Question about Electronics - Others
HP v218g PEN DRIVE 16 GB SHOWING 0 BYTES MEMORY
I HAVE WIN XP SP3 IN MY LAPTOP , MY HP PEN DRIVE MENTIONED IS SHOWING 0 BYTES FREE SPACE AND 0 BYTES ALLOCATED SPACE I HAVE TRIED EVERY PORT IN MY LAPTOP BUT NO SUCCESS I HAVE TRIED OTHER PEN DRIVES THEY ARE WORKING FINE MY HP PENDRIVE IS WORKING FINE ON EVERY PC AND LAPTOP EXCEPT MINE WHAT COULD BE THE REASON FOR THIS PLEASE HELP............
  • 27,725 Answers
Click start control panel administrative tools computer management disk management right click on your drive select properties
click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
then you restore it to its default status
Right click on usb drive select properties you will have an array of options
Select the hardware option then select your drive properties policies
restore defaults
Hope it helps.
Posted on Dec 04, 2012
SOURCE: pendrive problem
opening pen drive, it shows 'please insert the disk' & it shows 0 bytes & while trying to format it shows the same message again , i am using 2 gb pendrive of trancend.
Posted on Oct 26, 2008
  • 17 Answers
SOURCE: pen drive display free space 0 byte and used space also 0 byte
Try formatting the drive. Assuming Windows XP, just open your "my computer" icon, right-click on the device and choose format. Be aware, formatting will remove any data you may have had on there previously.
If you're using another OS, or if it's an existing drive, please re-state your question giving further details (what OS, what you are trying to retrieve, etc).
Posted on Aug 17, 2009
chanddra2009
  • 615 Answers
SOURCE: U-MAX 2Gb pen drive showing free space 0 byte and used space0byte
Dear sir,
Here is the solution conect it to the system,right click on your thumb drive icon appered in your computer,go to the properties,then click on tools tab,then click on check now, if there is no check disk window,keep your pen drive to the system(dont remove) restart the system.now windows checking disk for error dont skip checking,it checks your thumb drive also,and fixes file system errors.after arrival of desktop now open my computer open your pen drive.Your pen drive must open normally. thi deffinately solves your problem.
If it not opening you have to format your pen drive no other solution for this.
if you have any problem regarding this issue leave a feedback,we will glad to assist you,
Have a nice day
good luck
Posted on Sep 14, 2009
SOURCE: pen drive is showing o bytes
ple hielp me my email id is mannapur2000@gmail.com
Posted on Oct 05, 2009
SOURCE: transcend 2GB pendrive showing 0 bytes
kya baat hai.........
Posted on Nov 20, 2009
Transcend jet flash v33
Hi Virus or Trojans can run some process that keeps running in background. This not only harms the computer, but also prevents the pen drive from formatting as it shows that the drive is in use. Remove and re-insert the pen drive, don't double click on drive and cancel autorun operations if it starts automatically. Run a virus scan on pen drive, this will help fix the issue. Now format the pen drive.
Mar 30, 2014 | Electronics - Others
My (Transcend)pen drive showing free space 0 byte and used space 0 byte .
jmy (Transcend)pen drive showing free space 0 byte and used space 0 byte
Nov 26, 2010 | Transcend (589307) Media
4 GB pen drive show property as 0 byte used and 0 byte free..when subjected to open show insert disk
4 GB pen drive show property as 0 byte used and 0 byte free..when subjected to open show insert disk please help!
Aug 23, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
2GB Cruzer Micro USB Flash Drive (SDCZ62048A10) Hard Drive: i just bought a 16 gb sandisk flash drive. i took...
go to my computer, plug the drive in, right click the flash drive icon on my computer and click format.
May 18, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Pen drive display free space 0 byte and used space also 0 byte
Aug 17, 2009 | Transcend (589307) Media
Pen drive is showing o bytes
I would first put it through a fast formatte then a standard formatte, then i would recommend asector scan and see if there are any sectors that are not recoverable, if they are messed up and or still not solved try to uninstall the file that has stored the recognition files for the pen drive remove the main file in c drive program files , find the file by name corresponding to what it is you have and delet it then do a full shutdown and after a full cold start reboot install pen and software when asked if you still experience this post the results and i will try to help in a higher level of tech knowledge and support
May 31, 2009 | Transcend (589307) Media
Pen drive is not able to write any data
Your pen drive is corrpted........kindly replace your pen drive from your saler.
The best earn money site..plz signup free
http://bux.to/?r=jiteshright
(Join now and receive a $0.05 Sign-up Bonus)........click on it........
Dec 20, 2008 | AMD Chaintech ZNF3-250 Socket 754...
Pen Drive is Not able to write the data
i had purchased a pen drive of Moser Baer AZ-601USB device. previously it was working good, but since last 3 days i could not open my pen drive..it asks for formattin. i have formatted it , but after that it says your pen drive is write protected. so i could not open and use my pen drive....
so plz solve my problem to open my pen drive.
Dec 20, 2008 | Electronics - Others
How are you formatting it? NTFS or FA32?
I suggest you reformat as FAT32
Dec 19, 2008 | Electronics - Others
Unable to format 64 gb kingston pen drive
I am having 64 gb kingston pen drive.
But after formatting from command promt its file system is RAW an i cannot use the drive now.
Beacuse it is showing properties as 0 bytes.
The drive cannot be formatted.
Nov 20, 2008 | Computers & Internet
Electronics - Others Logo
513 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
