Question about Bosch Classixx WFL 2066 Front Load Washer
Fabric Softener is not being used
I put the fabric softener into the middle draw (marked 'max') but the machine is not using the softener. I can see a hole in which the softener goes into which I guess from there goes into the drum, this does not appear to be blocked. Has anyone else had this problem???
  • Bosch Master
  • 744 Answers
This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Jul 31, 2013
  • Bosch Master
  • 3,463 Answers
It is a very common problem.
Remove dispenser drawer completely from washer, thoroughly wash every part of the dispenser drawer, particularly the conditioner compartment.
Get a strong thin piece of wire, form a right angle at one end about 1" long, and poke it into all the holes in the top of the dispenser to clear any blockage there particularly the hole(s) over the conditioner compartment.
This should solve the prob.
Plz rate my solution.
Thyanks.
Posted on Jan 11, 2009
Where do you put fabric softner
Manually: If you're adding fabric conditioner by hand, be sure not to add it during the wash cycle. The washcycle will clean away much of the softener, so add it during the rinse cycle. Also, try to avoid direct contact with fabrics to avoid stains; instead, pour Downy into the deeper pockets of water.
How to Use Fabric Softener Without Dispenser ' Downy
where do you put fabric softener in the washing machine Google Search
Oct 30, 2017 | Washing Machines
Dispenser fabric softener slot
Fabric Softener Compartment Full Of Water - White Goods ...
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jul 9, 2013 - The small fabric conditioner compartment in the soap dispenser drawer has a plastic cap or tube at the back for the water to siphon up through. ... Make sure the washer is level front to back as well as side to side. .... If the washing machinehasn't been used since there's always the possibility that the plastic ...
The fabric softener part of my washing machine drawer keeps ...
www.mumsnet.com > Topics > Housekeeping
MumsnetAfter each wash, the fabric conditioner part of the drawer is f. ... The fabric softener part of my washing machine drawer keeps filling with water ... Stopped using thedispenser compartment for fab softener and instead did I separate ... see if that clears it up and also try cleaning behind the drawer in case there is a blockage.
Washing Machine ' Fabric Softener ' Problem ' Won't Empty
Jan 16, 2016 | Washing Machines
Water in slot for fabric softener wont drain. Always water in there. Lameez SA Jan2014
Remove the dispenser draw and wash it all out. The most likely cause is that fabric softener has congealed and blocked the dispenser. I hate what softeners do to machines with a vengeance. I would never put any fabric softener anywhere near my machine ever. They cause many problems that are not easily remedied.
Regards
John
Jan 30, 2014 | Bosch Washing Machines
Frigidaire washing machine fabric softner will not dispense out
Hello - There are several things that could cause the fabric softener to not dispense into the washer. Are you sure the liquid in the dispenser after the wash is fabric softener? If it is fabric softener, the solenoid that lets the water into the dispenser is not working. This solenoid is located on the back of the dispenser. It only gets voltage during the dispense time and fills the fabric softener dispenser with water. The fabric softener dispenser fills while the washer is filling for the rinse cycle.
When the washer begins to fill for the rinse cycle, the fabric softener solenoid is energized and water flows into the fabric softener dispenser cup. When the cup is full the water siphons out and softener and water flow into the tub.
If the liquid in the fabric softener dispenser is pure softener you may need a technician to diagnose and repair the problem. The voltage will have to be tested to the softener solenoid and a volt meter is required.
If the liquid in the fabric softener dispenser is water you probably need to clean the dispenser cup. **** will build up in the siphon tube and stop the liquid from going into the washer tub. The incoming water will dilute the softener and overflow the dispenser cup and run into the tub. The instructions for cleaning the dispenser should be located on page 43 of the use and care guide that came with the washer.
If you don't have the use and care guide these instructions will help. Open the dispenser until it stops. In the left rear corner of the dispenser, there is a release that is labeled push. Press down on the push area and you can slide the dispenser drawer out.
Remove the insert from the bleach and fabric softener compartments. Clean the bottom of the insert and the bleach and fabric softener compartments. Reinstall the insert and put the drawer back inside the washer.
To test the siphon action slowly pour water into the fabric softener compartment. When the water level goes above the maximum line stop pouring. The water should all drain out.
Hope this information proves to be helpful however if it is ineffective please contact a professional to move forward accurately.
Oct 26, 2012 | Frigidaire Affinity ATF7000E Front Load...
Roper heavy duty super capacity 8 cycle fabric softener mess
check to see when and where you are to add the softener read the manual for tips look in the trouble shooting guide
Jul 06, 2012 | Roper RAS8445KQ Top Load Washer
Where does the fabric softener and washing powder go in the LG WF-F5207PC 5.5KG top loading washing machine?
Put powdered detergent in the box at the back of the opening of the washer (opposite the control panel when the lid is open). If you use a liquid detergent, dilute it 1:1 with water and pour into the bleach dispenser at the front left of the washer. The fabric softener dispenser is near the bleach dispenser but a little closer to the tub and towards the middle of the left side of the unit. As with a liquid detergent, dilute 1:1 (30ml:30ml) with water before pouring into the dispenser.
If the fabric softener dispenser isn't working, add the fabric softener in the final rinse.
The manual for the washing machine is available here: http://safemanuals.com/user-guide-instructions-owner-manual/LG/WF-F5207PC-_E . You will need to review the unit or enter a security code.
I hope this helps.
Feb 13, 2011 | LG Washing Machines
How to use fabric softener
On this machine the compartment is built to hold your softener until it is time to be dispensed. So put in your softener (and bleach if you are using it) at the beginning of the load when you are adding your detergent. The washer will flush the fabric softener cup during the rinse fill to make sure it comes in at the right time for you.
Hope this answers your question!
Jul 04, 2010 | Frigidaire ATF6000ES Front Load Washer
Washing machine will not draw fabric conditioner
The Solution: Top up the softener tray with extra water so that it is up to the 'max level' mark.
The softener tray works by a siphon action. Thus, the reason the tray does not empty is that not enough water is added by the machine during the softening cycle, so that the machine does not completely fill the softening tray; only when the softening tray is filled beyond the 'max' mark does the siphon action works. A partially filled tray will never empty - it's impossible due to the siphon.
The reason that not enough water is added to the tray during the softening action is that the water inlet of the machine is partial blocked (you can try to fix that) but it is simpler to just added more water to the conditioner tray.
Thus, the easiest way to ensure that the softener tray empties every time (after adding the softener to the softener tray of course) is to top up the softener tray with extra water, top it up to the 'max level' line (keep a bottle of water by the machine). That way, even if only a little water is added to the softener tray during the softening cycle by the machine it is enough to trigger the siphon action and the tray will empty!
Works for me every time, and no need to remove any parts - I used to take the tray out, clean it, scrub the outlet holes that fill the tray etc, but they used to gum up again quite quickly!
Hope that helps
Aug 23, 2009 | Bosch Washing Machines
Washing instructions
My book says for the Axxis WFL 2050/WFL 2060 : from the left while looking at it from the front: detergent for wash, stain remover, middle: fabric softener, fabric conditioner, right one: detergent for soaking agent. (Do not use chlorice bleach in this wasking machine).
Oct 11, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Fabric softener compartment problem.
I have this problem as well.. All washing machines manufactured nowadays are energy effficient, which means that they don't use as much water as the older models. This can result in a build-up of bacteria in the top part of the washing machine, which is clogging up the bit where the water comes through to flush the fabric conditioner into the drum. What I have to do every so often, is to take the top off the washing machine and clean out the layer of black slime that has built up, blocking the holes where the water goes into the washing machine. Another contributory factor is that the usual program used is a 40 degree wash, which is not hot enough to completely flush the machine through. Manufacturers recommend running a 90 degree wash once a month with just washing powder in iit, no clothes. Hope this is some help
Dec 12, 2007 | Washing Machines
Bosch Classixx WFL 2066 Front Load Washer Logo
543 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
