Question about Tricity Bendix Dishwashers
Tricity Bendix TBD W42 wont turn on no lights nothing was working but now nothing ???
Was working grand then nothing,no lights power switch on/off has no effect any help would be great thanks.
SOURCE: my tricity bendix washing machine flashing and beeping end light
Hi, we had something similar happen just before christmas. Our machine seemed to finish a cycle and started making beeping noise with end light flashing. Then when I switched it back on to do another load it just started beeping with end light flashing no matter what cycle was selected. Engineer has been out and advised that it is a fault with the motherboard so has ordered another one. Hope this is of some help. Machine was tricity bendix aw1400w.
Posted on Jan 05, 2007
  • 116 Answers
SOURCE: Tricity Bendix washer won't take fabric softner in rinsing cycle
Your machine possibly has a defective water inlet valve which is preventing water from entering the dispenser channel to flush the fabric softner into the machine. The inlet valve in inside of your machine right where the washer hoses attach. the solenoid valves on the inlet will need to be checked with a multimeter to verify if they are working properly.
Posted on Mar 11, 2007
  • 1462 Answers
SOURCE: tricity bendix keeps turning off !!
assuming you still have power to machine, it could be that the main circulating pump has a thermal overload in it which is tripping off. can you give me more detail?
Posted on Apr 24, 2007
  • 38 Answers
SOURCE: Tricity Bendix AW1400W Won't spin or agitate.
this could either b the motor brushes or the timer check the brushes first they r mounted on either side of the motor unplug the machine b4 u start good luck
Posted on Aug 26, 2007
GothicXDolly
  • 40 Answers
SOURCE: tricity bendix dishwasher slimline
It Might Be Cloged Or Food Particles May Be In It Try Cleaning It Out Well!
Posted on Jan 27, 2008
Tricity bendix washing machine won't work on any of the settings
Hi, mine is the same - it will literally go on forever and it wont seem to ever 'finish' like it wont drain properly either - is it the 800 model? quite and old machine with a button you push in and twist to select the cycle and pull out to turn it on? its just awful it wont give an indication whether its completed any cycle! did you get yours fixed?
Feb 25, 2016 | Tricity Bendix Washing Machines
How do i fix a tricicty bendix dryer
You need to call a technician. If this unit is only 6 months old, it must be under some type of warranty.
May 04, 2015 | Tricity Bendix Washing Machines
Will a Tricity Bendix AW1000W Washing Machine run on a clock timer?
hi your machine will remember prog if there a power cut and restart from where it was interupted. So if you load the machine and start it then turn the power off on the timer it will continue when the timer switches back on (yes is the answer)
Nov 20, 2010 | Tricity Bendix AW1000W Front Load Washer
Tricity bendix aw1001w door lock wiring...
If you have multimeter and can use / 1 wire = live feed 1 wire is switch, 3rd is a netural idea is door lock gets 240 volt live netural feed energises the lock which in turn switches feed over to other connection..look at interlock to get idea what wire goes where....
Oct 31, 2009 | Tricity Bendix AW1000W Front Load Washer
Tricity Bendix DH101 dishwasher
my tricity bendix dh101 will not fill up with water what could be the problem
May 09, 2008 | Tricity Bendix 24 in. DH102 Free-standing...
Dryers
I think the pump is full of lint, and is not able to pumpe the water from the bottom container to the container in the panel. Check that;)
Jan 03, 2008 | Tricity Bendix TM310W Electric Dryer
TUMBLE DRYER
Hi, It wont fill up when the full tank light is on because it thinks the tank is full. Remove the tank and feel down inside where the tank sits into the machine. You should feel the switch, it sounds like it is stuck down.
Jan 03, 2008 | Tricity Bendix AW1400W Front Load Washer
My Tricity Bendix won't work
Check out the water inlet solenoid valve if this is clicking then it is probably the water level pressure switch which appears to be controling the flow of water mechanicaly dependent on whether the water is high enough in the machine and therefore giving enough pressure to close the switch .This may be stuck closed.
Oct 17, 2007 | Tricity Bendix 24 in. DH102 Free-standing...
My tricity bendix washing machine flashing and beeping end light
Dec 14, 2006 | Tricity Bendix AW1400W Front Load Washer
Dishwashers Logo
46 people viewed this question
Top Tricity Bendix Dishwashers Experts
Are you a Tricity Bendix Dishwasher Expert? Answer questions, earn points and help others
