Question about Singer Sewing Machines
My singer 257 bunches up thread around the bobbin case, what do I do?
  • Singer Master
  • 1,564 Answers
Doesn't that just give you fits? :) Usually this happens shortly after a needle break. So check your bobbin, bobbin carrier, needle plate.... for stab marks and burrs. Then if you find some carefully smooth those with fine grit sand paper at least 400 grit.
Posted on Dec 05, 2012
  • 6 Answers
SOURCE: The bobbin case on my Singer Inspiration 4210
From what I gather on other sites, your thread has to be threaded under tension.... You have to make sure you hear a click when your bringing your thread down to the bottom of the "arm". Also, I thought the bobbin case was rather loosely held in its place, I adjusted this by unscrewing the black plate and moving it over just a smidge. The bobbin is supposed to have some wiggle room, but it kept popping up and making the tiny adjustment seems to have done the trick....for now...
Posted on Mar 21, 2010
SOURCE: Singer Concerto sewing machine model 9217 - bobbin thread problem
This problem is common in sewing machines with plastic bobbin cases. The new case you've ordered will most likely solve your problems. I might suggest checking the point of the rotating hook, to be sure it is burr free.
Posted on Feb 01, 2008
  • 155 Answers
SOURCE: Singer 6217C Bobbin Thread bunching
please check out this link
http://sewvacdoctor.com/cate.asp?categoryID=6#1082
goodluck
 thanks.
Posted on Oct 26, 2008
  • 4 Answers
SOURCE: singer quantum sewing machine won't pick up bobbin thread
Try changing your needle
Posted on Dec 13, 2008
SOURCE: Bobbin thread bunching
I have a Kenmore 16231 That kept bunching up on the bottom side of the material. I found to correct this problem, there is a tension adjustment under the cover on the left side of the machine ( the light is housed under this cover) I found a tensiner lever numbered 1 - 4 and if you try this adjustment on 3 or 4 this machine works great. hope this helps
Posted on Jan 05, 2009
Thread bunches up into a knotted mess on bottom. Bobbin doesn't sit flat inside the bobbin case but spins with a tilt, lower on the left and higher on the right. Bobbin touches plastic cover plate.
Usually, thread bunching under the fabric is an upper tension issue. Be sure to ALWAYS RAISE the presser foot when threading the upper thread.
With the bobbin case operating at a tilt, there is something mechanically wrong with the machine. It may be best to take it for service.
Aug 30, 2016 | Singer 4411 Heavy Duty Sewing Machine
How to adjust bobbin when using embroidery machine, bobbin thread bunches up
Check your bobbin case if it looks like it has and feels like there are barbs on it they catch the thread time for a new bobbin case. I had mine less than 2 months and had to get one my machine sews and embroiders great now
Nov 25, 2013 | Singer Futura Xl-400 All-In-One Sewing And...
I have a singer confidence 7469 quilter, the upper thread keeps bunching up in the bobbin case. I've tried re threading numerous times with no luck.
try changing the needle
make sure the bobbin is turned the correct way in the bobbin case
make sure the thread has not come off the thread take up lever
clean under the needle plate and in the bobbin area for lint
Jan 29, 2013 | Singer Confidence 7469 Mechanical Sewing...
I had a matt of thread around the bobbin. I took the needle plate off, removed the bobbin case, cleaned the hook area, but now it still matts up. I put the bobbin case in as illustrated, put in new
try changing the needle-- make sure it's the right one for the fabric
your sewing
make sure the top thread has not come off the thread take up lever
make sure the bobbin is not filled to full
make sure the bobbin is not damaged or warped
Sep 08, 2012 | Singer Sewing Machines
My bobbin on my Singer 4562 keeps bunching up the threads, can you help?
If you have the black bobbin case you must make sure you use only a good mercerised thread, there should be enough gap between the edge of the bobbin case and the silver adjuster to allow the thread to pass through, if there is not then you must slacken off the two screws and move it over a fraction.
Aug 11, 2011 | Singer 2732 Mechanical Sewing Machine
Thread keeps breaking
Have you got the needle in the correct way around - the thread must lie in the groove in the needle. Is the machine correctly threaded? Try release the tension a bit and check that the bobbin tension is not too loose and bunching up under the needle plate. The instructions for bobbin tension setting are:- Check that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder. The bobbin tension adjustment is the small screw in the plate on the bobbin case that the thread passes under as it comes off the bobbin and goes out. This might not be exactly the same as yours but should give you an idea of the position.
Mar 08, 2011 | Singer 8280 Mechanical Sewing Machine
Thread is bunching up under the material
Check the bobbin tension and that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder.
Feb 19, 2011 | Singer Sewing Machines
Thread bunches up on Singer HD-110
my wife's hd110 singer machine is not keeping tension. what can I do/ look at to try and help this
Jul 07, 2009 | Singer HD-110 Mechanical Sewing Machine
Using Singer 7470 for the first time, and my bobbin thread is bunching terribly. There is a loud sound from the bobbin chamber, as if the mechanism is bouncing around??? How can I fix this bobbin issue?...
1. Take bobbin out and re-insert and thread.
If that dosen't work, try:
2. Take bobbin out and bobbin case, clean area and re-insert bobbin case and bobbin.
3. Re-thread the top thread that goes to the needle. (Sometimes the thread dosen't hook to the "Thread take-up"(page 6 on manual). It pulls the bobbin thread and the bobbing becomes loose inside the bobbin case.
4. Wind a new bobbin (Sometimes a bobbin might wind thread to lose) Do not wind thread to the edge of bobbin.
If that dosen't work, you should take it in to be serviced...Somenthing might become loose that only a technitian can correct.
Also check manual for troubleshooting.
Good luck.....
Chickiefl
Apr 15, 2009 | Singer 7436 - INGENUITY
Sewing Machines Logo
166 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
