Question about Dell Dimension 8400 PC Desktop
Set up cd rom dell dimension 8400 - Dell Dimension 8400 PC Desktop
  • Dell Master
  • 3,606 Answers
Hello Download drivers here at dell:
http://www.dell.com/support/drivers/us/en/19/Product/dimension-8400
The drivers can be downloaded one by one.
You maybe need to unzip the file before you install.
Here is only drivers for win xp.
You can`t download a setup disk but you can call dell support
to order the software from them (if they still have it) by the service tag.
Good luck
Posted on Dec 11, 2012
novafire
  • 61 Answers
SOURCE: Dell 8100 Dimension will not find the Hard Drive or CD Rom
If the drives share the same IDE cable, try to replace the cable and make certain it is seated properly on the motherboard. Check for bent pins on either drive and on the motherboard IDE connector. Sometimes pins (especially near either end of the 2 rows of 20 pins) will bend under if they are not lined up with the IDE cable. Also check that nothing changed on the Jumper positions on the drives. They should be set to Master if both drives are single and Master (hard drive) and Slave (CDROM) if they share the same cable.
Posted on Jun 29, 2009
benwabnick
  • 2404 Answers
SOURCE: Installed new WD HDD in dell 8400 unable to boot from CD
Make sure that the operating system cd has no smudges, dirt, dust, etc on it.
What I would do since you have two optical drives in the system. Disconnect one of the drives at first and only hook up one of the optical drives and make sure the jumper on the back is set to master.
Go into the BIOS and reset the bios defaults and have it redect the hardware in the system after this you'll get the same message so reboot into the BIOS and set the optical drive as the first boot device. Hopefully it will read the cd and you press and key to boot up off of the cd.
If this doesn't work then repeat all the steps i mentioned for the 2nd optical drive. Hopefully it will read the cd properly with this drive. Im checking to see if one or both drives have bad lasers in them.
If the 2nd drive doesn't read it then at this point disconnect the hard drive completely from the system and then turn it on and see if the optical drive can read the cd, if it does at this point then that means your new hard drive is defective cause its shorting out the secondary controller on your motherboard.
Let me know how things go and I'll help you further if you need some more help.
Posted on Jul 06, 2009
shahabdun
  • 249 Answers
SOURCE: dell dimension 8400 fan problems
Power supply needs to be checked.
Vaio Tech
  • 166 Answers
SOURCE: dell dimension 8400 will not start.
no man try to take out the modem ( last pci slot on the botom of the board) and see if you have any luck if not you going to need a new motherboard thanks and good luck
Posted on Oct 12, 2009
erone47
  • 458 Answers
SOURCE: CD-ROM drive doesn't acknowledge DVD-ROM, what's wrong?
CD-ROMs dont play dvd becuase they are not designed to read dvd.
If a dvd drive for your model is not available, you can buy an external usb dvd drive.
That should solve your problem
Posted on Dec 29, 2009
Reinstalled Windows XP on a Dell Dimension 8400 and The local area connection is not detected. Cannot seem to find drivers through Dell support
Dell Dimension 8400 PC"s use either Broadcom Extreme Ethernet controllers OR, on SOME models of the 8400 that do NOT have ON-board Ethernet connections, SMC Networks Ethernet Drivers. I've seen MANY a Dell Dimension.
Sep 11, 2013 | Dell Dimension 8400 PC Desktop
I have a dell dimension 8400 with a TSST CORP TSH492B cd-rw/dvd drive. Windows only sees this as a cd-rom and automatically uses the following drivers storprop.dll cdrom.sys imapi.sys redbook.sys. I...
those are the basic drivers for all cd. dvd, and rw drives. if you are trying to use the drive to burn a cd/dvd you need to purchase software for it your download a free burning software from filehippo.com called xpburner or burnerxp i cant recall the exact name
Apr 14, 2011 | Samsung (TSH492BLACK) CD-RW/DVD-ROM Combo...
Dimension 8400 locks up. Keyboard won't respond.
Generally and indication of a software issue that is locking the system. There can be hardware causes too.
  1. Run diags on the system (From Resource CD or F12 menu) see if any failure. If you have a hardware failure then address it and see if the problem is solved.
  2. Update bios and drivers from support.dell.com
  3. Edit MSCONFIG, startup group, remove entries that are not required (Generally only AV and printer scanner items are needed here, most other items will function without and item here)
  4. Edit the Virtual Memory settings, and set it to Custom and an amount double the RAM (EG: 4 GB RAM set initial and Mas to 8200 MB VRAM)
Apr 04, 2010 | Dell Dimension 8400 PC Desktop
No boot device available - strike F1 to retry boot, F2 for setup
again check is bios is there set first deviced as cd rom dvd rom?
If it is just clean your bootable windows cd with hand caurchief.
Then check if it not boot with disk then your cd disk of windows is not bootable or faulty.
Please let me know.
Jun 06, 2009 | Dell Dimension 8400 PC Desktop
JLMS DVD-ROM XJ-HD166 cannot detect any CD
dear friend this is due to u are using a pirated cd .
or your computer lens is not able to read it .
so no need to worry if you have problem try other cd .
and if it fails please contact me
Mar 28, 2009 | Dell Dimension 8400 PC Desktop
I'm having an issue reinstalling Windows XP on a Dell Dimension 8400 PC.
Okay you need to boot from cd
put win cd in drive restart when asked to boot from cd hit enter
this should get you there
if not we'll have to change your boot options
Jan 15, 2009 | Dell Dimension 8400 PC Desktop
No sound from my dell 8300
  1. Make sure the speakers are plugged into the CD-ROM drive headphone jack.
  2. Reboot the system and press F12 at POST to enter the one time boot menu.
  3. If Boot to Utility Partition is an option, select it; otherwise insert the Resource CD into the CD drive and select ATAPI CD-ROM.
  4. Select Boot from CD-ROM and choose the correct options to enter the 32bit Dell Diagnostics.
  5. Run the Audio Tests within the utility.
this would let you know if the problem is with the sound card or the softare ie the drivers for the sound card
Apr 15, 2008 | Dell Dimension 8400 PC Desktop
Dell Dimension 8400 PC Desktop Logo
78 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
