Tevion DVD3602 UKW Circuit diagram
Power unit failure
    Master:
  • 879 Answers
Check this site. It has more than 1400 posts to different brands of electronic entertainment and other equipments. All posts referrers with the repair and fault finding to electronic entertainment equipments. It will be best to view it either in Flipcard or Timeslide option, can be selected by the sidebar tag at the top left of the display screen. Timeslide view will be the best to select. If you are using Google Chrome as browser, Flipcard option will be the best.
Posted on Dec 02, 2012
Replace missing switch on bench grinder
2 wires are not needed to use they are the wires of an supression capacitor on the switch then there are 2 wires from your power cable and 2 that goes to your motor that 4 you only you have to use you can also connect the 2 wires from the s-capacitor with te wires on the motor together thats is how its also correct, (but best is to remove it because its only for suppression for FM ukw radio signals and everybody has DAB+ and the change to have short-circuit is reduced.
Sep 30, 2015 | Bench Grinders
What does F09 mean mean for a whirlpool AW0 3561 front loader?
Washing Machine Fault Cod Fault
FH No Water Inlet
FA Aquastop Failure
FP Drain Failure
F5 NTC Failure
F6 Tachometer Failure (no motor movement detected)
F7 Triac Short Circuit detection
F8 Heating Element, Open Circuit
F9 Overflow Failure
F10 Motor control unit (Thermal)
F11 Communication failure
F12 Heating Element Short Circuit
F13 Dispenser Circuit Error
F14 EEPROM Failure
F15 Motor Control Unit Error
F16 Control Failure (Control Unit)
F18 Control Failure (Control Unit)
F20 Control Failure (Control Unit)
F21 Control Failure (User Board)
F22 Control Failure (User Board)
FDL Door Lock Error
FDU Door Unlock Error
Whirlpool Washing Machine Fault Codes
So the answer is Overflow Failure
Apr 13, 2015 | Whirlpool Washing Machines
Str f6707a circuit diagram (power on power led glow but power led off after 1 second)
LG may be able to supply a circuit diagram that will enable you to determine the cause of power supply failure.
Apr 29, 2014 | LG Televison & Video
Where can I get a circuit diagram for POWER BOARD MLT666 (VERSION A & B) as used in my Tevion TV
You are not going to in most cases find a schematic as only boards are sold.
It could be a flat pack chip or if it reacts on the power board a filter cap--at least if the set is opened inspect all the filter caps for any even slightly puffed up or showing signs of leaking material top and bottom.
4_30_2012_3_49_28_pm.jpgThese are clearly bad caps.
Apr 26, 2012 | Televison & Video
Manf. cntrl veh. spd. idle speed control auxiliary inputs
DTC P1572: BRAKE CANCEL SWITCH OUT OF SELF TEST RANGE NOTE: Limited information available from manufacturer.
NOTE: For circuit reference, see appropriate diagram in WIRING DIAGRAMS article.
Possible Causes
  • Open circuit, high resistance or short circuit between the brake cancel switch and PCM signal circuit.
  • Open or short circuit in the brake cancel switch power supply circuit.
  • Brake cancel switch failure.
Apr 18, 2012 | Volkswagen Jetta Cars & Trucks
No power
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
Jan 08, 2012 | Tevion AP-DVR18 DVD Recorder
Model ir2016 e808
E808-0000 DRIVE CIRCUIT FAILURE
A zero crossing signal cannot be detected.
A fixing drive motor failure has been detected.
Fixing drive circuit failure
Main Cause/Symptom
- The heater does not turn on.
- A fixing drive motor failure was detected.
Countermeasure
- Check the connector of the fixing film unit.
- Replace the fixing film unit.
- Replace the fixing drive motor.
- Replace the DC controller PCB.
- Replace the power supply PCB.
Oct 29, 2010 | Canon Office Equipment & Supplies
Code to progarmme Tevion TV
Might be a bit late - but I hope this helps..
Tevion is made by Medion..
The only code I find for them is 191
Good luck..
Jul 22, 2008 | Televison & Video
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
Electro Med Services...
