings are not an exact match.
  1. Press Enter on the control panel to clear the error message.
  2. Try the print job again.
  • If these steps resolved the issue , you do not need to continue troubleshooting.
  • If the issue persists , continue to the next solution.
    Use the HP product software, also known as the printer driver, to change the print settings for your paper size and type depending on your version of Microsoft Word.
    1. In Microsoft Word, click File , and then click Print .
    2. Make sure that your HP product is in the Name drop-down list box, and then clickProperties .
    3. Click the Features tab, or the Paper/Quality tab.
    4. Select a paper size from the Size drop-down list.If the required paper size is not in the drop-down list, follow these steps to create a custom paper size.
      1. Select Custom from the drop-down list.
      2. In the Custom Paper Size dialog box, type a name for the new custom size.
      3. In the Width and Height boxes, type the dimensions.
      4. Select the unit of measurement, and then click Save .
      5. Click OK to close the Custom Paper Size dialog box, and then click OKagain to close the Properties dialog box. NOTE: You must exit the Properties dialog box to apply your changes.
      6. Open the Properties dialog box again, and then select the new custom size from the Size drop-down list.
    5. Select the paper type.
      1. In the Paper Type or Type is drop-down list, click More .
      2. Click the desired paper type, and then click OK .
    6. Select the paper source from the Paper Source drop-down list.
    7. Change any other settings, and then click OK to close the Properties dialog box.
    8. Try the print job again.
      Paper mismatch errors occur because the printer scans the width of the paper before printing. If the paper size setting in the printer driver does not match the paper actually loaded in the printer, the printer reports a 'Paper Mismatch' or 'Paper too Narrow ' error.The error message might also display when you load the correct paper, just reinstall the printer driver if above procedure does not helps. Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Jul 10, 2010 | HP PSC 2210 All-In-One InkJet Printer
The button becomes red once I print a test page
The red light means out of paper or ink ribbon. Some people chose not to use the ink ribbon and get thermal direct paper which requires no ink ribbon but The red light means out of paper or ink ribbon. Some people chose not to use the ink ribbon and get thermal direct paper which requires no ink ribbon but the printer has to be told by the driver not to expect ribbon or the red light will come on. Also not having the correct paper height set in the driver will make the red light come on as well so check the advanced tab in the properties of the driver then click printing defaults. In the ZDesigner driver height and width are entered there. In the zebra universal, its the same path but one extra click. Click paper output and enter the size.
Oct 05, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Everytime I turn my Zebra TLP 2844-Z printer on,
The red light means out of paper or ink ribbon. Some people chose not to use the ink ribbon and get thermal direct paper which requires no ink ribbon but the printer has to be told by the driver not to expect ribbon or the red light will come on. Also not having the correct paper height set in the driver will make the red light come on as well so check the advanced tab in the properties of the driver then click printing defaults. In the ZDesigner driver height and width are entered there. In the zebra universal, click paper output and enter the size.
Oct 01, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Dell 3100 CN printer...message on printer reads load tray
Cycle Power on the Printer
  1. Turn the printer off.
  2. Wait 10 seconds.
  3. Turn the printer on.
  4. Determine if the issue still occurs.
Verify There is Paper in the Tray
Verify the Paper Size
Look at the chart below to verify that the paper size meets the 3000cn / 3010cn / 3100cn-series specifications.
Verify the paper size in the tray matches the size set in the 3000cn / 3010cn / 3100cn-series printer´s operator panel.
To verify the paper size in the tray matches the size set in the printer's operator panel, perform the following steps:
  1. Press the MENU button.
  2. Press the down arrow until Tray Settings appears and press the return%20arrow%203100cn.jpg button.
  3. Press the down arrow until Paper Size appears and press the return%20arrow%203100cn.jpg button.
  4. Press the down arrow until the specific paper tray (Tray 1, Tray 2, or MPF) appears and press the return%20arrow%203100cn.jpg button.
  5. Press the down arrow to select the specific paper size, as shown in Figure 1, and press the return%20arrow%203100cn.jpg button.
  6. Press the MENU button.
*1 Denotes country-specific factory default values.
*2 Available for the optional 250-sheet cassette only.
Figure 1 - Paper Size Chart
Verify the Paper Type Matches the Type Set in the Printer´s Operator Panel
To verify the paper type matches the type set in the printer's operator panel, perform the following steps:
  3. Press the down arrow until Paper Type appears and press the return%20arrow%203100cn.jpg button.
  4. Press the down arrow until the specific paper tray (Tray 1, Tray 2, or Multipurpose Feeder) appears and press the return%20arrow%203100cn.jpg button.
  5. Press the down arrow to select the specific paper type, as shown in Table 1, and press the return%20arrow%203100cn.jpg button.
Table 1: Paper Type Chart
All media types that are not Plain 1 should be printed from the MPF only.
Verify the printing preferences on the Dell™ 3000cn / 3010cn / 3100cn / 5100cn-series printer.
To verify the printing preferences is set to print from the correct tray with the correct paper size, perform the following steps:
  1. Click the Start button, go to Settings, and click Printers and Faxes.
    The Printers and Faxes window appears.
  2. Right-click Dell Laser Printer 3000cn / 3010cn / 3100cn / 5100cn-series and click Printing Preferences.
    The Printing Preferences window appears.
  3. Verify the Paper Size drop-down is set to the correct paper size loaded in the specific tray to be printed from..
  4. Click the Paper Tray tab.
  5. Click the Paper Source drop-down menu and select the specific tray to be printed from.
    This sets the size and tray defaults.
Verify the Paper Size From the Printing Application Matches the Designated Printer Tray
To verify the paper size from the printing application matches the designated printer tray, perform the following steps:
  1. Open the application being used to print the document. (Example: Microsoft Word)
  2. Click File and click Print.
  3. Verify the paper size.
Verify the Paper Source From the Printing Application Matches the Designated Printer Tray
  3. Verify the paper source.
Do not replace any printer hardware as this is not a printer hardware issue.
Nov 12, 2008 | Dell 3100cn Laser Printer
Photosmart C6300 pictures are printing very wet and grainy. printer is also very loud - almost as though the parts were scraping and banging.
Sounds like you have the wrong paper setting in your print properties. I would use photo or high bright 24lb paper and set the paper type in your printer properties prior to executing the print job.
Regards,
Worldvet
Nov 12, 2008 | HP Office Equipment & Supplies
8250 hp printer
Adjust the paper settings in the print driver. The paper settings in the print driver must match the paper settings for at least one of the installed paper trays.
  1. Open a document in the program in which it was created.
  2. Click File .
  3. Click Print .
  4. Click Properties . The Printer Properties dialog box displays.
  5. Click the Paper/Quality tab.
  6. In the Size is drop-down menu, select the size of the paper loaded in the unit.
  7. In the Type is drop-down menu, select the type of paper loaded in the unit.
  8. Click OK .
hp website
Jan 29, 2008 | HP Photosmart 8250 InkJet Printer
731 people viewed this question
jasbo
jasbo
