My Coleman Evcon BGU12520A won't start. I have to turn main switch off than back on to get it to run. I have changed the thermostat 3 times now.What can it be?
2 Suggested Answers
  • 2463 Answers
SOURCE: Coleman Evcon BGU12520A won't ignite
check the ignitors condition is it cracked broken burnt out etc , ifn so then it will need replacing , or check the pressure switch is working try jumping it out and see if the ignition glows ,
Posted on Apr 09, 2010
Furnace wont work
Have to know the model and serial of the furnace.
locate code list usually inside or on the back of a door.
Operation sequence= call for heat--inducer blower motor--makes pressure switch--signals board to bring on hsi--after a set time gas valve opens and you have ignition--main blower motor comes on after a set time
Feb 14, 2014 | Coleman 7990-319p Evcon Gas Furnace...
Coleman Evcon furnace. Can i make it circulate air?
Your thermostat should have a "continuous blower" setting. Use that instead of fooling around with the A/C setting
Jul 17, 2013 | Coleman 7990-319p Evcon Gas Furnace...
I have a coleman evcon model eb15a furnace. it does not work with the therostat, if you turn the main breakers on the fan and one elament come on the fan auto/continuious run switch doest work either any...
Hello, have you tried jumping the R and W wires on the thermostat sub base? If this turns on you furnace than the thermostat is bad, however if there is no display on the thermostat and does not power up by jumping the R and W Wires then most likely the transformer is bad and must be replaced.
Mar 16, 2011 | Coleman Heating & Cooling
Apr 09, 2010 | Heating & Cooling
Coleman evcon four flashes on indicator...fans work... won't fire
Hi it could be the pressure switch clean the back of the fan control sensor, and the flame sencer
Feb 19, 2010 | Tools & Hardware - Others
Air conditioning runs all the time
I assume this is a manufactured home, this is probably a two transformer system, either your contactor is welded in the on positon or wyou have control wiring issues, (could be the thermostat)
Jul 12, 2009 | Coleman Heating & Cooling
Coleman furnace blower runs continuously
You should be seeing 120 volts to the igniter. Anything less requires either a replacement of the transformer, start relay or control module.
Dec 19, 2007 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
