Question about Tefal Irons
Tefal Gv9461 how to clean the tefal base
SOURCE: Tefal self cleaning iron Ultraglide
Go to Sunbeam.com. They don't have this model - but there is an instruction manual for a 39?? - I read it and from what I remember it is the same as the 3957. It is a pdf file - page 8. - Those are the instructions.
Posted on May 12, 2008
geokohler
  • 304 Answers
SOURCE: tefal proline express steam generator iron needs de scaling
Make a solution of half water and half white vinegar. Fill up your iron and get it good and hot then let it sit a couple hours. flush out and repeat as necessary. Hope you find this helpful. Please give me a fixya rating If this works for you. It works very well as long as it is not completely filled with scale. Once you have it good and clean By a gallon of bottled water at the market and use that for your Iron and you will never have a scale problem again. I learned how to do this 20 years ago from a 80 year old woman from england. If it is really bad you can up the vinegar concentration but do not go higher than 2 cup to 1.
George
Posted on Jul 24, 2008
SOURCE: tefal express iron cleaning
Thankfully I was able to clean the boiler compartment, by unscrewing the large bolt on the boiler, cleaned with water only, loads of brown yuck came out, It would then not allow me to use the steamer, Waited until the next morning tried again and working brilliantly again.
Jopey
Posted on Aug 23, 2008
SOURCE: I have lost the instructions
go to website by clicking below. Manuals can be printed from here.
http://www.tefal.co.uk/tefal/services/instructions.asp
Posted on Jan 06, 2009
SOURCE: Tefal Pro Express - Constant Steam
Found this on another site and just tried it. Put 50/50 water and vinegar in the tank and leave it to go through on the constant steam. Give it about 5 minutes then try the button. Mine gave an extra spurt of steam at this point but still continued giving steam out all the time. I refilled with the water vinegar mix and just kept pressing the steam button and letting it go through. Eventually it fixed it and the constant steam stopped. Something to do with a piece of limescale blocking the solenoid but that's all Greek to me! Hope this helps. Kind regards.
Posted on Feb 04, 2009
We have a tefal ironing station and it has developed a fault the steam is continually on and the green light is continually flashing can u help
The problem is caused by a blockage in the steam regulating valve. try the 50:50 vinegar solution as described above, If this does not work then you need to take out the valve and clean. IT is pretty simple. Remove the bottom of the base station and you will see a rectangular box with tubes coming out of it. This is the steam valve. Dismantle and clean and you should be good to go. whole job should only take 15mins
Mar 24, 2015 | Tefal Irons
Tefal iron steam generator
Steam irons can become clogged with mineral deposits. Use distilled water in the iron to minimize these deposits.
To clean the iron , use 1/2 white vinegar and 1/2 water. pour in iron and place iron on steam. The iron may require a few cleanings.
May 11, 2014 | Tefal Irons
HOW DO I CLEAN THE IRONING SURFACE FOR A TEFAL IRON
passar vela na base do ferro, vela de parafina ou produto semelhante. Atenciosamente. @valefelix
Sep 15, 2011 | Tefal Irons
How do i clean a tefal avantis 75iron
Howdy,
The Tefal PDF links for your model are not present, but here is the manual for a similar model by Tefal: http://www.t-falusa.com/NR/rdonlyres/FEBC20F7-ADAC-459C-9213-B3C3B67E57CF/210/PRIMA_gb.pdf
I hope you find it pertinent to your model:)
Aug 24, 2010 | Tefal Ultraglide 1549 Iron
Tefal steam iron not heating up properly
That is probably because the contacts to the element at the base of the iron are broken.
To disassemble you have to remove the casing, then remove the steam pump at front top of iron and then undo the safety screw mounted on the front of the base plate.
Apr 22, 2009 | Tefal UltraGlide plus 1656 Iron
Tefal express iron cleaning
Jopey
Aug 19, 2008 | Tefal Irons
Tefal Pro Express
  1. solenoid valve blocked
  2. swich for steam broken
  3. you forget it in turbo steam mode and you have steam all the time
ps see below on link turbo button
http://www.gostore.com.au/~ebay/krups/tefal/proexpressturbo/TefalProTurboAuction(3).jpg
Jun 22, 2008 | Tefal Ultraglide 1549 Iron
Irons Logo
170 people viewed this question
Top Tefal Irons Experts
Billy Detlefsen
Are you a Tefal Iron Expert? Answer questions, earn points and help others
